Question about Lands Phones
No lights on the plug my phone said check phone line
Cant receive or make calls on KX-TG2382
Can only be three things
unit broken
no power
no phone line
Does the display light up? If so, you have power, so it must be the phone line to your home. Plug in an old style phone and see if you have a line and dial tone.
No display lights up? Check the socket on the wall with an appliance known to work. If the appliance works, you need a new power supply unit, or at least it needs checking for voltage with a test meter.
any further questions, please reply as a COMMENT.
Jul 16, 2016 | Panasonic Lands Phones
Line in use light is on but phone is not being used
pull the phone jack from the wall, pull the mains adapter to the phone, count to 10. Plug the phone jack back in, plug the power adapter back in.
If that doesn't work and you can't make a call, contact your Telco on a cellphone and ask them to check the line.
Are you sure the blinking light isn't a voicemail message?
Oct 24, 2015 | Vtech DECT 6.0 Digital Cordless Phone
PK5001 solid red DSL light
The trick I found for this is amazingly simple. Take the phone line out from your DSL modem and plug your phone line temporarily into an antique regular telephone for a second, check that it has a dial tone, and plug it back into your DSL modem. Your red light should go green in a minute after plugging the phone line back in. If you leave your computer idle too long, I think the phone company senses no activity and kills the connection after a few dead minutes, and the signal gets booted into some electronic alley. Also put tinfoil over your splice connectors as they leak signals that totally confuse your modem. Never leave any bare wires, I tinfoil the entire modem to prevent the neighbors from hacking me. I don't use wireless, only CAT5 ethernet cable.
Jan 04, 2014 | Computers & Internet
My phone says check tel line.
I have a similar model from the same manufacturer.
You've got the AC adapter plugged into the wall and the phone base, and the phone wire with std. phone connectors plugged into your phone jack and phone base, and it's still not working.
This can happen if the phone line is not active, or if the "pair" of wires is reversed (which is how DSL worked exclusively for years). Ultimately, it's not sensing a dial tone on the line you're base is plugged into.
First, make sure you can hook up a std. phone handset, if you have one, to the active phone line wire and plug to make sure the line and wire can result in a dial tone. Then, unplug that phone and plug in your new base. You should now be able to use the phone.
If, for any reason, you can't get a dial tone, it may be possible the plug you're using had a two-line phone plugged into it previously, which places the other line on another pair within the 4 wires for that type of plug. In other words, the active wires you want are in the wrong place for the phone to access.
I would recommend taking this handset to a phone jack you know to work fine with a single-line phone, near an AC outlet, and give it a try there like I outlined above. If it works there, then it's just the phone jack and maybe wiring position that is your issue.
You can also find at many hardware and electronic stores a simple phone line checker. It's a small box with some lights on it, with a short phone cable and plug coming out of the other end. You plug this into your phone line jack, and it tells you if the phone wires are wired correctly (typically a green light), or crossed (red light). This may be the source of your problem.
I hope this helps!
Feb 15, 2012 | Uniden DECT15885 58 GHz 1Line 1Line Phone
Can you use the nortel t7316e on a normal land-line..? I've noticed if I plug it in to a land-line that the top left red light flickers on and off, along with the microphone button bottom left and the...
You get around the problem by unpluging the phone and taking it back to wherever you got it, or going out and buying a CICS, MICS, or BCM cabinet to plug the phone into.
A Multi-line digital phone doesn't operate on a POTS telephone line.
Carl
May 28, 2011 | NorStar T7316E Corded Phone
I use AOL as my ISP, with British Telecom supplying my telephone line rental. On Friday 2nd my internet connection kept dropping out, and then eventually stopped connecting altogether. My original router...
If BT tested the phone line is OK but did AOL test the connection to the Netgear router and get the IP address of your Netgear router.
The phone connection is OK but the ADSL connection from the telephone exchange may not be working, that is why you are not getting an ADSL light.
Jul 12, 2010 | NetGear DG834 Router
Phone won't transfer to next free line when a second call comes
If you are not getting a dial tone then something is holding the line off hook. Disconnect any other device you have on your lines and check to see if you get your dial tone back. If you still have no dial tone unplug each phone and check again. You may have to disconnect everything for a minute or two so the phone company will reset its equipment. Plug in your phones one at a time and check your dial tone every time you add something new.
If you add something and you loose your dial tone immediately you may have a crossed connection in the wall socket, any splitters or in the phone plug. Check to make sure all of the wires in those sockets are straight before you plug in your phone wire.
If you add your CC machine and everything is good but it fails after you run a transaction you will have to contact the supplier of your CC machine. It is not hanging up the line.
Mar 22, 2010 | Panasonic KX-T7730 Corded Phone
The phone has a buzz on it and it is not the line it's the phone att945
Buzz may be from many different sources.
First, is there DSL on this line? Make sure you have a filter on the line going to the phone or plug your phone into the jack coming out of the DSL modem.
Next, remove any other device from the line and check the buzz. Sometimes a fax machine, computer or credit card machine will create noise on the line.
Then check the connections in the wall, any splitter and in the phone. Make sure the wires are straight before you plug in the phone cord.
If that does not help, take a regular phone and plug each wire into that phone and listen for the buzz, it may be a pinched wire.
Or, you may have a wire running past something that has a large electrical current. Try moving the wires away from a television, florescent light, etc.
Lastly, these phones have a cable length maximum. If you have too much cable in the office they will act as an antenna and this will add buzz to the line.
Feb 10, 2010 | AT&T ATT-945 Corded Phone
2701HG-B
Hi. I will not repeat the check the phone line and resetting comments as it's now redundant.
I always have a spare modem as a line tester.
I've seen several 2700HG-B 2wire modem/routers burn out and every single time it's the DSL signal or modem portion that is burnt out. Even if you have two or three phone line surge protectors these 2700s are prone to shorting out unless you have a direct signal splitter DSL setup.
Here are a few things you can try to confirm if the 2700 is no longer functional on the DSL signal light problem.
#1: Turn on (plug in) your 2700 without the phone line plugged in and wait. If the DSL starts flashing red then there is a hardware problem in the modem/router.
#2: Plug the phone line into the 2700 while the dsl light is flashing red. It might take about 3 seconds however it should start to flash green and let it flash for about (usually) three minutes. If it turns red then the 2700 is indeed damaged.
#3: If you can enter into your modem using the http://2wire... and check the connection status. The first two status lines should read attempting to connect and no connection.
Nov 01, 2007 | 2wire 2700HG-B Router (2700HGB)
My intercom button flashed red to green. When I push a line button, I get a two-tone beep but no dial tone. I changed the internal 9 v battery. I unplugged the phone and waited, then plugged it back in....
Each telephone must be connected to line 1 and line 2 for
proper operation. The remaining lines 3 and 4 may — or may not —
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set). Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
Aug 29, 2007 | GE 2-9450C Corded Phone
Lands Phones Logo
32 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
