I've ordered a new remote for my tv, meanwhile I used the menu button, and have it on HDMI. But I can't get it back to reg TV.
SOURCE: I can't select TV/Video input on the menu
Prueba poniendo canal 00 en el tv varios modelos de rca entran en modo de auxiliar en este canal.
Posted on Mar 12, 2008
  • 476 Answers
SOURCE: I can't get my remote
It's unusual for these remotes to break down, but they often suffer from bent contacts in the battery slot.
When the battery is inserted with the tray, if makes contact with a spring terminal on the main board, and a spring terminal at the back of the battery.
First check that the replacement battery is the correct type. If the replacement is too fat, then the board spring has probably been flattened, otherwise the back spring has probably been pushed in.
Either way, its quite easy to fix.
Board Spring: using a thin wire, such as a paperclip or precision screwdriver. gently lift the two contacts from the back until they stay up from the board.
Back spring: using the same tool, hook into the loop on the contact, and gently pull forward.
This will ensure that proper contact is made when the battery is inserted.
Don't worry if you pull the contacts too far, because the battery will push them back.
In this case, remove the battery tray
Posted on Mar 14, 2008
jerryg50
  • 1689 Answers
SOURCE: Toshiba TV - 29 inch - model 2990 XEL
This may be a fault with the firmware (internal software for the uPC), or it may be a failure in the circuit area or chip that generates the fonts and characters for the menu display.
You will have to send the set for factory level service if this is the case. If you give the set to an independent service center, they may have to send the set out on your behalf.
I would be careful to not invest too much money in to servicing a TV of this generation.
Jerry G.
Posted on Jul 12, 2008
mistersony
  • 320 Answers
SOURCE: KDL-32XBR6
Try resetting the TV by holding down the "up" button on the remote (with the TV powered on) and then, while you hold down the up button on the remote, hit the power button on the TV. This should do a "factory reset" which will wipe all settings in the TV. There is no reason why the TV should not "remember the last input it was on when it was ;last turned off. Also be sure that the TV is not plugged into a switched AC outlet, like the outlet on the back of the cable bix. The TV should be plugged into an output that receives power at all times.
Posted on Oct 19, 2008
SOURCE: nu tec crt 54cm tv
the problem is the volume/sound
Posted on Nov 06, 2008
How do I hook up DVD player
Liz,, most DVD players come with RED, Yellow, White cables. on back of ur DVD player find the holes with the matching colors. and insert cables, now go to ur TV , on the back you should see some of the same colors plugins ,.once u have done that . put in a DVD and hit play. now go to the input/source button on ur TV or remote and push it . u might see a drop down menu if u do highlight the AV or Video 1 or 2 or 3 till u get a picture. when finished u will have to hit the input button and go Back to where u were in order to watch what u had it on before. NOW if u have a Blu Ray DVD player all u need is the HDMI cable , find the HDMI output onback of player and on the TV find the same. your tv might have 3 or so HDMI inputs ,, any will work. as before put in a movie, use ur remote , input button and find the HDMI on the menu and high light it. .
Jan 25, 2015 | Televison & Video
What should I do in order to get the sound to turn back on my Vizio VX20L TV?
Have you tried the user manual? There may be a setting in the menu indicating whether to use internal speakers or some other device run through say, a cable or HDMI output, or turn off sound for those using a cable input to the TV from say, a cable box, but the sound goes to a separate sound system.
Also check that there is sound coming INTO the unit from your cable box if you have one and use RCA cables. If using HDMI input, there may be a menu item as well, to control whether to use input or not, as some people will have the cable box send the sound to a sound system instead of the TV.
Oct 26, 2014 | Vizio VX20L 20 in. LCD TV
PC HDMI W4201C 42 CONNECTION
Hi Caleb,
To resolve this, please perform the following steps:
  • Turn off the TV and unplug the power cord
  • Connect the HDMI cable to the HDMI port of your laptop.
