Question about Health & Beauty
I have an old Kay Acoustic #L65266836 and N-3 stamped in the body. Is it made in 1936? Maybe a KG-31? Thanks!
My girlfriend gave me her grandfather's old KAY acoustic guitar. Try to fig out date it was made but having NO luck whatsoever. Inside numbers read.. L1256 6858
it was either the 12th guitar of this model out of the factory in 1956, or 68th in 1958. its more likely the first.
Apr 21, 2015 | Kay Music
How do I check a 1936 Ford starter armature for shorted or open segments?
Use an ohm meter and attach one lead to the armature connection and then ground the other lead to the armature body
Sep 16, 2014 | Ford Cars & Trucks
I have an old Kay arch top F hole acoustic guitar in good condition. Can you tell me when it was made and its value ?
There is no way to get exact year unfortunately approximate is best one can do. without photos even harder. but they were popular in 50's to early 60's
Sep 11, 2014 | Music
Siemens KG 36 NVL 31 Manual
manual at below link
http://www.mediafire.com/view/2yjlpgxlf6glj56/90008289454.pdf
May 25, 2014 | Siemens Refrigerators
ERr
Are you talking 31 "Stone"? If so, I believe that comes out to 434lbs. You are lucky if your scales can read that high. For testing purposes, remove your shoes or more if you think your right at the upper limit. Or let a slightly lighter friend try it. I assume your talking "Stone" as used in the UK. Are you from there? (I,m in the US, in Florida.) Also, there should be a switch on the bottom of the scale (upper left corner) allowing you to switch between lbs, st and kg. You can try that as well, although the limit should be basically identical. If you tell me more, I can help you more.
(By the way, I weigh 197 lbs right now, that's 14 stone.)
May 19, 2013 | Health & Beauty
Can i use mary kay time body targeted action toning lotion on my face
NO! Time wise toning lotion is only for your body. If you want something for your face use Time wise 3 in 1 cleanser or Replenishing Serum+C. Or much better Ask your Independent Beauty consultant for more information.
Apr 07, 2011 | Mary Kay Time Wise Targeted Action Toning...
No! use Replenishing Serum + C to tone your skin on your face.. or ask your Mary Kay Independent Beauty consultant for more details or check out this site. http://www.marykay.com.ph/mkpweb08/Products/product_cat.asp?id=skincare
Apr 07, 2011 | Mary Kay Timewise Body Toning Lotion plus
Doing a physics problem and when dividing i am getting wrong exponents coming up as E16 when should be E4
In scientific problems the powers of 10 are the easiest thing to handle if you keep in mind two or three rules.
  1. 1/10^(a) = 10^(-a)
  2. (10^a)*(10^b) = 10^(a+b)
  3. (10^a)/(10^b) = 10^(a-b)
  4. (10^a)^b=10^(a*b)
Example : suppose you want to calculate the charge to mass ratio of the electon
m_e= 9.109534 E-31 kg
q_e=1.6021892 E-19 C
q_e/m_e= (1.6021892/9.109534)* (E-19)*(E 31) C/kg
q_e/m_e= (1.6021892/9.109534)* (E 31-19) C/kg
q_e/m_e= (1.758804786 E-1)* (E 12) C/kg
q_e/m_e= 1.7588048 E 11 C/kg
If you just use your calculator to operate on the mantissas (multiplications and divisions) and handle the powers of 10 by hand, you will make fewer errors, especially if you are not confident in your mastery of the calculator as regards exponents.
Anyway, if you could give us a sample of the divisions you are performing, we might be able to help you. Post a comment to this thread and we will take it from there.
Feb 18, 2010 | Texas Instruments TI-84 Plus Calculator
35 year-old guitar,curious to know approx. what it's worth$?
Search for a like item on eBay in both live and completed auctions to find the value.
One site says about $330
Feb 02, 2010 | Washburn D10sbc Acoustic Guitar
Health & Beauty Logo
52 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
