A step by step list of checks to follow to identify the malfunctioning section of my refridgerator
  • Washing Mach... Master
  • 5,323 Answers
It helps if u say what is the problem first
Posted on Jan 15, 2017
I just bought a 1998 Pontiac Bonneville and now the system monitor light is on why and what does that mean?
No other messages in the driver info center ?
This section provides an overview of the instrument cluster operation as well as a detailed diagnosis. The instrument cluster serves as the primary interface for the vehicle's driver.
The instrument cluster contains a microprocessor as part of the instrument panel assembly. The instrument cluster performs the following functions:
• Recognizes operational malfunctions
• Alerts the driver through indicators
• Stores DTCs which identify malfunction areas
In order to perform all of these functions, the instrument cluster microprocessor has its own inputs, outputs and program software. The instrument cluster has the capability to diagnose malfunctions in the following components:
• The sensors
• The input switches
• The components
• The systems the instrument cluster communicates with or controls
When the instrument cluster or another microprocessor-controlled module detects a malfunction, the instrument cluster may turn on an instrument cluster indicator in order to alert the driver that a malfunction has occurred. Some indicator lamps have dual controls. Your best bet is have it checked for DTC'S diagnostic trouble codes !
Mar 02, 2016 | Pontiac Cars & Trucks
Tip
Fix Windows 7 Error ?Windows is Not Genuine? Error code 0×80070005
To resolve this issue, you can either disable the policy setting (Method A), or edit the permissions to provide the Licensing Service the required permissions (Method B).
Method A: Disable the Plug and Play Policy 1. Determine the source of the policy . To do this, follow these steps:
a. On the client experiencing the Activation error, run the Resultant Set of Policy wizard by clicking Start, Run and entering rsop.msc as the command.
b. Visit the following location:
Computer Configuration / Policies / Windows Settings /Security Settings / System Services /
If the Plug and Play service is configured through a Group Policy setting, you see it here with settings other than Not Defined. Additionally, you can see which Group Policy is applying this setting.
2. Disable the Group Policy settings and force the Group Policy to be reapplied.
a. Edit the Group Policy that is identified in Step 1 and change the setting to “Not Defined.” Or, follow the section below to add the required permissions for the Network Service account.
b. Force the Group Policy setting to reapply: gpupdate /force (a restart of the client is sometimes required)
Method B: Edit the permissions of the Group Policy: 1. Open the Group Policy that is identified in Method A, Step 1 above, and open the corresponding Group Policy setting.
2. Click the Edit Security button, and then click the Advanced button.
3. In the Advanced Security Settings for Plug and Play window click Add and then add the SERVICE account. Then, click OK
4. Select the following permissions in the Allow section and then click OK:
Query template, Query status, Enumerate dependents, Interrogate, User-defined control, Read permissions
Note: The Previous rights are the minimum required permissions.
5. Run gpupdate /force after you apply the previous permissions to the Group Policy setting.
6. Verify that the appropriate permissions are applied with the following command:
sc sdshow plugplay
The following are the rights applied to the Plug and Play service in SDDL:
D:(A;;CCDCLCSWRPWPDTLOCRSDRCWDWO;;;SY)
(A;;CCDCLCSWRPWPDTLOCRSDRCWDWO;;;BA)
(A;;CCLCSWLOCRRC;;;IU)
(A;;CCLCSWLOCRRC;;;SU)
S:(AU;FA;CCDCLCSWRPWPDTLOCRSDRCWDWO;;;WD)
(A;;CC LC SW LO CR RC ;;;SU is an Access Control Entry (ACE) that allows the following rights to “SU” (SDDL_SERVICE – Service logon user)
A: Access Allowed
CC: Create Child
LC: List Children
SW: Self Write
LO: List Object
CR: Control Access
RC: Read Control
SU: Service Logon User
Note: If there are no GPO’s in place, then another activity may have changed the default registry permissions. To work around this issue, perform the following steps:
1. On the computer that is out of tolerance, start Registry Editor.
2. Right-click the registry key HKEY_USERS\S-1-5-20, and select Permissions…
3. If the NETWORK SERVICE is not present, click Add…
4. In Enter the object names to select type Network Service and then click Check Names and OK.
5. Select the NETWORK SERVICE and Grant Full Control and Read permissions.
6. Restart the computer.
7. After the restart, the system may require activation. Complete the activation.
on May 19, 2010 | Computers & Internet
Tip
Error messages when you try to install Windows XP Service Pack 3
When you try to install Windows XP Service Pack 3 (SP3), you may receive the following error message:
An internal error occurred
After you click OK in the error message, you receive the following error message:
Service Pack 3 installation did not complete
Additionally, you may see the following errors that are logged in the C :\Windows\Svcpack.log file: 165.672: An internal error occurred.
165.672: Service Pack 3 installation did not complete.
165.672: Update.exe extended error code = 0x1ffe054f
165.672: Update.exe return code was masked to 0x643 for MSI custom action compliance
Note Throughout this article, the C :\Windows folder represents the folder where Windows XP is typically installed.
CAUSE
The errors that are mentioned in the "Symptoms" section can occur because of files that are not trusted or because of corrupted registry keys. You can verify the cause by searching for related entries in the Svcpack.log file. Specific entries will identify specific causes of the issue, as noted in the following "Cause" sections.
Cause 1
Determine whether the following entries are logged in the Svcpack.log file: 142.391: CheckVLKForBlock: LIC.dll not trust verified
142.578: Trying CheckVLKForBlock again
142.594: CheckVLKForBlock: LIC.dll not trust verified
142.594: Error: CheckVLKForBlock failed
These entries indicate that the cause of the issue is the Licdll.dll file. The Licdll.dll file may have been altered, is corrupted, or is not trusted. The Licdll.dll file is located in the following folder:
C :\Windows\System32\
Cause 2
Determine whether the following entries are logged in the Svcpack.log file: 211.890: IsSPBetaKey:pLA->lpVtbl->GetProductID Failed: 0x80004005
213.125: Trying CheckVLKForBlock again
214.468: Error: CheckVLKForBlock failed
These entries indicate that incorrect product ID information in the registry is causing the issue.
Cause 3
Determine whether the following entries are logged in the Svcpack.log file: 299.031: Trying CheckVLKForBlock again
299.531: Error: CheckVLKForBlock failed
These entries indicate that corrupted or altered registry keys in preinstalled programs are causing the issue. Note One program that is known to cause this issue is Micrografx - Picture Publisher Professional 10. To work around this issue, see the "Workaround for Cause 3" section.
RESOLUTION
To resolve or to work around these causes, use the resolution or the workaround that corresponds to the cause.
Resolution for Cause 1
To resolve this issue, you must replace the current copy of the Licdll.dll file by using a copy from the original Windows XP media. To do this, follow these steps: 1. Insert the Windows XP CD into the CD drive.
2. Click Exit on the Setup Wizard as soon as it starts.
3. Click Start , and then click Run .
4. Copy and then paste (or type) the following command in the Open box, and then press ENTER:
explorer
5. Click My Computer .
6. Note the drive letter that contains the Windows XP CD.
7. Click Start , and then click Run .
8. Copy and then paste (or type) the following command in the Open box, and then press ENTER:
cmd
9. Type or copy and paste the following text into the Command Prompt window, and then press ENTER:
Expand CD_Drive_Letter :\i386\licdll.dl_ C :\Windows\system32\Licdll.dll
Note In the command in step 9, replace CD_Drive_Letter by using the actual drive letter for the drive that you noted in step 6.
10. To install Windows XP SP3, visit the following Microsoft Windows Update Web site:
http://windowsupdate.microsoft.com Resolution for Cause 2
To resolve this issue, you must replace the incorrect product ID registry entry with the correct product ID. To do this, follow the steps in the "Locate and note the product ID" and "Identify and change the product ID registry entry" sections.
