Question about Dehumidifiers
My Soleusair Dehumidifier has buildup around the filter. Whatis causing this.
    Top Expert:
  • 79,077 Answers
Dirt and dust and pet dander?
Posted on Dec 28, 2016
Why is my soleusair dehumidifier model GL-DEH-50 say F2
Pipe Temperature Sensor Malfunction.
1.
Unplug the dehumidifier.
2.
Check the surrounding area
for possible reasons for sud-
den temperature changes.
3.
Wait 2 hours before plugging
the dehumidifier back in for
normal operation.
4.
If the "Error" is still indicated,
please contact customer
service. Call 1-888-876-538
Soleus Air SG DEH 70EIP 6 Operating Instructions Manual Error Codes...
Jul 31, 2017 | Dehumidifiers
How do I fix leaking dehumidifier?
units that leak some times are a total loss but not allways , sometimes its just not being used on level surface (water seeks level allways) , there are lots of ports inside that need to be kept clean for all the units water to drain out , look inside with a flashlight to see if any buildup is obvious that might be cleaned off ? if not a last effort is to remove cover to see 1st hand what cause is(remove power plug 1st) , rust /mold/dust are all common things to find inside that affect units operation
Jun 29, 2014 | Kenmore 50 pint Dehumidifier w/Electronic...
After an hour, the refrigeration unit begins to freeze up. Condensation appears on top of the dehumidifier cabinet. I have eliminated all obstructions to air flow, including the filter. What can I do?
The most common cause of frost and ice buildup on a dehumidifier is because the unit is operating in temperatures that are too cold. Many dehumidifiers are not equipped to run at temperatures below 65 degrees Fahrenheit.
To fix this problem, Position the dehumidifier in an area where there is at least one foot of clearance around the unit in order to allow for proper air circulation during its operation. Close all windows, doors and other outside openings to make sure your unit isn't attempting to remove moisture from areas outside of the immediate room. Determine the temperature of the room by checking a nearby thermostat or by using a hand-held thermometer.
Check the filter for dirt and buildup. Unplug the unit from the electrical source and check the filter by opening the filter compartment. If the filter is dirty, it will restrict airflow through the unit and lead to freezing. Soleus recommends lightly vacuuming the surface of the filter to remove dirt. The filter also can be washed in warm water if it is extremely dirty. Once clean, place the filter back in its compartment. Allow for the ice to melt and then restart your dehumidifier.
Sep 10, 2011 | LG LHD45EL Dehumidifier
Esco Oasis 2700L dehumidifier ices up. Is there a filter to be cleaned and if so, how to I get to it?
Jul 03, 2011 | Dehumidifiers
This dehumidifier continues to run after it is full, spilling water out of the full tank. How can I fix this?
Diane, the float valve in the left top of the bucket (it's styrofoam) is stuck and can't shut the unit off when the bucket is full. To help you solve this, I am providing a link to your Owners Manual that will help you with this problem You can download and print the manual for future reference Be sure to turn the Master ON/OFF Switch to OFF and unplug the unit, before attempting to solve this problem.
http://www.soleusair.com/soleusair/Manuals/Dehumidifiers/CFM-25E_CFM-40E_manual_revised%20_07-24-2007_.pdf
Hope this helped you to solve the problem. Please take a moment to rate my response to you.
Thanks.
Apr 27, 2011 | Soleus CFM-40 Dehumidifier
Soleusair showing signs of limited life
If the room temp is below 60 degree, coils may be frozen in block of ice - see if you can see into grills.
If frozen, unplug and set in tub or over drain.
Check to see that it is not set on CONT (continous) as it will run but with low indoor humidity in winter, not have mosture to extract.
Sep 20, 2009 | Soleus CFM-40 Dehumidifier
Soleus CFM40E
Looks like 1 yr warranty so if a coolant system problem and more than 1 yr old, not worth repairing, but try:
contact@soleusair.com
Jun 26, 2008 | Soleus CFM-40 Dehumidifier
Dehumidifiers Logo
156 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
