Question about Dyson DC65 Animal Bagless Upright Vacuum
Dyson DC65 Animal I atook off the vacuum head to remove hair etc. it now appears to br dragging instead of smoothly moving
Suction is fine - but the push/pull aspect is changed
ukvacfan
  • 328 Answers
SOURCE: Dyson DC17 Animal Vacuum
Use the upholstery brush supplied to unclog the perforations on the Dyson filter; the clogged holes don't impede on suction so you dont have to worry about this. It can be annoying however when you see it.
http://www.dyson.co.uk/support/help.asp?article=32&product=DC07-ANIMAL
Click on this page and it will take you directly to the Dyson page (UK) for your Animal model. It wll open up for user manual in another window
www.dyson.co.uk is a very well stocked website which has manuals for virtually all DC models sold.
Dont forget to rate!
Posted on Jul 19, 2008
  • 55 Answers
SOURCE: Dyson Animal hose collapses when using attachment hose
You have a clog in either your hose or your wand. You need to take off the wand and hose and inspect them.
Posted on Dec 02, 2008
VacuumRepair
  • 438 Answers
SOURCE: dyson dc07 animal\ no suction
There could be a few things that would cause your Dyson to have no suction. I will give you detailed step by step instructions along with pictures on how you can diagnose this.
Possible Problem #1. The first problem is extremely common. In fact, we probably see between 2-3 of these problems every week. It mostly happens after people take the bottom plate off the vacuum in order to clean the roller brush. What happens is when they reinstall the bottom plate, they put it on on incorrectly. It's actually very easy to do. When the bottom plate (soleplate) is installed wrong, there will be a gap between the bottom plate, and the agitator housing, or the purple tray the roller brush sits in. This will cause the soleplate to be a few inches higher off the ground then it should be, preventing the brushes from even hitting the carpet. This makes it seem to the user that vacuum has lost suction power because without the brushes hitting the carpet, the machine will not pick up very well on floors, but when they use the attachment hose there's plenty of suction power.
Here's a picture of the WRONG way to install the bottom plate. Notice the gap in between the two housings:
Here's another picture, that is the RIGHT way to install the soleplate:
I would say probably 6 times out of 10 this is the problem with the customers machine. If you checked the soleplate and it is installed correctly, move on to the second possible problem.
Possible Problem # 2. Turn the vacuum cleaner upside down so the brush roller is facing upwards. I found the easiest way to work on it is to put it on a counter top or work bench. On the left hand side behind the roller brush you should see a flexible transparent hose that goes from the motor to the agitator housing. This hose actually has a lot of strain on it when the vacuum cleaner is in the reclined position. When the first few series of Dyson DC07 models came out, they didn't make this hose long enough, so when the vacuum was in the reclined position, it would put too much stress on the hose, and cause the hose to actually crack, usually right where the end of the hose that goes into the agitator housing. Examine your hose and see if you have any visible cracks in this hose. If you need to you may just remove the entire hose assembly by pulling on it. It will easily come right out of the machine so you can inspect it better. Here's a picture of where the hose usually cracks:
This would also explain why the vacuum works fine when using the attachments, but not on the floors. The attachment hose uses a different suction channel, and when the machine is in the upright position, no suction goes through this hose. If you do find a crack in this hose, the this hose needs to be replaced. Here's a direct link to that hose on our GoVacuum website.
Dyson DC-07 & DC-14 Upright Replacement Internal Hose Part # 904219
Possible Problem #3. I would suspect that this may not be the problem, but if neither of the solutions above worked, then try this one. Dyson's in general are prone to clogging. There are a few clog ports throughout the vacuum cleaner that were added there due to Dyson prototypes becoming clogged at these points. Here are pictures of how and where to check for these clogs. Simply remove the suction port covers at both of these locations:
Possible Problem #4. If none of the above solutions worked for you, try this last one. The Dyson DC07 models use a clutch mechanism that stops the roller brush from spinning when changed from carpet mode to bare floor mode. This clutch mechanism is a notorious problem with all Dyson models, in fact they were such a problem that Dyson had to redesign the DC07 model to a non-clutch system. Even if yours is one of the newer ones that don't use a clutch, yours still has a belt inside. You can tell if your model uses a clutch or not by the shape of the roller brush. If your brush is a perfect cylinder shape, yours does NOT have a clutch. To check and see if the clutch or the belt have gone bad, first release the handle on the vacuum as if you were vacuuming carpets. Make sure the machine is set to carpet mode. Now while the handle has been released, turn the machine upside down and see if the brushes are spinning. If the brushes are spinning then turn the vacuum right side up and put the brushes on the floor. Can you still hear the brushes spinning when they are hitting the carpet? If yes, then this is not the problem. If the brushes however are NOT spinning, this indicates either your brush roll, clutch, or belt have gone bad.