1. Click Start , and then click Run .
2. Copy and then paste (or type) the following command in the Open box, and then press ENTER:
sysdm.cpl
3. On the General tab locate the product ID. The product ID is the 20 digit number that is located under the Registered to section.
4. Note the product ID for use in the "Identify and change the product ID registry entry" section. Identify and change the product ID registry entry
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
322756 How to back up and restore the registry in Windows
regedit
3. Locate and then click the registry subkey that resembles the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\WPA\Key- XXXXXXXXXXXXXXXXXXXXX
Note The series of Xs represent a placeholder for a string of 21 characters.
4. There may be several subkeys that resemble the format in step 3. To determine the correct subkey, follow these steps: a. Click each subkey in the navigation pane.
b. In the details pane, compare the value of the string for the ProductID registry entry under the Data column to the number that you noted in step 4 in the "Locate and note the product ID" section.
c. The registry subkey whose ProductID registry entry value matches the number that you noted in the "Locate the product ID" section is the registry subkey that you want.
5. In the navigation pane, right-click the registry subkey that you identified in step 4c, and then click Export .
6. Save the registry subkey to the Desktop as temp.reg .
7. Right-click the temp.reg file on the Desktop, and then click Open With .
8. Click Notepad , and then click OK .
9. In the open temp.reg file, locate the following text:
[HKEY_LOCAL_MACHINE\SYSTEM\WPA\Key- XXXXXXXXXXXXXXXXXXXXX ]
10. Replace the text that is mentioned in step 9 by using the following text:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion]
11. Click File , click Save , and then exit Notepad.
12. Double-click the temp.reg file, click Yes in the dialog box when you are prompted to add the information to the registry, and then click OK .
13. To install Windows XP SP3, visit the following Microsoft Windows Update Web site:
http://windowsupdate.microsoft.com Resolution for Cause 3
To resolve this issue, you must delete the InprocServer32 registry subkey. To do this, follow these steps: 1. Click Start , and then click Run .
regedit
HKEY_CLASSES_ROOT\CLSID\{00020420-0000-0000-C000-000000000046}\InprocServer32
4. Click InprocServer32 . A string value with the name InprocServer32 is displayed in the details pane. Click this value.
5. On the Edit menu, click Delete , and then click Yes .
6. Exit Registry Editor.
7. To install Windows XP SP3, visit the following Microsoft Windows Update Web site:
on May 03, 2010 | Computers & Internet
I have a 2004 envoy xuv and my service 4wd light came on but I don't have any lights on the switch and it won't change into anything and I don't hear anything trying to engage and lights don't blink
The Automatic Transmission Diagnostic System Check is an organized approach to identify a problem created by an automatic transmission. The Diagnostic System Check - Engine Controls in Engine Controls - 4.2L or Diagnostic System Check - Engine Controls in Engine Controls - 4.8L, 5.3L and 6.0L is the diagnostic starting point for an automatic transmission complaint. The Diagnostic System Check - Engine Controls in Engine Controls - 4.2L or Diagnostic System Check - Engine Controls in Engine Controls - 4.8L, 5.3L and 6.0L directs you to the next logical step for diagnosing a transmission concern. Perform this check only if there is a driveability complaint or if you have been directed here from another service information section.
Follow the table to help reduce diagnostic time and help prevent unnecessary replacement of good parts.
  1. Install a scan tool.
  2. Important: Check for applicable service bulletins before proceeding with this test. Perform this test only if there is a driveability complaint or if you have been directed to this table from another section in the service information.
    Important: Do not turn the ignition OFF when performing this diagnostic procedure. Do not clear the DTCs unless instructed by this diagnostic procedure.
  3. Turn ON the ignition, with the engine OFF.
Does the scan tool turn ON?
Go to Step 2
Go to Diagnostic Starting Point - Data Link Communications in Data Link Communications
Is the MIL ON?
