Question about The Toys
Please tell me the location of the on/off switch for the mingji a/c helicopter model 802 gallant. Thank you
How do you thread a model 802 overlocker
Unfortunately, the only model 802 I can locate is a Janome sewing machine.
Search the internet for:
Make Model manual
or contact manufacturer support.
Nov 24, 2016 | Sewing Machines
Just purhased two Tier-One Gallant helicopters. They say they are 3 channel. I see no channel selectors on remote or helicopter. I want to fly two of them but don't think I'll be able to unless I have them...
You cannot easily change the frequency these helicopters operate on, they are not designed for multi channel use. To change their operating frequency you would need to find and replace the small crystal inside the helicopter and also inside the remote control.
The 3 channel you are referring to is the number of functions (channels) you can control on the helicopter, not it's frequency channel.
Dec 31, 2013 | Air Hogs Havoc Heli Helicopters
Do the helicopter itself have a on/off switch..tech-one gallant
After fights between teh kids (he's crashing my helicopter) I think I figured it out. The instructions says to select the frequency on the helicopter, but there is no switch. When you first bring up the helicopter and controller, sometimes the green light on the controller blinks a few times. That is it synching up with the helicopter. After you charge the helicopters, turn then both off, Then turn on one helicopter and one controller. The key is when the green light above the one off switch is blinking. I did it with trial and error, so I am not sure exactly how to get it in the mode where it is in pairing mode. RIght now I am reluctant to mess around with it because they are set correctly and the kids are playing with them. I will post later if I figure out the exact sequence for getting them in pairing mode
Dec 26, 2013 | SYMA Toys industrial New Syma S107 Radio...
Is it the gears that make the helicopter just spin? I'm pretty sure I'm just new at this and I'd Like some feedback. Please and thank you
First you should post the model number and make.
Are you sure the blades are suppose to be opposite, you have different size blades on each rotor.
You have this on to smooth a surface, if you held the rotor the body would spin, same thing, the force of the blades is just making it spin on the surface.
Try putting it on cement surface, a driveway or carpet.
Apr 11, 2013 | Sport & Outdoor - Others
I have problem in my new v-max alloy model helicopter - i has charged it yesterday by the usb charger but now the helicopter deosn't work - what can i do ?
my helicopter on/off switch also but how to change the you know tell the solution it will helpful for me
Jun 04, 2012 | Toys
On what part of the helicopter do i connect the remote charger to, I can't find it?
When the helicopter is sitting upright, locate the on/off power switch located on one side of the helicopter. The charging port is located on the opposite side and will look like a tiny square hole/plug (usually white or beige).
Note: The charging cable can only be plugged in one way, because it's notched / keyed so that it can only be plugged in one way. If it does not seem to be going in smoothly one way, flip it over, and try gently plugging it in again.
Dec 26, 2011 | SYMA Toys industrial New Syma S107 Radio...
The control module status indicator is showing two flashes which mean the the pressure switch is open. How do you fix it and where is it on our model could you please help us thank you.
Hello Cindy,
We would love to help you. However, we do not know what model you have to tell you which pressure switch you may need to purchase or the location of the switch as we do not know the model number of the unit you currently own. When you find this information please post back to this thread so that we may help you.
Thank you for chosing FixYa.com to answer you question.
Justin
Mar 09, 2011 | Heating & Cooling
Belts replacement for Mitsubishi gallant (1997)
Is your engine a 4 or 6 cylinder? Air conditioning or no? Either way, a power steering belt at Auto Zone will run you from $7.99 to $12.99. If replacing that does not help, it may be your pump.
HOWEVER, before anything else, PLEASE CHECK THE FLUID LEVEL IN THE POWER STEERING RESERVOIR. It may be low. If so, just add fluid to the correct level.:)
Dec 24, 2008 | 1997 Mitsubishi Galant
Toys Logo
Top The Toys Experts
Lawrence Oravetz
Gary Queen
Gary Queen
Are you a The Toy Expert? Answer questions, earn points and help others