  • Connect the other end of the HDMI cable to the HDMI input on your HDTV
  • Connect your device using the HDMI connector (Refer to image below)
  • Plug in the power cords for the TV and Xbox
  • Turn on your TV and Xbox
  • Enter the TV Menu and select Setup (Refer to the image and steps mentioned below)
  • To enter the TV Menu, press the Menu button on Remote control
  • Use the left and right buttons (volume buttons) to move between the icons
Select correct input source
  • Input allows you to select the proper source based on how you have your TV and video equipment connected.
  • Press Input on the remote to go directly to the Input Select menu
  • Select HDMI 1 or HDMI 2 (Refer to image below)
If the TV does not work, please follow these steps:
Verify the PIP/POP/PBP function is disabled ( PIP/POP/PBP Compatibility - The only input sources that cannot work together are HDMI with HDMI)
  • Press the Menu button on the remote control or TV
  • Use the Left and Right arrow buttons (Vol +/-) to select PIP/POP/PBP, and then press <Enter>
  • Use the Up and Down arrow buttons (Ch Up/Ch Down) to select PIP/POP/PBP/OFF
  • Use the Left and Right arrow buttons to select Off
If issue is still persists, please move to the next step
Reset the TV current input to its default configuration
  • Use the left and right arrow buttons to select Setup, and then press Enter/OK
  • Use the Up and Down arrow buttons to select Factory Reset, and then press Enter/OK
  • Select Current Input Setting and press Enter/OK
  • Re-check the TV functionality
Feb 19, 2014 | Dell W4201C 42 in. Plasma HDTV
How to find source for model WS-28W63N without the remote control
Sometimes you can unplug the hdmi cable and power off the tv and unplug power to tv wait 10 sec plug tv back in and then insert hdmi cable. Some of the newer tvs will auto tune to the input if that dont work, try getting a universal remote program the remote to control tv if you can control tv volume, power , menu then you should be able to navigate to the input menu and select hdmi that way
Jan 13, 2013 | Samsung TV Remote Control
Apple tv to optical audio on avr 1601
You need to assign the optical input to the video input you are using. It's under the 'Input Setup' menu.
Or use HDMI, it will output the audio thru the HDMI connection. Once again assign the input under the Input Setup menu (press the Menu button on remote to access setup menus)
Nov 19, 2011 | Denon AVR-1601 Receiver
Tv won't switch to "tv"
Your T.V. is programmed to store the last input you've selected. You have to manually switch it back to your T.V. channel input after each time you switch it to HDMI or any other input even when you turn it off. The "Source" or "Input" button on your original T.V. remote will change this.
Jun 24, 2011 | Vizio 42 in. LCD TV
Can't get the menus to show up
Try to reset tv by unluging it first ,if that does nothing turn off tv press and hold down the input button in the front then press and release the pwr button the service menu should appear. also tv can't be in the HDMI mode. DON'Tpush any more buttons and unplug the tv if that don"t work there is a problem in the video circuitry with the character generator.
Jan 09, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Help!
Try pressing the HDMI button on your remote a couple of times, pause about 5seconds after each press it might be slow to change. If this doesn't work try connecting just the yellow lead(composite video) into the DVD player to the TV like the old days, probably AV1 or AV2 in the back of the TV. Then access the setup menu(setup button on remote). This will bring up a menu. Use the down arrow on the remote until HDMI setup is highlighted. You should then get a selection to turn HDMI on and select the different outputs(576, 720p, or 1080i). You might actually find the picture to be worse on some DVDs.
Apr 06, 2008 | Televison & Video
Hdmi
Bring up the "service" menu, put the TV in standby mode, then press in sequence :
Onscreen Display ( the little screen with the i+ in it )
5 ( channel number 5 )
Volume Up ( upper end of volume button )
Analogue ( middle top button )
The TV should switch on and when it's warmed up, you should see a screen with lots of big green lettering on it.
Press the "menu" button ( middle bottom )
Use the direction dial to move down to "LCD Drivers" and press right on the dial to enter this menu.
Move down to "S H Pos Reg R". It should be "10", change it to "11". ( Left/Right to adjust )
Move down to "S H Pos Reg G". It should be "10", change it to "11".
Move down to "S H Pos Reg B". It should be "10", change it to "11".
Press the menu bottom to drop out of the menus, and the standby button to drop to standby. Switch back on, and hopefully your ghosting will be gone.
Nov 15, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
