Question about Oliso Irons
My Oliso iron leaks all the water out onto my ironing board and items that I am ironing. This has happened several times, iron Ian about a year old.
I fill iron and use a little bit and the next day when I go to use it again all the water has leaked onto my ironing board
SOURCE: LEAKING IRON
This was happening with mine - leaving trails of water behind as well when I ironed. I took it all apart (figured it was already broken, what could I do worse?) I discovered that there is a rubber gasket around the hole that lets water move from the reservoir to the heating plate. The two surfaces (reservoir and plate) are held together by screws, which compresses and seals the gasket. The bottom surface of the reservoir section had been cracked (due to a drop on the cement floor, probably, and the two surfaces could no longer fit tightly together, the crack allowed it to flex, and water leak out. In other word, once it's leaking like that, it's time for a new iron. Sorry I can't offer a fix, but at least a explanation!
Posted on Oct 04, 2008
SOURCE: Rowenta Powerglide 2 INOX vertical steam, no steam, just water leakage
replace the o-ring gasket on the tank fill cap. It is a simple neoprene "O" ring you can buy at your local hardware or NAPA aauto parts store for less than $3.00.
st. louis mo Ralf
Posted on Feb 04, 2009
SOURCE: iron leaks water while ironing
Seal on iron is disolved. replace iron
Posted on Aug 31, 2009
Testimonial: "your information was very helpful."
heatman101
  • 43501 Answers
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Posted on Jul 14, 2010
SOURCE: Iron leaking and plate dirty
If you have hard water, there will be a buildup of minerals where the rubber gasket on the water tank meets the steam chamber that is built into the sole plate. This will make the rubber gasket surface become hard and no longer seak to the team chamber, resulting in water leaking from the tank onto the outside of the iron.
If you are reasonably skilled with tools and have a Torx T20 driver, you can disassemble the iron and remove the rubber gasket between the tank and the steam chamber and soak it in vinegar to remove the mineral scale. First remove the three Torx screws visible at the rear of the iron and gently pry off the gray rear cover plate. This will expose two screws holding the rear end of the sole plate. Remove those two screws. Then gently pry off the stainless steel nose piece on the front of the iron; this is the curved piece that says "high precision" on it. This will then expose the screw that holds the front of the sole plate on the handle. Remove thqt screw. Pull the black connector at the rear of the iron off the two rods to which it is attached, and you can move the sole plate away from the handle. The rubber piece in the handle that is sort of oval shaped and about 2 inches long is the gasket that is probably causing the leak. Gently remove it and soak it in vinegar to remove the scale, and remove the scle from the round hole where it meets the steam chamber in the sole plate. .When they are clean, reassemble the gasket onto the handle and the sole plate onto the handle, connecting the electrical connections, and replace the screws, It is not simple, but it is doable.
Posted on Jul 25, 2010
I have a oliso iron that is one year old. Just not turning on.pluged into socket
take it in to an appliance repair shop( possible cord problem) otherwise consider a new one as repairs past a cord are uneconomical to repair
Dec 10, 2016 | Oliso Irons
How can I clean the plate of my Oliso pro. It has wonder under on it
get the iron hot. Take a piece of fabric and a dryer sheet. Put the dryer sheet between two layers of fabric. Place this at the edge of your ironing board. With the iron hot, run the sole place over the "fabric/dryer sheet set" several times. This will remove wonder under and many other adhesives from your iron.
May 31, 2016 | Oliso Tg1600 1800 Watts Smart Iron Pro
My iron is leaking water. Can it be repaired? I picked it up off the ironing board today and it was sitting in a puddle of water. It continued to pour out the bottom. Is this fixable?
I have had several do this after many many years of use. I did not find a fix but ended up buying a new model. If you do not need to use the steam function, you can still use it. Might want to use a spray bottle with water to add the steam the old fashion way.
Jan 27, 2014 | Irons
Oliso iron will not give much steam, nor will it get hot even on the highest setting, only a few months old
It has a THERMAL PROBLEM SETTING!
If u said u just bought it a few months ago, it is still under warranty and u could bring that where u bought it and have them repair/replace it!
Dec 02, 2010 | Oliso TG-1000 Iron
Leaking where the base plate attaches to the upper portion of the iron thus causing all the water to eventually run out onto the iron board or item being ironed. I do not have original receipt or box but...
This is a leak on the seating of the body to the frame and it is possible that the seal is not tight. It can be tightened with the screw fittings inside the handle but if you can get warranty for the Iron it will be bettter than tampering within.
Now for the time being do not use water into the iron but have it dry and sprinkle from outside till you get confirmation from Walmart.
Sep 26, 2010 | Irons
Iron leaks , lift stuck in up position
heatman101
Jun 12, 2010 | Oliso TG1100 Iron with Auto Shutoff
Irons Logo
343 people viewed this question
Top Oliso Irons Experts
Andrew Taylor
Andrew Taylor
ray gallant
Bill Boyd
Are you an Oliso Iron Expert? Answer questions, earn points and help others
