Question about The Audio Players & Recorders
My headphones are just giving off a red light on the right speaker with the volume buttons and everything else. I was trying to connect to my computer and they had worked before on my laptop.
Open SKy
  • 620 Answers
SOURCE: Using headphones with Logitech X-230 speakers
Hi FOG-57
Happy HOlidays!
well, if volume is fixed, you have to see if in the control program for sound, you can disable and use the headphone sound program in windows.
good luck
Posted on Dec 26, 2007
Posted on Sep 19, 2008
SOURCE: Strange problems with Z-2300's
I'm having this same problem and have sort of solved it with a really wierd technique I found at Logitech. Evidently this problem is related to the control pod rather then the RCA jack. Try this:
Unplug the control pod from the subwoofer Turn off the main switch Turn the volume knob one full turn, tap the knob Repeat again (2 times) Replug the control pod Turn on the main switch and the control pod See what happens
I found that this got the speaker working finicky after it was almost totally useless. It seems to be cutting out randomly, but fidgeting with the control pod or it's connector jack fixes it. No clue what the deal is here, but your problem is identical to mine so take some time to screw around with these components with music running so you can hear if it suddenly works.
Posted on Jan 24, 2009
SOURCE: hp dv 7-1135nr speaker won't work, headphones do
I suddenly got the same problem on my dv4-1120us today.. However by updating the audio driver to this one it started working again:
You better take a look at HP's website.. maybe you will need a slightly different driver, since your computer is not exactly the same as mine. I'm sure the sound card is the same, but better safe than sorry. good luck!
Posted on Feb 26, 2009
  • 368 Answers
SOURCE: Volume only works with headphones in
Hi pujak,
The little red "null" symbol you describe indicates you've got the "Mute" turned on (bypassed by headphones). Either go into System Preferenced/Sound and adjust that, or use the F3 or F4 keys (it's F3 on my MacBookPro) to toggel it on/off.
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using,
Posted on Apr 04, 2009
Macbook pro headphone audio
Go in to the "applications>utilities" folder. Run the "Audio/MIDI Setup" program. Insure the audio out is actually going to the headphone out.
Mar 21, 2013 | Apple Computers & Internet
Be sure to plug it into the green socket on your laptop, or the socket with a headphone symbol. Do you see a light indicating the speakers are turned on?
You could also check if the input you are using for the speakers is muted or at a low volume. If you double click on the speaker symbol on the lower right hand side of your screen you should have a window open giving you a list of sliders to change audio volume.
Do other things like headphones work when plugged into the computer? If so the speakers you are using could be faulty.
Aug 23, 2011 | Computers & Internet
I have a LG 19LE3300 television and i whant to be able to connect an Infra red headphone while being able to listen by the speakers at the same time. actually when i connect the hearphone it disconnect...
First you need to make a test to adjust your headphones wireless system..
.pls follow the step below:
  • "Connect the headphone base" TO " headphones output of TV" with 3.5mm stereo headphone jack cable (than Tv should mute ) Infra red headphone pilot lamp should flicker in parallel to voice coming from TV
  • Infra red headphone should have a rotary adjustment on it.. "Volume" adjustment
  • while TV talking , when you sit in front of the Infra red headphone (it works point-to-point ) you will hear the voice of TV, than adjust volume properly...Thats lets go to second step..
  • Your headphone's Base should either "3.5mm stereo headphone jack" or "RCA Stereo jacks" or "bot"h..After completion of this test ,I recommend you to switch / use "RCA Audio output plugs-white/Red cable " on the back of TV instead of TV's headphone output ,since it mutes the whole sound..RCA output plugs of TV work independently from the TV's master volume control..of course you need RCA cable to connect this..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | Televison & Video
I JUST bought a insignia speaker 2.1 (model # NS-PCS21) and the speaker plug ins are pluged right, power are plug in, the green and the red cord plugged in... i see blue light comming up. my computer sound...
Greetings - The setup (as you already know) is simple. If you have the a/c adapter plugged in, the power on and the green speaker cable in the audio out at the back of your PC and and the red cable plugged into the subwoofer and the volume knob on the the right speaker turned up that's all it takes.
The one possible gotcha I can see is if you have something plugged into the jack at the BACK of the right speaker (an AUX jack for things like MP3 players, etc.) it will override everything else.
If that's all good you have a bad set of speakers.
