What year was the edison disc phonograph c 33 official laboratory model made
  • Audio Player... Master
  • 5,487 Answers
I would say between 1925 and 1935.
Posted on Dec 29, 2016
Why was 78 rpm chosen as the standard speed for Vinyl records?
Edison patented the phonograph record at 80 rpm. Victrola to keep from infringing on his patent went with the 78 rpm standard. Afterward RCA and several others used 78 as their standard.
Mar 24, 2015 | Vintage Audio Players & Recorders
I have a vintage RCA Victor turntable from the 50's or 60's. I need to replace the needle housing, but cannot find a model or serial number to look for parts.
Turnatables then used ceramic or crystal cartridges. All you need to do is look for one of them plus something that will fit in the space in the arm. You will probably not find the original cartridge.
Feb 17, 2013 | Audio Players & Recorders
Oonsole model with stereo and phonograph, and phonograph will not turn on
The easiest way to find out the issue is to get an OHM reading to see if you are getting power from the switch when you select phonograph. If it is putting out, then the issue is with the phonograph, if not it is with the switch, and you will need to find a replacement.
Mar 04, 2011 | Curtis Televison & Video
I need a needle to play the phonograph Model SS4000 RCA radio and phonograph combination
Search the web and eBay by part number or model number and you should be able to find what you are looking for.
Mar 02, 2011 | RCA Audio Players & Recorders
Playback on the turntable is sped up
The first step to resolving this issue is to select the appropriate RPM speed for the record that you have in hand. If it is not a simple 33 1/3 RPM record set on 45 RPM, then it would seem that the phono motor speed could require adjustment. Your phonograph is a belt-driven PX-E860 K with a DC servo motor.
Some people mistake the the 7"/LP record size LEVER for the rotational speed BUTTON (33 RPM when raised; 45 RPM when down).
In the case of needing to actually callibrate the rotational speed, underneath the unit there is a hole labeled "33" & a hole labeled "45." Using a very fine precision screwdriver, you can callibrate the speed of each. Insert the screwdriver into the repsective hole past the rubber & slightly turn the screw (rotational speed increases as you turn the screw clockwise).
Jan 07, 2011 | Aiwa Z-L500 Shelf System
Its an edison model emd40s year 200403 and the
Any float will work. Go to home depot and get a toilet float kit. -Good Luck Ned-
Sep 16, 2009 | Edison 40 Pint Dehumidifier
Seeburg Stereo Phonograph Model ESL100 Q-65-H5
End of record switch out of adjustment or bad? Disconnected?
Mar 05, 2009 | Wurlitzer Jukebox 1015 One More Time...
48 people viewed this question
 Grubhead
Grubhead
