Question about Dacor Coffee Makers & Espresso Machines
I have a Dacor CM24-P. When I turn it says Machine Off - Boiler Filling. It never fills or changes display. Suggestions?
SOURCE: Saeco Primea Cappuccino Ring--stuck on "boiler filling" mode!
Hello, I had the same problem, therefore the machine has gone to a repair centre. The problem is caused by a mechanical switch in the machine, that doesn't work properly. To repair it you've to open the machine completely, but that’s not easy. Because there is nothing broken you’ll should have warranty because it is a production failure. The solution in my case was to heat up the switch and push it a little together so that the contact works properly. It is the switch that you hear when you turn on the machine.
Posted on Oct 30, 2008
  • 8 Answers
SOURCE: Push ok to start boiler
Try opening the steam valve before pressing ok.
This will let water into the boiler before the heat element comes on.
Posted on Jun 24, 2009
EsWorld
  • 1618 Answers
SOURCE: no barometric pressure
Check the reset thermostat located on the right side of the machine just above the element, you will see 2 electrical brown wires going to it and a red push pin, make sure machine is OFF and not connected to the Mains, press reset you will hear the click. Plug machine in, turn on and open steam valve.
Posted on Apr 17, 2010
  • 81 Answers
SOURCE: I purchased this machine only
In the water tank there is a float with magnet inside. When water is filled it should rise up to indicate the machine has water.If it is not floating up ,try putting some foam underneath to raise up.It should help.
Posted on Oct 18, 2010
EsWorld
  • 1618 Answers
SOURCE: a2 just trying to
Either the level probe does is not functioning properly, or the solenoid for the autofill valve is not working or the Cpu board relay is not telling the auto fill solenoid to turn off or the valve seats in the inlet valve are damaged.
Posted on Apr 25, 2011
Sir, LA CIMBALI 39 DOASTAROM 3 GROUP MACHINE MOTHER BOARD BROKEN Sir, We try to install the new mother board, most of the things are working, the boiler is heating up, but when we turned on the...
hi. Im not sure excactly what is going on with your explaination about your machine, but I gather the the original mother board has died, and you have replaced it with a new one. It sounds like you have a water fill issue with your machine. If the boiler doesn't have enough water in it, then the pc board will shut the machine down. Ive never worked on a m39, but they are from the Faema corporation, and Faema/ La Cimbali electronics canbe very complicated. Dont now why they make such complicated electrics, cause there are hundreds of other brands with simple electrics.
If your boiler was empty, then the water fill cycle might be a timed cycle, and is shuting down before the water level has reached the water level probe inside the boiler. If this is the case, then once it has stopped, turn the machine off, wait 10sec, then turn it back on again and let it start the fill cycle over. You may have to repeat this a number of times until it has reached the water level probe inside the boiler. Some machines are designed to have a slow water fill, because when you draw hot water from the boiler for making tea, fresh cold water is pumped back into the boiler to replace what you have taken out, and if it fills too quick, then your steam pressure drops. So by filling slower, the machine will maintain its steam pressure. Good idea in theroy, but its only good for cafes that do 300 coffees per hour.
Im hoping that your machine is configered this way, cause it will probably just have to be turned on a few times until it has reached the water level probe as I explined in the begining. If you have a sight glass, you can check to see how high your water level is. If your level is correct, and its still not working right, then id recomend calling a repairer. There are number of things that could be wrong, causing your board to die. Faulty solenoids. switches, touch pads, pressure switches can cause main board issues. Hope all this helps with getting your machine working properly. Dazza Repairer
Oct 23, 2011 | Espresso RMI La Cimbali Espresso Machine
No barometric pressure
Apr 17, 2010 | Nuova Simonelli Premier Maxi Espresso...
I have had 2 la marzocco lineas where the steam boiler heating elements burst. the first machine was a bit of a frankenstein and I thought it might be a wiring problem since I kept replacing the element...
For the element to burst, the machine has to be devoid of water, Do you have a reset thermostat on the steam boiler, if no then it would be wist to get one put in to protect the element. Next, check the flow from the filter, is it restricted, if it is find out from which cartridge and replace. Next, the level probe might be set too low, lift the probe another 1/2 to 1 inch. Remove the safety valve, turn the machine to 1(fill) and lift the probe so that the water level is above the element. If the machine does not have off-fill-on(3 position switch) then that could be the brunt of your problems. Next make sure the inlet solenoid is filling the machine, you will know be removing the wire on the probe and the machine will start filling.
Dec 30, 2009 | La Marzocco Linea Series Group 3 Espresso...
Astoria double overfills with water
The machine froze at some point, one of the exchangers are busted, you will havew to replace the exchangers or the boiler depending on the model.
May 11, 2009 | Krups Small Appliances Espresso Machine
Apr 23, 2009 | Saeco Incanto Classic Espresso Machine
Nuova Simonelli Mac 2000 - Boiler continues to fill up
I had the same problem of the boiler filling up all the way with water and the water was coming out of every hole in the machine. Turn the machine off, drain the boiler completely,
MAKE SURE VALVE #2 is CLOSED, this is the one under the drip pan all the way to the left. Turn on the water supply to the system and turn the system ON. The cup warmer on top will come on and stay on for anywhere between 10 to 20 minutes..... let it be,,, do not turn it OFF,, it will go off automatically. That should do it!
Hratch
Jan 21, 2009 | Nuova Simonelli Mac 2000 Espresso Machine
Oct 29, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Repressurizing my boiler
take your pick from video or text
How to Repressurise a Heating System with an Internal Filling Key ...
? 3:30
https://www.youtube.com/watch?v=zUsBw1ZpiKY
Oct 27, 2010 - Uploaded by Worcester, Bosch Group
This video shows you how to repressurise your heating system using your Greenstar gas boiler's internal ...
Repressurise Worcester boiler - YouTube
? 4:12
https://www.youtube.com/watch?v=K6fH4XfGgxo Nov 10, 2012 - Uploaded by Rory Macfarlane
This video demonstrates how to repressurise a Worcester combi boiler on the.
Product Troubleshooting Videos ' Worcester, Bosch Group
https://www.worcester-bosch.co.uk > Support > Troubleshooting > Videos How to repressurise a heating system with an internal filling key ... how to repressurise your heating system using your Greenstar gas boiler's internal filling key.
How to top your Worcester combi boiler up - Gas Care.
www.gascare-heating.co.uk/topping-pressure-worcester-bosch-combination-boiler/ Aug 4, 2014 - If the needle on the pressure gauge on your boiler has gone into the red or down to zero it means there is little or no pressure left in the heating system and it needs to be topped up ASAP. So here's Gas Care Swansea's guide to refilling your Worcester Bosch combination boiler through the internal filling link.
How do I re-pressurise my Worcester Bosch boiler? - My Plumber
www.my-plumber.co.uk/blog/how-do-i-re-pressurise-my-worcester-bosch-boiler/ Sep 1, 2015 - 6) Check the pressure on the pressure gauge. When it reaches between 1 and 1.5 bar, it is time to turn the white knob back to the right to close the valve. Be very careful not to over-tighten. 7) Turn the filling key to the left until the arrow lines up with the open padlock and remove the key.
May 12, 2017 | Heating & Cooling
Water leaking into machine
This happens when the boiler develops a leak, usually due to scale buildup. Order a new boiler and o-rings and replace.
Sep 29, 2007 | Saeco Magic De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
42 people viewed this question
Top Dacor Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Michael Vincent Cruz
Tom Chichester
Are you a Dacor Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
