Question about Refrigerators
Show to set temp
Frig is running but not getting cold
  • 1073 Answers
SOURCE: Constantly runs and what is the normal frig. temp?
37-39 sounds like a problem check the freeezer coil for frost buildup
Posted on May 17, 2008
  • 89 Answers
SOURCE: Frig is not getting cold!
How did you transport refrigerator? Standing straight up, or laying on its side???
Posted on Jul 14, 2008
  • 149 Answers
SOURCE: hotpoint frig,top freezer
niether. is there frost on back wall of freezer? if no look behind back wall and see if there is frost on all the coils when running. if less than 80% is frosty...freon. or is there frost covering back panel..if so then defrost problem would be correct. but side would be warm so I think not.
Posted on Jun 12, 2009
SOURCE: Frig gets too cold freezer works good
I had the same problem. I have the side by side Profile Artica. The problem was a broken damper. It allows the cold air in from the freezer side. With it broken, there was a steady flow of freezer air coming into the frig side. It was easy to fix. I ordered the part (damper/fan assemble) for around $100. While searching for a solution, it seems that this is a common problem. Unfortunately, I received a wide range of incorrect solutions to the problem which could have cost me a lot of money. I hope this helps!
Posted on Aug 03, 2009
  • 3361 Answers
SOURCE: Refrigerator keeps running
Your cold control(thermostat) is bad.
Posted on Jul 27, 2010
Freezer not cold enough
setting the freezer at 7 opens the baffle from the freezer to the fridge to make the fridge colder. It works completely opposite than a person would think. Feel in the back of the fridge with it on this setting. The freezer is dumping all its cold air into the fridge thus equalizing the two parts. if you move the selector to 1, you should feel the air from the freezer cut off in the fresh food compartment. try a setting in the middle and let sit for 24 hours. Hope this helps
Jan 25, 2012 | Amana Refrigerators
Freezer fan stays on constantly. temps ok in both sides. will this cost much more electricity and should i really worry about it.
If the freezer fan is running constantly, and things aren't too cold in either section, it means the frig thinks its not cold enough to shut off, so it runs trying to get to the proper temp. you have control set at. Check for any frost buildup on freezers back panel inside freezer. If there is you have a defrost problem.
Oct 01, 2011 | Hotpoint HSS25GFP Side by Side...
My refrigerater is getting to cold i have the the temp at the factory setting of 37 but it is going down to 28
hi there is a damper on the refrigerator side that goes bad. and stays open lets to much cold air in frig. it in the top of frig running from lift to middle pull it out unplug replace jim
Oct 13, 2010 | GE Profile PSW26P Stainless Steel Side by...
Refrigerator keeps running The compressor is not shutting off regardless of how cold it gets. If the temp is set at 35 for the frig and 0 for the freezer, the compressor keeps running even when the temp...
your cold-control that you adjust has gone out,be it dial adjust or electronic unplug the dial one and see it will shut down,be careful on unplugging on an electronically controlled unit as you can ruin the control board if not powered down before board is unplugged
Jul 27, 2010 | GE Refrigerators
Whirlpool frig. Freezer warm, frig seems ok.
Since the temperature is already 40°, the cold control is satisfied and will not run. Thus the freezer will warm up to 40°.
Jan 06, 2010 | Refrigerators
Upper freezer temp. alright Lower refrigerator to
Sounds like the airflow balance is off. When you turn the aircontrol to max what you are actually doing is starving the frig compartment of cold air, cold freezer, warmer frig. It is recommended to set both controls to middle and see if it helps the problem.
Jul 30, 2009 | Whirlpool Refrigerators
We have a LG Two Side Fridge.
Look for the air ciculation regulator sliding vent between frig & freezer section open accordingly. Set both sides to #3 on dials if frig not cooling to less than 40 degrees, might need new cold/temp controller behind frig dial
Apr 30, 2009 | LG LRSC21934 Side by Side Refrigerator
I have a Kenmore coldspot side by side- not cooling properly
Setting it to 5 is what the manufacturer recommends. If you set it to 1 and the frig is still not cold, then you probably have a faulty cold control (thermostat)
Feb 19, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Everything in frig is frozen and it won't turn off.
If the compressor is running non-stop then the temp. control is not telling it that it's "cold enough". If the compressor isn't running non-stop then you should look at the air damper (little window) that lets the freezer air into the refer compartment... if it's stuck open then you will always get cold air pushed into the fridge eventually becoming a freezer in itself.
Jan 17, 2007 | Kenmore 74844 / 74842 Top Freezer...
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
