Question about Locks & Locksmithing
My sentury safe model V260 with keys an electronic keypad will not lock, please help i dont have the lock number anymore
SOURCE: how to cahnge the battery on a sentry safe
There is a small opening on the front number panel of safe. Use a small hex screwdriver or pin to insert into opening. It will open up the front panel (slide panel to right to take off) showing you 4 AA batteries. Just replace and close panel. Very simple to do. I wish the manual show me how. Instead of trying to figure it out for hours.
Posted on Sep 23, 2008
SOURCE: how to change the battery of my sentry safe model v260
You must replace the batteries located in under the keypad.
Use a large paperclip to unlock the cover. Push the paperclip into the small hole while at the same time, sliding the battery cover to the right. Gently remove the battery housing and replace batteries. You will have to reset your password again, but can find the directions to do so by going to the Sentry site: http://www.sentrysafe.com/pdfs/OwnersManuals/172967.pdf,
Posted on Oct 04, 2008
SOURCE: Schlage electronic keypad lock doesn't work
I have the same/similar problem. I called the company 888 number. The customer rep promised to send me a new one. good luck
Posted on Jun 09, 2009
  • 384 Answers
SOURCE: LOCKED KEYS INSIDE A HARDLINE SAFE
Do you expect us to read minds?
Posted on Jul 16, 2009
deanot26508
  • 77 Answers
SOURCE: locked out of my cs2 safe
If you registered your safe with the manufacturer they will normally let you know your combination if you have registered the safe.
If not you will need the serial number on the side of the safe and you will need a notary stamped paper explaining you are the rightful owner of the safe.
Costs will apply to the Notary and possibly from the manufacturer.
Posted on Aug 23, 2009
Testimonial: "thank you very much your help was excelent "
Need to open a Sentury safe key pad only the batteries died
without knowing the model the best i can doe is link you to you tube and some of the fixes there. i used this search term how to open a sentury safe key pad only batteries died. you may try other terms to get different videos on how to do it. good luck.
https://video.search.yahoo.com/search/video?fr=crmas&p=how+to+open+a+Sentury+safe+key+pad+only+the+batteries+died%3F#id=1&vid=1b6eaea93a88d9929e8b1ce283d04996&action=click
Oct 23, 2017 | The Home Security
Have key and code...safe will not open
Sentry Safe not unlocking - YouTube
? 0:36
https://www.youtube.com/watch?v=4mbtSUAoS6w
May 8, 2013 - Uploaded by 1diazsantana1
When i put the pass-code on my Sentry Safe the handle will remain locked and I ... mine dont want to open either! i get 5 beeps ... How To: Open A Locked Sentry Safe If You ForgotCombination Code Or Lossed Key Model Is ...
Opening a Sentry Safe with a Rubber Mallet, some WD-40 ...
idoneitmyself.com/.../opening-a-sentry-safe-with-a-rubber-mallet-some-...
May 7, 2010 - Since this safe can only be opened with an electronic code, this is a .....i have sentry V260 electronic with key, no handle. cant find key and ...
Jan 05, 2016 | Sentry Safe Fire-Safe .8 Cubic Ft....
I can't get into my gun safe and I have already changed the battery but my combo doesn't seem to work anymore,what do I do ?
If you don't have a key to get into your safe try contacting the manufacturer and give them the serial number of your safe for a new set of keys and or keypad. I had to do this when the keypad on my safe failed. Fortunately I had the keys to mine.
Jan 10, 2015 | Locks & Locksmithing
The Sentry V260 safe will not open. Replace batteries?
Locksmiths agree on how to install sentry safe batteries
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place. How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Mar 11, 2010 | Sentry Fireproof Safe
Detroit electronic digital safe lost code and keys
Help, just boughta Detroit digital safe, code number to open my instructions are locked inside.
Feb 19, 2010 | Sentry Fireproof Safe
I can't reset by keypad on my cannon gun safe electronic key pad
First I would try the original numbers to see if you did change it. If the original numbers work then you need to start over. If they don't work then the new numbers you installed are there and you need to figure out what you punched in not what you meant to punch in.
Hope this Helps,
RSMITH972278
P.S. FOR FURTHER ASSISTANCE PLEASE PROVIDE MAKE AND MODEL
P.P.S. PLEASE RATE ME
Nov 15, 2009 | Locks & Locksmithing
Sentry S3807 safe-cannot open
locksmiths agree on how to install sentury safe batteries
to install batteries, turn the electronic lock case to the right and remove.Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Jan 26, 2009 | Sentry Fireproof Safe
The number 1 button will not press
Key override
If your electronic lock fails or you do not have any codes
available, you may use a key override to access this unit.
1. Remove the battery cover, disconnect and remove the
battery holder.
2. Insert the skeleton key (second set of keys provided)
into the key hole inside the opening for the battery.
3. Turn the key to the right.
4. Turn the four-bitted key to the right.
5. Open the door.
You can download the user manual here:
Dec 24, 2008 | Sentry Fireproof Safe
I cannot open my safe.
try holding the # and the * key for 5 seconds that should reset the safe and open it up
Dec 22, 2008 | Sentry Fireproof Safe
Sentry codes v260
You should have received two skeleton keys when you bought the safe. They will open the safe without the key AND without the code. If you don't have it, the only solution is to get help from Sentry. By following the instructions below, they will send you a skeleton key for your safe. First, find your safe’s Serial Number. The Serial Number is printed on the small label on the right side of safe (outside). Send this, a notarized letter(last name must be different) stating you are the safe’s owner, and a check or money order or $8.00 (U.S. funds) to:
Sentry Group Dept. 200
882 Linden Ave
Rochester, NY 14625-2784 If using a credit card (Visa/MasterCard only), call 1-800-828-1438.
Oct 19, 2008 | Sentry Fireproof Safe
Locks & Locksmithing Logo
78 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
