Question about Brother Sewing Machines
Brother sewing machine feed dogs not coming back up?
Bought at Costco, used lever to lower and now they won't come back up. I noticed there is a solid piece that might/should be attached to the feed dog lever inside and it is not. Is this fixable? Can I fix it or does it need to be taken in for repair? Is it worth fixing?
  • Brother Master
  • 11,493 Answers
Difficult to say--you didn't provide the model. It could still be covered under warranty depending on when it was purchased. If not, service could run $50 possibly to ~$125 plus any parts(?) required.
You can also try contacting Brother support.
Also, have you tried stitching with it? On a lot of machines, the feed dogs don't come up until the machine starts sewing again.
Posted on Dec 28, 2016
How to lower feed dogs
Ther is a lever on the left at the back of sewing machine. Press to the right to lower the feed dogs. press to the left to bring them back up.Make sure they are in the 'up' position before sewing. My machine is a Brother 420.
Sep 19, 2017 | Sewing Machines
The driver on my brother ls2125i won't move when trying to sew
If you are referring to fabric not feeding through...make sure the feed dogs were not accidentally lowered. There should be a switch/lever to raise and lower feed dogs. May have to remove extension tray/table to have access to switch. NOTE: even if switch is moved, the hand wheel will have to be rotated at least 1/4 a turn before results from switch selection becomes "active".
Nov 22, 2016 | Brother LS2125i Sewing Machine
Janome 3050 feed dogs wont come back up
Dropping the Feed Dog
The feed dog can be lowered with the drop-feed lever for sewing on buttons etc.
  • Shift the drop-feed lever to the right to lower the feed dog.
  • Shift the lever to the left to raise the feed dog, it will return to the up position when the machine is started.
NOTE:The feed dog should be in the up position for regular sewing. Turn the handwheel toward you to check if the feed dog comes up after setting the lever in the up position
JANOME DC 3050 User Manual Page 9
May 24, 2015 | Janome Sewing Machines
How do I lower the feed dog on a Brother LX3125?
Look on the back of the machine near the feed dogs for a lever to lower them.
If there is none then you need a feed dog cover (or darning plate) that goes over the needle plate.
good luck!
Feb 23, 2015 | Brother LX3125 Sewing Machine
How do I fix the dogs when they won't feed the fabric?
The feed dogs on that machine (and many others) do not go back up when you move the feed dog drop button to up; they return to the up (feeding) position after the machine makes a stitch or two. So if they won't come back up after you tinkered with them, you will now need to bring it in for servicing.
May 14, 2014 | Brother XR7700
Kenmore sewing machine feed dog
Probably it is the spring loaded cam on the lower shaft not moving as it is bound up. The feed drop lever pushes it to the left to lower the feed dogs, but it has to spring back on its own after you move the lever back.
If you can remove the lower free arm cover you may be able to work it loose. Do not use 3 in 1 oil as it is gummy. Better to get Lilly white sewing machine oil.
Hope that helps!
Mar 12, 2014 | Sewing Machines
Does XL5340 have drop feed dog lever?
Look on the back of the machine for a slide-type switch near the sewing area.
Aug 22, 2012 | Brother XL-5340 Mechanical Sewing Machine
My feed dogs will not come up into position
Some machines have to take a stitch for the mechanism to "pop" back into place, I don't really know if your brother is like that but try to sew with it and see if they click back into place.
Oct 22, 2009 | Brother Sewing Machines
Feed dogs do not come back up after lowering
Are you talking about the feed dogs or the presser foot. Either way, if you moved a lever to lower them, there is probably a screw that either fell out or has become loose that holds the linkage to the lever.
Jan 02, 2009 | New Home Sewing Machines
Are feed dogs supposed to be up or down w/ embriodery unit?
The embroidery carriage automatically lowers the feed dogs when put in place
Dec 01, 2008 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
35 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
