Question about Ridgid Tools & Hardware - Others
Ridgid 18 in. belt sander makes grinding noise
redbeard00
  • 957 Answers
SOURCE: ORBITAL sander screeching (NOT belt sander!)
No, sounds like a bad bearing. But depending on who made it parts may be available. Don't know if it helps but I use a co. called GRAINGER, they are pretty helpfull. good luck.
Posted on Apr 26, 2009
SOURCE: My belt sander makes a horrible noise.....like
I have a Rigid belt sander and after nearly continuous use the fan bearing overheated and melted the plastic housing it is surrounded by. The net result was the bearing moved and that caused the belt (toothed) to be too loose and slip- causing a loud rasping sound. I heated the bearing up with a propane torch and moved it back close to where it should be. Then was faced with the globs of melted plastic that were binding the fan gear. A dremel tool was used to get rid of the plastic and it sort of works without growling most of the time now. Basically, Home Depot tools aren't made for continuous duty and if you use them that way they self destruct.
Posted on Sep 23, 2009
farmerbear
  • 490 Answers
SOURCE: where can i find a
You came to the right place:) Here it is:
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/90511879,BR318.pdf
Hope this is very handy for you.
Regards, Farmerbear at FixYa.com
Posted on Sep 09, 2010
pst4911
  • 41 Answers
SOURCE: my makita 4"X24" sander makes
http://www.ereplacementparts.com/makita-9404-belt-sander-parts-c-97_103_535.html
I would say you have a bearing going out ether on the motor this web address will take you to a good break down of the housing I would say you need a motor bearing it will also give you a parts # but if you have a bearing supplier somewhere ( I look in yellow pages for electrical motor repair) you might find the bearing for a cheaper price just remember to take the old one with you so you are sure to get the same size. I have found bearing and belts for my table saws are the same as for some clothes washers for about 1/2 the price as ordering from sears
good luck
Pat
Posted on Oct 29, 2010
SOURCE: My beloved sander dosn't get up to speed and is
I just had the same problem with mine. I replaced the motor start capacitor with one from Grainger and it starts like a champ now. I found one that had the same specs as the stock one and it also fits inside the cover perfectly. Here are my notes:
Grainger Item 2MDR5
MFD Rating: 189-227
Voltage: 110-125
Hz: 60/50
Shape: Round
Dia. (In.): 1-7/16
Case Height (In.): 2-3/4
Overall Height (In.): 2-3/4
Original start capacitor was:
CD60
125/156V AV
200 UF
Blue shrink wrapped can with pigtails.
Length: 81mm (3.19")
Diameter: 34mm (1.34")
Posted on Mar 10, 2011
I have a Makita belt sander,just replaced belt tensioner system including springs and roller but belt drive roller still keeps stopping on relatively light load even though the motor is running
very good trade tool
how quickly is it getting hot
slowing motor could be the cause
motor bushes and bearings can be replaced
did the motor drive belt under the cover get replaced
Jun 02, 2016 | Makita 9911 Compact Lightweight 3" X 18"...
Belt sander runs until I put pressure on it
It sounds like the sand paper itself is slipping. There should be an adjustment to tighten the pressure on the sand paper itself.
Feb 28, 2015 | Ridgid Makita 98462 9910 Belt Sander 120v...
Ridgid random orbit sander will not turn on
Mine also, in the middle of a job and it just stopped, no warning , did not slow down or bog just quit.
Apr 26, 2014 | Ridgid R2601 5-Inch Random Orbit Sander
I have a power devil belt sander, but every time i turn it on for use the belt works its way off... i bought this sander second hand at a boot sale so im thinking is there supposed to be an outside guide...
no there is not anything missing, you need to adjust the belt by turning the black plastic adjuster knob which guides the belt to the left. I have found that whilst using the sander you sometime need to adjust it further. If you adjust it too much the belt will hit and grind the plastic casing of the sander.
Also make sure you are using the correct size belt as it should be size 75X533 which you can buy from Toolstation for £2.78 a pack of 5.
Sep 03, 2011 | Electric Power Belt Sander, 3" X 21" 700...
Dead. Power is connected, wires are in tact. Just died when I was using it. Is ther an internal reset?
Try to plug something else into the outlet, just to make sure that the breaker didn't trip.
Try to run the sander without a belt. It may be in a bind.
With the sander unplugged, check the motor brushes. Replace if necessary.
If everything above checks out OK, you may have a loose wire.
Regards, --W/D--
Jul 13, 2009 | Ridgid 3 X 18 Belt Sander
Describe your Black & Decker BR318
This is a good sander but no portable belt sander is really a floor sander.
Jun 13, 2009 | Black & Decker BR318 3" x 18" Belt Sander
New belts on drum sander shear off inside clip
Belt sander are very tempermentel and require a light machine oil (3-in-one) on the metal slides and Tension lever and springs to opperate properally, if not they will drive you nuts, it will make a big differance, a few drops will do ya, more it needed, to much will cause a reverse action and collect dust, clean areas before oiling with air preasure and fluids if needed to get rid of build up from wood dust
Jan 20, 2009 | Delta 31 - 255X X5 18'' x 36'' Drum Sander
Tools & Hardware - Others Logo
85 people viewed this question
Top Ridgid Tools & Hardware - Others Experts
R Daniel Wolfe
 perry tradesman    ...
perry tradesman ...
Level 1 Expert
Are you a Ridgid Tool and Hardware - Other Expert? Answer questions, earn points and help others