Go to Step 3
Go to Malfunction Indicator Lamp (MIL) Inoperative in Engine Controls - 4.2L or Malfunction Indicator Lamp (MIL) Inoperative in Engine Controls - 4.8L, 5.3L and 6.0L
Attempt to establish communication with the PCM controller module or modules.
Does the scan tool communicate with the PCM control module or modules?
Go to Step 4
Important: Diagnostic Trouble Codes (DTCs), engine performance, and transmission default actions can greatly affect the transmission performance. Ensure that these items are not the cause of a transmission concern.
Use the scan tool Capture Info function in order to save or capture (Store Info) any DTC Information.
Are there any DTCs present?
Go to Diagnostic Trouble Code (DTC) List/Type
Go to Symptoms - Automatic Transmission
Your best bet is take to transmission repair shop or the dealer
Dec 04, 2015 | Cars & Trucks
2002 chevy silverado trys to stall in any condition sometime it will stall. all dash light will come on. starts right up.
Is check engine light Lit ? You should have all the computers on the vehicle check for DTC'S - diagnostic trouble codes ! Check the battery an all connections !
Diagnostic Starting Point - Engine Electrical
Begin the system diagnosis with the Diagnostic System Check - Engine Electrical . The Diagnostic System Check will provide the following information:
The identification of the control module(s) which command the system.
The ability of the control modules to communicate through the serial data circuit.
The identification of any stored diagnostic trouble codes (DTCs) and their status.
The use of the Diagnostic System Check will identify the correct procedure for diagnosing the system and where the procedure is located.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
Lack of communication may be due to a partial malfunction of the class 2 serial data circuit or due to a total malfunction of the class 2 serial data circuit. The specified procedure will determine the particular condition.
The symptom list in Symptoms will determine the correct diagnostic procedure to use.
The presence of DTCs which begin with "U" indicate some other module is not communicating. The specified procedure will compile all the available information before tests are performed.
Step
Action
Yes
No
Did you perform the Battery Inspection/Test?
Go to Step 2
Go to Battery Inspection/Test
Does the scan tool power up?
Go to Step 4
Go to Scan Tool Does Not Power Up in Data Link Communications
Important: The engine may start during the following step. Turn OFF the engine as soon as you have observed the Crank power mode.
Access the Class 2 Power Mode in the Diagnostic Circuit Check on the scan tool.
Rotate the ignition switch through all positions while observing the Class 2 Power Mode on the Scan Tool. Refer to the Serial Data Power Mode table within the Body Control System Description and Operation in Body Control System for a list of the power mode states that correspond to each ignition switch position.
Does the Class 2 Power Mode parameter reading match the ignition switch position for all the selected positions?
Go to Step 4
Go to Power Mode Mismatch in Body Control System
Attempt to communicate with each module on the class 2 serial data circuit:
• The body control module (BCM)
• The driver information center (DIC)
• The instrument panel cluster (IPC)
• The powertrain control module (PCM)
Does the scan tool communicate with any module on the class 2 serial data circuit?
Go to Step 5
Go to Scan Tool Does Not Communicate with Class 2 Device in Data Link Communications
5
Select the Display DTCs function for each module. If using a Tech 2, use the Class 2 DTC Check feature in order to determine which modules have DTCs set.
Record all of the displayed DTCs the DTC status and the module which set the DTC.
Does the scan tool display any DTCs?
Go to Step 6
Go to Symptoms - Engine Electrical
6
Does the scan tool display any DTC beginning with "U"?
Go to Diagnostic Trouble Code (DTC) List in Data Link Communications
Go to Step 7
7
Does the scan tool display any DTC beginning with "B"?
Go to Diagnostic Trouble Code (DTC) List in Body Control Systems
Oct 28, 2015 | Cars & Trucks
Tip
How to put a reserve price in your ebay listing
Here's how you can put a reserve price in your listing, follow these steps:
First, if you are lisitng an item using the Simple Form you need to switch to form with more choices first. In the Create your listing form please click the "Switch to form with more choices" link that you will see on the upper right hand corner of the Create Your Listing page. Then follow the steps below:
1. On Create your listing/Edit your listing page, scroll down and look for "Choose how you'd like to sell your item" section on yellow orange background.
