Question about Saws
I am looking for a manual for a phillips 437 turn table. I need to replace the belt. Any help would be appreciated
  • Saws Master
  • 1,828 Answers
Philips 437 turntable
You could try the Philips website. They might have a free PDF of it!
Sep 09, 2013 | Philips Audio Players & Recorders
The belt came off my turn table and I can't figure out how to get it back on
Depending on your skill level this could be easy or a bit difficult. You will need a couple of screw drivers (phillips) and a long paperclip with one end bent into a semi circle hook.
If you feel comfortable with this, let me know and I can get you further.
Mar 21, 2013 | Audio Players & Recorders
Need cods for a universal remot to a zenith tv
  1. Manually turn on the tv.
  2. Hold code search button until the red light stays on.
  3. Press and release TV button-the light should blink
  4. Enter one of the following codes: Phillips Universal remote Codes-713 502 606 409 710 701 507 714 405 712 015 916 008 002 115 224 324 126 326 826 228 430 632 435 437 903 407 OneForAll Codes- 0017 0463 0178 009 With a valid code entry, the light should turn off.
  5. Press channel up button. If the tv responds, the code worked.
If some functions (like mute or menu) dont do what they should, try a different code.
Good luck.
Sep 28, 2011 | Zenith C27A24T 27" TV
I need the codes for a phillips universal remote to control a toshiba TV.
  4. Enter one of the following codes:517 419 512 613 719 112 506 111 618 627 437 041 891 802 111 313 715 With a valid code entry, the light should turn off.
Good luck.
Sep 28, 2011 | Televison & Video
I recently changed the battery on my casio 437 watch and now it won't turn on
There is a 437 stamped into the back of the case for one of the two versions (437 and 438) of Casio WR watches, with the 437 being the kind with raised rubbery number buttons. The model no. for the 437, also on the back case is CA-53W, useful for ordering parts (see below). These instructions are for the 437 but should be useful in many cases for other Casio watches, with numbers other than 437 or 438 on the back of the case. For example, the resetting process described in step 5 below appears to be common to many if not all Casio watches. There is no manual on the casio.com website for many watches, including the 437 and 438. There are no instructions for changing the watch battery in the manual for the 437 or 438 either, nor for many if not all Casio watches. If there is a 438 stamped on the back of the case, the chip is the same as on the 437. The buttons on the face of the 438 watch are flat plastic rather than raised and rubbery. The two buttons near the top serve the same function on the 438 watch as the right side buttons on the 437. The left top button on the 438 corresponds to the top right side of case nonindented button on the 437. The right top button on the 438 corresponds to the bottom right side of case lower indented button on the 437. Save time and money by replacing the battery yourself If you send your Casio watch off to have the battery replaced, it will likely cost you about $30 USD. Many jewelers will routinely send a Casio watch off for battery replacement rather than replace the battery themselves, so these instructions may help save you from delays and expense if you do it yourself. Likewise, jewelers may find these instructions useful for satisfying customers by replacing the battery on the spot rather than having to send the watch off to Casio. Materials needed a. 5/64" Phillips head screwdriver (A set of different size screwdrivers in a small black plastic case, including the 5/64" was bought for $1 USD at a local Dollar Tree store in the USA.) b. Watch battery identically numbered to the dead battery on the watch (2016 on 437 case back number) c. Metal tweezers to reset the watch d. Sil glyde gel grease or any other grease, to maintain water resistance f. Toothpick or similar to spread grease in O ring slot g. Ziplock plastic bag or bowl to hold the 4 small screws so they don't get lost Instructions on replacing the battery and resetting the watch 1. Take off 4 back screws, using the 5/64" Phillips head screwdriver. One screw was balky and needed to have the screwdriver handle attached to a vise grip pliars, with the watch held in the other hand and rotated. Putting the screwdriver handle in a vise would also work to stabilize the screwdriver, while turning the watch held in one hand. Set the 4 small screws aside in a ziplock bag or bowl. 2. Remove the red cellophane cover on the battery, held by two tabs cut into the cellophane fitting into a slot on the metal hold down battery strap atop the battery. 3. With a fingernail or toothpick (nothing metal), slide the battery to the side, out from under the metal hold down strap atop the battery. 4. Insert new battery with fingers/fingernails, sliding it into place from the side. The side, with the battery number showing (2016 on 437 case back number) faces outward, just as on the removed battery before it came out. The watch will continue to appear dead, with nothing showing on the display until the electronics are reset in step 5. 5. Reset the electronics by using a pair of metal tweezers to simultaneously touch with metal, the outward facing side of the battery, and the brass terminal in an indentation in the plastic about 4 o'clock and about 1/8" outside the battery diameter. To aid in orientation, there is a barely visible small AC (presumably meaning "all clear") pressed into the metal near the battery and the indented brass terminal at about 4 o'clock. It may be necessary to tilt the watch in the light so the light strikes the AC so it becomes visible. Verify the display is working. Resetting the time will be in step 11. 6. Reinsert the red cellophane cover removed in step 2. It may be necessary to slide a knife or similar between the strap holding the battery down, and the battery, to make room for the two cellophane tabs to be inserted in a small air space between the strap and the battery. (When installed, the cellophane tabs do not prevent current from flowing between the top of the battery and the battery hold down strap.) If you use a knife or other metallic object to open up the strap to battery space to allow entrance of the cellophane tabs, take care not to short the battery against metal parts of the watch other than the hold down strap. Quickly glance to see make sure the display is still working after the cellophane is back in place. If display not working, repeat steps 2, 5 and 6 (remove cellophane, reset watch, reinstall cellophane). 7. Remove the rectangular O ring from the case back removed in step 1, or the case, and coat it with Sil Glyde silicone gel grease or similar, to retain water resistance. White grease or any grease should also work. Set the coated O ring on the inside of the metal case back removed in step 1. The O ring will eventually mate back with the O ring slot in the plastic case. 8. Using a toothpick or similar, coat the rectangular O ring slot in the plastic case with the same grease used to coat the O ring in the metal case back, to provide extra water resistance. Grease is nonconductive, so there should be no damage from shorting if some of the grease gets inside the watch. 9. Wipe hands clean and wash hands and/or use plastic gloves to avoid putting too much grease on the outside of the watch. 10. Replace case back removed in step 1. Screw in the 4 removed screws with your 5/64" Phillips head screwdriver.
Dec 21, 2010 | Casio Watches
I'm looking for a manual for a craftsman table saw model 137.248830.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0606545.pdf
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Aug 09, 2009 | Craftsman Saws
Need assistance putting belt on turn table
"Put the thing on the other thing. There you go."
- Everyone trying to explain this to me on the internet.
May 27, 2008 | Teac P-A688 Turntable
Turn Table
No belt, just the motor and coupler.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 19, 2008 | GE JVM2070SH 1100 Watts Convection /...
Philips pm4s how to and codes
Search google for remote code for your type of remote I found mine on first choice
Apr 22, 2007 | Philips PM4S Remote Control
Saws Logo
56 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
