Question about Coffee Makers & Espresso Machines
Hi., What causes a white scale on a frangipani leaf and how do I get rid of it? Thanks
    Top Expert:
  • Coffee Maker... Master
  • 75,807 Answers
The white scale is mineral deposits from hard water, use white vinegar to clean/remove it, run the white vinegar full strength through the machine a couple of times. Do this on a regular basis to stop the scale from building up.
Posted on Dec 28, 2016
The trays in my 1-1/2 year old dishwasher seen to be plastic coated. They have now acquired a kind of lime scale buildup. What is the cause or how can I get rid of the build-up
First of all I am not paid to sell product but I can tell you the build up you have is normally soap. You can use vinegar, but I personally use a product called Lemi-shine. I add this to the soap (2 tablespoons) to the soap in the door for every load. This will clear this issue you have and keep the dishwasher clean like the day you got it. If you doubt this check out the Finish website as this will answer the questions you might have. Good Luck
Oct 09, 2014 | Refrigerators
No steam coming out of iron, does it need descaling and if so how do you do it? Thanks Iron is Wahl zx506-1
Hi, Brown water and whitescale are often the result of the water you use in the iron... If you have scale, white vinegar will clean that... For brown water, empty the iron, rinse out the insides with bottled water, and then use the bottled water instead...
Also check out this tip...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
Aug 25, 2011 | Microwave Ovens
I need to get rid of hard water scales inside the dishwasher
One of the safest and least expensive ways to remove scale is to run the EMPTY dishwasher through a cycle using 1/2 cup of white vinegar. If all the scale is not removed during one cycle, then repeat the process.
I hope this gets rid of your problem. If it does, please come back to fixya and rate my solution!
Jun 29, 2011 | Dishwashers
Dishwasher leaves grit on dishes even after a full wash
Most likely need to clean your dishwasher. Yes....clean the dishwasher. Hard water builds up scale in them, and the best way to clean them is with a product called "Lemi Shine". It's actually just citric acid the same as you find in oranges and lemons, but in this case you put it in the dishwasher and run it empty. It cleans off the scale and deposits that have built up in the tub, pump, and wands. You can do the same thing with a quart or so of white vinegar, but it would take a few times to get rid of the smell. The Lemi Shine smells like lemons, so you won't need to worry about it after you use it.
Best wishes, and thanks for using FixYa!
May 03, 2011 | Kenmore Dishwashers
How do i clean the boiler
Brown water and white scale are often the result of the water you use in the iron...
Cleaning a Steam Iron White Scale and Brown Water
heatman101
Apr 21, 2011 | Irons
Hello, I need to know how to de-scale my chrome Simplex Kettle for gas ranges. Thanks, barb
to perform a de-scaling on your unit --- just add about 1 cup of white vinegar to the water and let it steam out. do this twice,, and then do two fresh water steam outs to get rid of the vinegar.
c...
Feb 16, 2011 | Simplex SIM-BF2 Electric Kettle
Brown water spitting out of bosch steam iron
heatman101
Feb 03, 2011 | Bosch TDA8340 Iron
I use distilled water in my Roweta. When ironing a white shirt this morning, brown water came out and stained the shirt. What could have caused this and what can I do in the future to avoid this?
heatman101
Jan 22, 2011 | Rowenta DX6700 Iron
Photo has 'lines' across it. New batteries just fitted. Have the settings been reset??? How do I get rid of the lines???
Lines across photo's or over exposure Is due to the shutter not closing correctly. Common cause for this is moisture fouling the shutter leafs. It only has to be a very tiny amount to cause an obstruction. If you turn on your camera and turn the flash off face the lens towards you and look at the lens in the middle you should be able to see the shutter fire across the lens when you take a picture. I know its small but you should be able to spot if there is a gap ( may not be very big) where the shutter leafs meet. What you need to do is remove the lens unit from the camera, dis engage the zoom motor ( the motor nearest the front lens) then remove the main lens to access the zoom lens and remove that aswell. Behind it is the shutter. Undo the screws for the retaining plate, remove the plate, and then remove the shutter leafs for cleanning with lens cleaner or anything that will clean without leaving a residue. And remember not to touch the leafs after cleaning, use tweezers.
Sep 27, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
Humidifier does not reset
According to Holmes, one of the causes of the Reset light staying on is scale buildup on the heating element.
Remove Scale: Allow to cool before maintenance.
1. Repeat steps 1-5 in the Daily Maintenance section.
2. Clean the base by partially filling the base with one
8-oz cup of undiluted white vinegar. Let solution stand
20 minutes, cleaning all interior surfaces with a soft
brush. Dampen a cloth with undiluted white vinegar
and wipe out entire base to remove scale.
3. Rinse with clean warm water to remove scale and the
white vinegar solution before beginning to disinfect
the tank.
4. Wipe the heating element clean with a soft cloth after
it has had chance to cool.
If the scale has really built up it might take longer than 20 mins for the vinegar to get rid of it and you might need to refresh with new vinegar.
Your Manual can be found at this link:
http://www.holmesproducts.com/Manuals/Holmes/HM5250-UC_English.pdf
Good Luck.
Apr 07, 2008 | Holmes Products HM5250-UC Humidifier
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