2. Click on "Add or remove options" link within the same section.
3. Click "Set a minimum selling price for your item" for Reserve price and the "Save" button after.
4. This will appear: "No Reserve price set for this item. Change"
5. Click on Change to put a Reserve Price. Then click on Save button.
on Dec 31, 2009 | Computers & Internet
Microphone is not working
Note that the microphone is not listed individually in Device Manager because it works through your sound card. Perform the steps in the following sections in order, and then test to determine if your issue is resolved after each section.
NOTE: The microphone should be selected as the recording device in the Volume Control tool(sndvol32.exe).
To verify this, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type sndvol32.exe, and then click OK.
  3. Click Properties on the Options menu.
  4. In the Adjust volume for box, click Recording.
  5. Click OK.
  6. In the Microphone box, verify that the Select check box is selected.
All the properties listed on the Playback section of the Volume control are independet of the recording settings. So you could record through the microphone by selecting it on the recording section, and mute it on the playback section. Then, you could record sound, but wouldn't hear it through the speakers while you are recording.
Check Your Hardware loadTOCNode(2, 'moreinformation'); If your microphone has never worked, or if it has stopped working, first check the physical connection of the microphone. Verify that it is firmly plugged into the microphone port instead of the headphone or speaker port. If you are not sure which port is correct, you can check the sound card to see if it is marked (sometimes with a picture of a microphone), you can use a process of elimination, check the documentation that came with your hardware, or contact the hardware manufacturer.
Jul 23, 2011 | Sony VAIO VGN-NR310E/S Laptop
I have genuine windows 7 but computer says that it is not genuine
To resolve this issue, you can either disable the policy setting (Method A), or edit the permissions to provide the Licensing Service the required permissions (Method B). Method A: Disable the Plug and Play Policy
1. Determine the source of the policy. To do this, follow these steps:
a. Edit the Group Policy that is identified in Step 1 and change the setting to "Not Defined." Or, follow the section below to add the required permissions for the Network Service account.
Query template
Query status
Interrogate
Read permissions
sc sdshow plugplay
(A;;CC LC SW LO CR RC ;;;SU is an Access Control Entry (ACE) that allows the following rights to "SU" (SDDL_SERVICE - Service logon user)
A: Access Allowed
CC: Create Child
LC: List Children
SW: Self Write
LO: List Object
CR: Control Access
RC: Read Control
Note: If there are no GPO's in place, then another activity may have changed the default registry permissions. To work around this issue, perform the following steps:
  2. Right-click the registry key HKEY_USERS\S-1-5-20, and select Permissions...
  3. If the NETWORK SERVICE is not present, click Add...
If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
Thank you and Keep Visiting FixYa!
Apr 13, 2011 | Microsoft Windows 7 Ultimate 32 & 64 BIT
I have listed something on Ebay and it doesnt give me the option to put a reserve price
cheers!
Oct 03, 2009 | eBay Auctions
My samsung yp-s3 doesn't work, i can't trasnfer music from my pc to my mp3
I had the same problem and an older PC using XP Professional. With a bit of research I found the corrective action.
1. The Samsung must be properly identified by windows as a storage device.
This is accomplished by obtaining the Update for WMDRM-enabled Media Players (KB891122) from Microsoft. The driver is a part of media player but it is listed seperately.
at http://update.microsoft.com/microsoftupdate/...
2. Once you have updated the driver the My Computer Should Identify a MTP Drive using the S3 as an identifier. You could drag and drop the data using the drive section or continue with the third step listed.
3. Reload the Samsung Media Studio and the S3 portable device will be enabled.
S.Risoff
Mar 20, 2009 | Samsung YP-S3JAB Digital Media Player
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
