Question about Refrigerators
How or where I can register my refigerator - Refrigerators
Refigerator and Freezer not cooling
You might try cleaning all the dust if any from the back or access to the bottom front.
Feb 14, 2008 | KitchenAid Superba KSCS23IN Side by Side...
Hi I have a Whirlpool Refigerator and it drips water from the frezzer into the refigerator thru the two opening up in the back middle opening from the frezzer to the refigerator. It does this off and on
sounds like the drain live from freezer to outside is clogged. the water isnt making it you the condensate pan but coming out in the refrigerator. try finding and cleaning the drain line.
Mar 02, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a Kitchenaid KSCS20QFAL01 refrigerator. The freezer side gets cold but the refigerator side does not. The difuser has been replaced but did not solve the problem. It was working fine until the...
clean all the dust off the coils on the back of the fridge and all the dust out from underneath the fridge. This was the cause of my fridge not cooling and it worked and cost me to have somebody come out to blow all the dust out from underneath. Give it a try
Jul 24, 2010 | KitchenAid Refrigerators
The card with my refigerator is AMERICAN - so I
You can register Maytag/Whirlpool family US appliances here.
May 27, 2010 | Maytag MMV4205 Microwave Oven
EC light is on and AC does not work? Refigerant
Could be a bad compressor, or a plugged line. More detailed analisys of your car will be required
Jan 30, 2010 | 1996 Mercedes-Benz C-Class
Freezer is not freezing properly and the refigerator is not cold
You have a defrost problem. The fridge gets cold air from freezer, if ice blocking from no defrost, no fridge temperature.
Apr 26, 2009 | Kenmore Refrigerators
REFIGERATOR DOES WANT TO COOL DOWN
see if you hear a fan running in the freezer side pull the unit out on the right side about a foot up is a panel remove it and check the mother bd to see if any parts on the bd are burned if so replace the bd
May 09, 2008 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
