Question about Coffee Makers & Espresso Machines
The machine has to be cleansed after two or three cups have been brewed or it won't brew anymore.why is this happening?
  • yadayada
    yadayada Dec 28, 2016
    What machine do we have here, does your water have a lot of minerals in it, IE hard water?
  • 25 Answers
SOURCE: Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
Posted on May 14, 2009
  • 34 Answers
SOURCE: Not brewing properly
I have a similar problem with my B70 Platinum brewer. The brewer was saying that it was "Brewing", but only dispensed a small amount of coffee and/or dispensed an incorrect amount of water. I called customer service and they told me that this is "short cupping" and walked me through resetting and descaling. After descaling three times, I had the same problem and called them back. I was told that I would receive a call from tech support on Monday, at the earliest, but I told them that it was unacceptable and that I would prefer to speak to someone today. I was put on hold and then spoke with someone who put in the order for a brand new brewer to be sent to me with an additional 1 year warranty.
First, try de-scaling your brewer at least two times and see what happens. If that doesn't resolve the problem, call customer service and be persistent. They will ask what kind of water you use (tell them you use bottled water, spring water, or filtered water) and some other questions. They will probably have technical service call you, so wait for the call (24-48 hours) and do what they say. If the problem isn't resolved, call customer service again! I placed a total of three calls to customer service and received one tech support call. They are very friendly and helpful. You are obviously going to be put on hold, so use a speaker phone, if possible, so you don't have to keep the phone up to your ear for 10 minutes or more, and just wait it out while watching TV or something.
Posted on Jan 09, 2010
  • 186 Answers
SOURCE: Coffee Maker only brews 1 cup at a time
Hello. I just talked to Cuisinart and they recomended running a solution of 1 part vinegar and 3 parts water through the brew cycle,then a full pot of plain water to rinse, to remove hard water deposits. The phone # to Cuisinart is 1-800-726-0190. I hope all works out for you.
builderdale
Posted on Jan 12, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: My keurig machine wasn't brewing a full cup so I
do another descale..add more vinegar....run the entire full tank of water....you must have a big buildup of scale...
Posted on Dec 18, 2010
  • 1089 Answers
SOURCE: I was cleaning the grinder
Hi
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. (You can insert your key into the hole in the front and twist the key to return the brew unit to the center. Line up the 2 diamonds and it centered) If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit,(it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must insert the drip tray and dredge drawer, close the door and turn on the machine without having the brew group in. Turn the machine on. You will hear the motor turn on and when it stops completely, open the door and remove the tray, now insert the brew group and replace the tray, and test.
Posted on Apr 06, 2011
Why cant I get a full cup of coffee
Brewing a Partial Cup
If the brewer is not brewing the full amount selected, it may be caused by the following:
  • The exit needle is clogged by coffee grounds or cocoa mix. Please refer to the K-Cup Holder cleaning instructions.
  • The brewer needs to be descaled. Please refer to the descaling instructions.
  • The removable water reservoir was removed during brewing. Place the water reservoir back onto the brewer and perform a cleansing brew without a K-Cup pack.
Jul 27, 2014 | Keurig B60 Coffee Maker
All lights are blinking on coffee maker & unable to brew.
The cups only brew one mug at a time. Open and close the lid to check if that resets itself.
Otherwise, turn the machine off and on again to "reset" the function. Also check that there is enough water
Nov 12, 2013 | Keurig Coffee Makers & Espresso Machines
Frigidaire 12 cup coffeemaker won't brew
Like the one i own, the heating /warming plate is bad and needs replacement. I have not been able to find one.
Nov 14, 2012 | Frigidaire Professional 12-Cup Coffeemaker...
Coffee maker will not make but one size cup
If your brewer is not brewing the full amount selected, it may be caused by the following:
  • The brewer may need to be de-scaled. Please refer to the de-scaling instructions.
  • The removable water reservoir was removed during brewing. Place the water reservoir back onto the brewer and perform a cleansing brew without a K-Cup.
First try to make a descale maybe repeat it the next day.
http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/FD69E91A51CA41BEBF4CCAA138325BBF.ashx
Jul 04, 2011 | Keurig B60 Coffee Maker
We have just descaled our Platinum unit and reset all the functions. When attempting to make a cup of coffee, it says it is brewing, but NOTHING is happening. What do we do?
Then try also this helpful tip
http://www.youtube.com/watch?v=DqRs4Ott21s
Jul 04, 2011 | Keurig Platinum B70 Coffee Maker
Slow brewing
The coffee maker has three contributory factors for brewing experiences. First, putting enough water in container prior to brewing is expected to dispense in to coffee capture cup. Second, installing the component parts after inserting coffee leaflets should not hinder brew seepage into the cup. Third, allowing enough time for the brew to dispense is a requisite means to coffee impressions. Furth, coffee leaflets require appropiate numbers inserted at the container area lest the machine takes time to sock and dispense. However, refer to the device user guide for appropiate manufacturers instructures to user as expectations during brewing. Also, refer to the user guide to ascertain any conditions that may be signs of damage preventing fast brewing.
Jan 22, 2011 | Oster HDX23 12-Cup Coffee Maker
I can't get a full cup of coffee. I've descaled my machine and it still doesn't work properly. Any other suggestions?
Jan 14, 2011 | Keurig B60 Coffee Maker
Coffee Makers & Espresso Machines Logo
27 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
