Question about Refrigerators
I have a GM-DEH-30M-1 that is about 3 years old. Ice builds up around the filter. What is causing this?
peyton32034
  • 410 Answers
SOURCE: Ice Jam in Chute - Whirlpool IDI SxS
first check would be to see if the flapper door is closing all the way in the dispenser area. best way is to remove the ice bucket and shine a flashlight from the front up into the disp door area and look for light around the door from inside the chute.
another check would be to make sure the door delay mechanism is connected an not allowing the dispenser door to close to fast trapping a cubes in the door and causing an air leak in the chute..
Keep in mind if you use alot of crushed ice frost build up is faster than with just cubed.
Posted on Dec 11, 2007
IFIXALL
  • 868 Answers
SOURCE: ice maker's ice taste funny
You may consider pulling out the ice maker and tossing it in the trash if you look at it and see that where the ice sits it's corroded or its close to a 10 year old in age (IT'S DUE TO GO OUT ANYWAY).Other than that:you have a 3% chance that the tube that goes to your ice maker is bad. Please Rate This !
Posted on Jun 12, 2008
SOURCE: Ice build-up around the fan making a noise.
Drain line froze.
Used hair dryer to thaw frozen line, works OK now. 01/07/09
Think the frozen drain line was caused by the light in the refrigerator not shutting off when the door closes, causing excess cooling in the freezer. Poor design on the light shutoff switch, corrected design to make permanent repair
chestnutlee.
Posted on Jan 07, 2009
  • 44 Answers
SOURCE: ice build up in the bottom of my upright freezer
If it's a frost free model, it could be caused by a plugged defrost drain. Every time it goes through a defrost cycle the water is supposed to drain into the compressor compartment. You can defrost it by unplugging it for a day or two and then remove the panel covering the evaporator coil. You should be able to see the drain tray under the coil and find out whats blocking it.
Posted on Aug 27, 2009
EllaWatson25
  • 725 Answers
SOURCE: I have a hotpoint refrigerator with model number: HSS25GFTA BB
You have a defrost problem. No biggie. Check your heaters first, then your t-stat and timer. After a year, you may need to repalce all three parts as after time, the ice takes out other parts if they are not changed right away. You will need to make sure the unit is completely thawed out before replacing parts for optimum use. Call or email us for the part that you need and we'll be sure to get them to you right away! Hope this solves all your problems.
Posted on Sep 09, 2009
Testimonial: "THANKS"
Have a second hand Homemaker chest freezer model hmbd155....recently noticed fluid around the floor....? Leaking..don't have a manual and noticed a dial on the bottom left hand corner .What this do..?
The dial Adjusts the temperature. If it is adjusted too cold you might have ice build up underneath the freezer thus causing the fluid that you see. As the freezer is old it can also be that the insulation underneath is a bit old causing the ice build up and fluid leakage. A broken thermostat (dial) will also cause too low temperature inside and possible ice build/fluid leakage.
Oct 04, 2017 | Refrigerators
Ice buildup in bottom of freezer compartment
Here's a link to a great website that will help you understand what might be causing your freezer to have that ice build up. I could explain it here, but if you look at this link, they've already done a wonderful job.
http://www.appliance411.com/faq/defrostproblem.shtml
Jun 08, 2016 | Samsung RF4287HARS French Door...
Bosch frig/freezer fan icing up... How can I stop the problem?
This could be caused by 1 of 2 problems.
1. Your evaperator coils could be clogged with dust. Clean with a vacuum hose.
2. If that is not the problem, the freon pressure is probably low and this is caused by a leak. This would require a professional repair person. How old is the frig? Sometimes they are not worth the repair cost.
Mar 09, 2015 | Bosch Refrigerators
Loud "clattering" noise from freezer area when refrigerator runs
There is a fan in the back of the freezer that runs when the compressor is running. It sounds like you have ice build up around the fan.
You could have one of these problems: (Sorted by most likely to least likely)
1) Auto Defrost timer, defrost bi-metal or defrost heater is defective - the unit will go into auto defrost about twice a day, if this fails you will have lots of ice built up around the cooling fins and sometimes on the fan. Pull the back off the inside of the freezer and check for ice build up around the cooling fins, there should be none or very little if its running normal.
2) Bad door gasket - if the freezer door is leaking warm moist air inside the freezer it could be condensing around the fan causing ice (you will also see ice build up on things inside your freezer too).
3) Plugged drain - the drain leads from the freezer down to the drain pain under the fridge. If this is plugged ice will build up on the bottom of the freezer and potentially around the fan.
Apr 01, 2013 | Kenmore Refrigerators
Ice build up around intake?
Shut it down and make sure the cooling coil and filters are clean. Ice usually means one of two things
1. dirty filters or coil
2. low gas (freon) charge
Jun 02, 2010 | Goodman CKL24AR24 Air Conditioner
Noise on the ice maker
I think you are having the same issue that I am having. My noise is being caused due to ice build up around the fan inside the freezer. There is a switch when you open the door that causes the fan to shut off, hence the reason the noise stops when you open the door.
I pulled the cover (just below the ice maker) and removed the ice that had built up. Only problem is that after three days the noise is back. I think there may be a bigger problem that is causing the ice to build up around the fan.
Jan 05, 2009 | Samsung RS2630WW Side by Side Refrigerator
Drain line froze.
chestnutlee.
Dec 27, 2008 | GE Refrigerators
Ice build up
HELLO AND THANK YOU FOR YOUR QUESTION.WITH REGARDS TO THE ICE BUILD UP IN THE BOTTOM OF THE FREEZER THAT COULD BE CAUSED BY ONE OF THREE THINGS.YOU NEED TO CHECK THAT YOUR HEATER ELEMENT IS WORKING OK AS THIS WILL CAUSE THE ICE NOT TO DEFROST FAST ENOUGH BEFOR THE FRIDGE COMES BACK ON.SECONDLY THE FAN NEEDS TO BE CHECKED IF ITS WORKING OK THAT CAN ALSO CAUSE IT.LASTLY YOU DEFROST CLIQSANS NEED TO BE CHECKED TO SEE IF THEY ARE SENSING THE TEMP CORRECTLY.GOODLUCK.MOHAMED
Sep 15, 2008 | Whirlpool GD2SHGX Refrigerator
Frigidare side by side Gallery fridge
sounds like you water is spilling out instead of going into ice maker... check the inlet spout for ice or other blockage
Oct 10, 2007 | Frigidaire GLRS237ZA Side by Side...
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
