Question about Kenmore Dishwashers
My Kenmore Elite dishwasher model 665.13949K010 will not start. No lights on panel, plugged in. this happened a couple years ago and a repairman pressed a couple buttons and it reset and worked fine.
  • 5911 Answers
SOURCE: Kenmore Elite Dishwasher Problem
The dishwasher should have a thermal fuse mounted to the control board behind the operator console4.gif. It is a small silver colored device4.gif attached to a white plactic bracket. In some model dishwashers the wrong gage wiring was used causing the wires to heat up and trip the thermal fuse. There was no apparent risk of fire or anything like that, but the thermal fuses didn't tolerate the heat differential too well. A fix for the problem was to purchase a thermal fuse replacement kit (found at most appliance repair stores) that had thicker wires. The part number for the thermal fuse kit is 959376 and the price is $16.85. You can find it at Order on line and have the part shipped directly to you. access the control board perform the following:
1. Turn off the main breaker to the dishwasher. This is important. Even though the dishwasher is not running, the control board still has live voltages present.
2. Open dishwasher door and remove the top screws that hold the console in place. You shouldn't have to remove the lower screws unless you plan on removing the entire door panel.
3. The control panel should pull off from the front enough to where you can access the control board. There is a thermal fuse mounted on the board with two wire leads going to it. The fuse is silver in color and mounted to a plastic bracket which is mounted to the control board.
4. Cut the wires on the old fuse and splice the new fuse kit to it. Leave plenty of wire to accommodate. There will be instructions included with your replacement kit. Ensure you follow the direction thoroughly and tighten the wire lug screws securely.
NOTE: Do not attempt to reuse the existing wires by simply unplugging the old fuse and replacing it with the new one (been there). The fuse will eventually blow again. Follow the instructions provided and you can't go wrong.
If you have any further quesitons, or if you run into trouble during your repairs, let me know. Good luck to you.
PS If you do not wish to order on line, take the part number I provided you to any major appliance repair shop4.gif and they SHOULD have the part available. This is a known problem and a common fail item.
Posted on Dec 15, 2007
  • 13 Answers
SOURCE: Kenmore Elite wont power on
Door switch. If the washer thinks the door is open, it won't run.
Posted on Aug 20, 2008
SOURCE: Kenmore Elite Dishwasher- The touchpad
can you post the rest sequence? i would love to try this!
Posted on Aug 24, 2009
SOURCE: Kenmore Elite dishwasher model 665 touchpad buttons falling off
Posted on Mar 27, 2010
  • 1998 Answers
SOURCE: Maytag MDBtt60awb
most likely you have a bad motor when replacing the motor ihave found it is cheaper to get the pump with the motor attached where as they charge you more money for just the motor or the pump seprately try allbrands appliance parts they seem to be cheaper
Posted on Apr 30, 2010
How do I fix a flashing Start/Resume light on a Kenmore Elite dishwasher model 665.13793K601?
These dishwashers are known to accumulate moisture in the keypad and then short. The solution that I have seen is to replace the keypad...It is possible that all of your issues with this dishwasher could point back to the keypad. After spending $$$ on the circuit boards, do you want to throw and additional $135 for a keypad? or replace the whole unit? Food for thought. Here is a link for you:
May 22, 2014 | Kenmore Dishwashers
Kenmore Elite Dishwasher will not start
Consider examine inside there is maybe fuse busted on the panel or in the circuit through the control panel of the machine.
Feb 05, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Elite model 665.15932 motor is now very
1)check any jam on impeller(motor)
2)check whether bearing plm.(possible replace the bearing)
Mar 01, 2010 | Kenmore Dishwashers
Kenmore Elite: Model 66576962K601.
I had exact same issue. I've called Sears Maintenance. They had to change 2 pieces in UI: Timer KUDS02SRB10 and CONSOLE Assy. Cost 360$ pieces  130$ Job Charge 60$ taxes.
Now It works perfectly, but I bought 1100$ 3 years ago... Really expensive to keep it running.
Nov 29, 2009 | Kenmore Dishwashers
Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Dec 23, 2008 | Maytag MDB7100AWB Dishwasher
Kenmore Elite 665 16912001 Dishes not completely dry.
you can check for the elemant open. it will have to be pulled out.the connection may be bad to the heater.
Oct 30, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
I had this same problem so I took the front panel off to access the thermal fuse.  What I found instead was that food had become lodged in the door latch which was keeping the door safety switch from operating properly.  I took a thin screwdriver and removed the food from the cavity.  Since you did not have the problem in your first five years the cavity just might be the problem since that is about the amount of time it took me to get too much food stuck in mine as well. This solution took five seconds and requires no disassembly.
Oct 09, 2008 | Dishwashers
Kenmore elite dishwasher
I had the same problem when I bought it and it just happened again; the problem is solved by ressting the control panel: Hi Temp ---> Heated Dry two or three times. It kind of goes into a testing cycle and the clean blinking light goes off.
Dec 08, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Nov 27, 2007 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwashers Logo
47 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
