Question about Sewing Machines
Acs light comes on and freezes the foot and or hand controls
  • Sewing Machines Master
  • 12,487 Answers
Difficult to advise since no make/model was provided. However, if the machine is locked, it could be a safety issue. Consult the owner's manual troubleshooting section or contact the manufacturer support group for assistance.
Posted on Dec 28, 2016
Electronic foot control on My Elna free arm model SU is not getting power to the machine from the electronic foot control. The light comes on, but the control will not provide power to the machine.
take the foot control in to a sewing machine repair shop and have it tested
earlier models were a simple resistance variation but later models are electronic control
it could be a simple broke connection in the control
Sep 04, 2016 | Elna Sewing Machines
Bernina 1006 foot peddle does nothing
Not sure. It could be something to do with the foot control, power cord, or the motor. Does the light come on? If so, it's probably not the power cord. If you have access to another foot control and power cord, that is an easy way to test. Otherwise, might be best to take it to a Bernina technician.
Bernina 1006 Parts
Bernina Foot Control Power Cord for 1000 800 Series
http://www.drdanessmh.com/berninaftc.html
Apr 03, 2016 | Bernina Sewing Machines
Foot pedal does not operate needle
[PDF]INSTRUCTION MANUAL - Singer
www.singerco.com/uploads/download/445_4830_4832.pdf
around the sewing machine needle. ... ings of the machine and foot controller ... The spool does not turn. 7. ... Note: Do not operate machine without fabric.
Oct 29, 2015 | Singer 3116 Simple
My brother sewing machine just quit working
Does the light come on? If the motor will increase and decrease in speed as you push the foot control the belt is broken. You need to check to see if the hand wheel is locked after using the bobbin winder. This is your second possibility.
Dec 17, 2014 | Brother Sewing Machines
Machine is behaving as if not getting any power, but light is on. Press foot pedal and absolutely nothing happens
There is probably a bad connection in your foot pedal. Try moving it around with your hands at the contact points while pressing to activate. If it goes when you are shifting its position then it needs to be fixed or replaced.
May 20, 2014 | Janome Sewing Machines
Is the motor in my kenmore sewing machine bad?
will the motor run if you turn it by hand when the power is on
Apr 02, 2014 | Sewing Machines
The foot pedal on my Singer Inspiration is stuck on fast speed.
Hi lawoffice474...
Unplug your foot pad from the machine and the electrical receptical.
Try moving the foot pedal with your hands, back and forth as if you were pressing your foot on it.
Did it loosen up?
If yes then you still need some maintenance...
If no then you still need some maintenance.
Disassemble the foot pedal and take as many pictures as you need to be able to reassemble it.
Once you have disassembled then you will look to oil (one drop max) the pivot points of the foot pedal, like the hinge assembly, reostat linkage,etc.
Once you have it oiled then try moving the foot pedal again my hand before reassembly.
If everything moves ok then your good to go...
Reassemble the foot control.
If not then its time to replace it with another foot pedal such as one of these at this webpage below:
Please take time to rate me thumbs up.
http://www.sewingmachinesplus.com/singer-foot-controls.php
Sep 10, 2011 | Singer Inspiration 4206
I can't start to sew on my 830. The foot control is recognized(the start/stop button light goes off when I press the foot control), but does not make the presser foot come down. It worked 15 minutes ago...
If you lower the pressure foot before you press the foot control does it sew then? If so, then some how in your setting menu you auto pressure foot setting has gotten turned off.
Apr 23, 2011 | Bernina Artista 180
The machine won't run (the light comes on, so power connection is ok)
Maybe your foot control is bad. Some repair shops have used ones on hand to verify.
Apr 21, 2011 | White Sewing Sewing Machines
Knee pedal does not work
I think what you mean is that it lifts the foot. That is what its supposed to do. Some of the older ones it could be used for a speed control (30-40 years ago).The knee BAR is there to lift the foot for you so you can turn fabric etc. without having to reach behind and lift it. It acts as a third hand. You must have a foot control which plugs into the small hole on the right side of the machine.
Hope I helped.
Feb 07, 2009 | Bernina Virtuosa 150
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
