I need to view all charges on my count - Office Equipment & Supplies
My tablet fully charges.. then dies within an hour.. why?
Probably the battery is unable to hold a charge.
Feb 01, 2016 | Tablets & eReaders
How to enable the meter count of canon iR600n
Hmmmm. I have to assume you merely wish to view the meter. The only way I am aware of for an older copier such as yours is to open the front door and view the ANALOG meter which is @ the left upper quadrant of the covers. This count I believe can also be obtained in service mode but we wont go there.
Dec 01, 2012 | Canon imageRUNNER 5000 Copier
Where is meter reading on canon imageRunner C5180i color copier?
Hi sophie,
Look to the far right of the operator contol panel, past the 9 key pad and you will see a "little button" called COUNTER check. Press it and it will tell you your meter reading.This screen can be configured "by a service tech" to allow you to view the count of up tp 6 different meter counts depending on the function you wish to monitor. The basic meter reading is named "101". That because there are hundreds of funtions that are always monitored and they name them 101,102,103 etc. 101 counts the number of sheets of paper that have exited the copier. "102" does the same except it counts 11x17 [ledger] as 2 copies as 11x17 is really 2 letter size sheets. So my company uses this meter for billing purposes so we ADD the 102 meter to the list of viewable meters. Again this can be configured to the customers needs or the service provider needs. You can set it to view just black and white, just color, or even how many copies were made at 64%. its wild. But the 101 meter is the default and cannot be removed or altered. I sure how I helped you. Please let "FIXYA" know.The pat me on the head when I do good. :-) Take care . SPINAL
Jan 28, 2011 | Canon imageRUNNER C5180i Color Copier
How do I reset the maintence kit counter for an Infoprint 1532?
This is a lexmark based machine with IBM logo's
1 of the 2 options should get you squared away
---- Option 1 ----
To enter the Diagnostic Mode:
1. Turn the printer off.
2. Press and hold the Go and Return buttons.
3. Turn the printer on.
4. Release the buttons when "Performing Self Test" displays on
the operator panel.
This counter is reset by the servicer after a "80 Scheduled
Maintenance" message displays (300K copies) and a maintenance
kit is installed.
To view the Maintenance Page Count:
1. Select Maintenance Count Value from the diagnostic menu.
2. Press Return to go to the previous menu.
To reset the Maintenance Page Count to zero:
1. Select Reset Maintenance Count. Pressing Select causes the
maintenance page counter to reset to zero.
- Reset Maintenance Count Saved displays momentarily.
When the reset operation is complete, the menu returns to
the Printer Setup Reset Maintenance Count screen.
---- Option 2 ----
Maintenance page count
This counter is reset by the servicer after a 80 Scheduled Maintenance message displays
(300K copies) and a maintenance kit is installed.
To view the maintenance page count:
1. Select Maintenance Count Value from the Configuration menu.
To reset the maintenance page count to zero:
1. Select Reset Maintenance Count from the Configuration menu.
2. Pressing Select resets the maintenance page counter to zero.
Reset Maintenance Count Saved displays momentarily. When the reset operation is complete,
the menu returns to the Printer Setup Reset Maintenance Count screen.
Oct 19, 2010 | IBM Infoprint 1532 Laser Printer
How do i reset the maintenance count?
1. Select Reset Maintenance Count Configuration menu.
Mar 30, 2010 | IBM Infoprint 1532 Laser Printer
Reset maint counter
Page 3-17 of IBM's service guide
Mar 25, 2010 | IBM Infoprint 1352 Laser Printer
80 maintenance infoprint 1125
You need to replace your Maintenance kit and reset the fuser count.
This counter is reset by the servicer after a “80 Scheduled
Maintenance” message displays (300K copies) and a maintenance
kit is installed.
1. Select Maintenance Count Value from the Diagnostic menu.
Select Reset Maintenance Count. Pressing Select resets the
maintenance page counter to zero. Reset Maintenance Count
screen.
the operator panel.
The tests display on the operator panel in the order shown:
• Print Registration
• Print Tests
• Hardware Tests
• Duplex Tests (If installed)
• Input Tray Tests
• Output Bin Tests
• Base Sensor Test
• Printer Setup
• Error Log
• EP Factory Defaults
Sorry English only.... hope you can read English or google translate it...
Feb 24, 2010 | IBM Infoprint 1125 Laser Printer
How to find page count option
You either hold the go button until the lights flash and it will give a printout or just press the start a couple times for a printout that also gives the print count.
Oct 15, 2009 | HP LaserJet P2015 Printer
Nikon D80 Exposure Count
My camera is now fixed. It was a tiny speck of dirt on the sensors between the mounting of the lense & the camera. The uy that fixed it said it is a problem with the camera because they are so sensitive.
Jan 13, 2008 | Nikon D80 Digital Camera with 18-135mm...
14 people viewed this question
jasbo
jasbo