May 30, 2011 | Insignia 2.1 Speaker System (3-Piece)
My view sonic monitor has no sound
Troubleshooting Sound Issues Verify that the audio cable is connected to the AUDIO OUT or LINE OUT output on the Sound Card and plugged into the AUDIO IN or LINE IN of the Monitor.   Make sure there are no cables connected to the Headphone Jack (located next to the AUDIO IN port) on the monitor. If there is, please disconnect that cable and try the speakers again. Connecting a cable to the Headphone Jack disables the speakers. If there is no cable connected into the Headphone Jack, test a pair of headphones into that jack to see if you can hear sound out of the headphones. If you are able to hear sound out of the headphones, disconnect the headphones and try the speakers again.   Verify that the Mute on the monitor is not on or the Volume is not turned down.    Verify that the Mute on the computer is not on or the Volume is not turned down.<    If there is still no audio from the monitor's speakers, connect the Audio cable to another audio source like a portable CD player or tape player headphone output. If audio can be heard through the monitor's speakers, then there may be an issue with the computers sound card.    Connect another set of computer speakers (if available) or headphones to the AUDIO OUT or LINE OUT output on the Sound Card. If NO audio can be heard then there is an issue with the sound card. Verify with the computer's manufacturer for additional assistance.   LCD TVs Troubleshooting No Sound from a LCD TV No Sound when using RGB (when connected to a PC) Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the computer. Note: On the N1700W use the GREEN mini-jack; on this model Audio is SHARED between DVI and RGB, there is only 1 audio channel for data connections. The N1700w is designed to take a 1.0v RMS audio signal for optimal sound quality.   Confirm that both the LCD TV Mute and Windows Mute are off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the monitor or remote to confirm the Volume is not set to zero.   Confirm that PC volume is sufficient by using Windows/Macintosh Volume adjustment settings.   Try plugging another audio source such as a CD or Cassette Player directly into the Audio port on the LCD TV to confirm the speakers work, or try plugging headphones or external speakers into the sound card on the Computer. If the Headphones or External Speakers do not work, contact the manufacturer of your Computer for further support. No Sound when using S-Video/Composite/ Component Video Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the S-Video, Composite, or Component Video device.   Confirm Mute is off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the LCD TV or Remote to confirm the Volume is not set to zero.   Try plugging headphones or external speakers into the audio port on the S-Video, Composite, or Component Video device. If the Headphones or External Speakers do not work, contact the manufacturer of your S-Video, Composite, or Component Video device.   Note: Some ViewSonic monitors do not include speakers.
Nov 23, 2010 | ViewSonic E70f 17" CRT Monitor
I have some multi speakers but the volume not coming out
You don't give me much to go on so here is everything that I can think of:
Remember that there are two volume settings. The volume knob on the speakers and the volume in the computer. Make sure the speaker and computer volume is up and Mute is off.
Make sure the speakers have power. Most of them have a light to show that they are on.
Make sure the speakers are plugged into the the right port on the computer. The audio out port is usually color-coded green.
You can plug a pair of headphones into the computers audio port to see if they work. This will tell you if the problem is with the computer or the speakers. (Don't put the headphones on for this test, the sound might be very loud.)
The last thing would be if a sound driver is not installed on your computer. If you have a sound driver there is usually a small speaker icon next to your clock. No speaker icon and you may need a driver. You can download a sound/audio driver from your computer manufacturer's website.
I hope this helps.
Jan 29, 2010 | Computers & Internet
Green light on speakers and sub. No sound - only hissing noise
open volume control & remove check from mute button.
start-program-acessories-entertainment-volume control.
Sep 17, 2009 | Audio Players & Recorders
Speaker volume is not audible
if the speaker system is set up right , then it could be a problem with your audio def`s go to either (if your using windows) volume controll panel , or realtek controll panel and make sure its all set right .
to make sure your speakers are ok , just plug them to an mp3 player or something and see if everything is cool.
good luck!
Jul 29, 2009 | Altec Lansing ATP 3W Computer Speakers
MacBook Sound Problems
This also happened to me after unplugging some headphones. After reading this, I opted for putting the headphones back in instead of a toothpick. This fixed it.
Sep 11, 2008 | Apple Mac/iMac&iPod Speakers-(Bondie-Blue)...
I really don't know, because some of the newer gadgets come with fixed volume control due to law suits, ect. Try to see if you can bring you TV menu up and see what the sound setting is.
Dec 25, 2007 | Logitech X-230 Computer Speakers
37 people viewed this question
Top The Audio Players & Recorders Experts
Jose Ma DM.
Jose Ma DM.
Level 1 Expert
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