If these solutions still didn't fix your problem, I'd be happy to try and help you further. Just use the Clarification Request, or comment section here on the Fixya repair page.
If this repair was helpful to you, please be sure to rate this repair as helpful by clicking the thumbs up icons in the top right hand corner of the repair. Thanks so much!
Chris J.
GoVacuum
Posted on Apr 04, 2010
Dysonteam
  • 167 Answers
SOURCE: No suction on wand of Dyson DC14 Animal
Hi its Darran at Dyson.
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
Kind regards
Darran
Dyson customer Service
Posted on Apr 22, 2010
jspahn
  • 105 Answers
SOURCE: I have the Dyson animal
You might want to check and see if your cyclones are plugged with hair. this can happen and there is a great site to disassemble and clean the cyclone here: http://www.exonotes.com/content/node/4
Posted on Aug 10, 2010
How do you change the attachments?
Hello, this is Ava with Think Crucial.
You may refer to the online manual of your Dyson DC65 on how to change the attachments.
https://www.dyson.com/medialibrary/Files/Dyson/Support/downloads/US/Floorcare/manuals/DC65_Manual.pdf
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dc65
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Sep 14, 2016 | Dyson DC65 Animal Bagless Upright Vacuum
Tip
Dyson DC41, DC43, DC65 or DC66 - Removing a blockage from the cleaner head or...
If your Dyson DC41, DC43, DC65 or DC66 upright vacuum cleaner doesn't seem to be picking up as well as it should be from carpets or hard floors, this may be due to a blockage. A blockage could occur if an item too big for the machine has been accidentally vacuumed up.
After turning off and unplugging the machine, please follow the steps shown in the video to locate and remove any obstructions from the cleaner head, internal hose or changeover valve.
on Jun 04, 2014 | Dyson Bagless Upright Vacuum DC41 Animal
Dyson dc44 animal cordless handheld brush not turning but suction fine what can it be
remove the brush from the enclosure. use a quarter rotate the cover, pull out the brush and clean any debris. operate the unit before installing the brush to see if the device in fact operates as designed. if not replace the unit, if so install the brush and bust out laughing!
Aug 13, 2016 | Dyson DC44 Animal Cordless Vacuum
The rotating brushes on my floor setting keep stopping on carpet - even though nothing is clogging it. I have to turn my vacuum off and then back on to get it to start spinning again.
There are two things that cause this.
1) The suction is not good and is not making the turbine head run. Clean the filters/ head and check the hose for blockages
2) The Turbo head has more friction than it should. Remove the brushes from the turbo head and remove all hair etc from the bearings with tweezers.
If it still does not work the the most common problem is the bearing retainer in the turbo head has heated up and come loose. This is a very hard repair I do but for most they should buy a new turbo-head.
Keith from Dyson Repairs North Shore Auckland
Sep 24, 2014 | Dyson DC29 Animal Vacuum
Dyson dc15 brush bar turns intermittently depending on angle of vacuum
There are a number of reasons why your brush roller is not working properly. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
Ava B.
Jan 14, 2013 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson Animal handheld brush not turning
We would recommend checking it for a blockage and a removing any hair or fibres from the brush bar.
As the brush bar relies on the suction power of your machine, it would be worth cleaning the filter and checking for blockages as this may cause a loss of suction will in turn stop the brush bar in the Mini Turbine head turning.
If you are still experiencing difficulties, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Liaison
Apr 10, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
My dyson dc17 animal will pick up via the hose attachment but there is no suction when you use the regular vaccuum on the floor - you can hear the difference in the suction once you put the floor part down...
Check that the brush control dial is in the centre position when upright and then moves forward when the head is released. If the brush bar is still not spinning when switched on in the vacuuming position, check the base for blockages and remove any threads or hairs from the brush bar as outlined in your user guide or on our website.
If you are still having difficulties, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Jan 16, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC65 Animal Bagless Upright Vacuum Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
