Question about Garden
The oil smell is all over the ho7se. We can hardly breath
It'seems a gravity fed oil stove
2 Suggested Answers
  • 18313 Answers
SOURCE: We have oil smell through the whole house. We can hardly breath. What is causing It?
Blocked vent stack or wind blowing the wrong way. Chimney need cleaning? Try opening a window a crack. It can make it better or worse.
Posted on Dec 27, 2016
Dec 27, 2016 | Motorcycles
Will start and run for ten mins then dies. If I wait ten mins will run again. Fuel filter is empty when it dies
Sounds like you got the wrong filter. There are filters for fuel pump tractors and filters for Gravity fed engines. I had the same problem when I changed my filter. I had to get one that was gravity fed
Oct 17, 2015 | Cub Cadet Garden
Front oil seal leak
never guess here.
oil leaks,
no engine stated, nor year, so you wont get good advice.
mines a v6 2.5L
on most suz engines, front leaks can be.
1: top front of valve cover seal. leaks. then gravity does its thing.
2: top cap seal
3: bottom seal
4: pan seal,
5: pump seals.
doing all on a guess. is $$$$$$$$
what we do is clean it all , run for 10 miles, and see what really leaks.
use the UV dye kit. and find it.
you have gravity and air currents that form a chaos. there.
so only those 2 work.
Jan 07, 2014 | Suzuki XL7 Cars & Trucks
1988 883 sportster hugger oil draining from oil tank to crankcase after shutdown
commen problem, could replace oil pump as pump is gravity fed and if worn will allow oil to seek into crank case.
Nov 04, 2013 | Harley Davidson Motorcycles
We have just had a wood burner stove fitted at some cost and we seem to have rather a lot of smoke smell in the room we thought with a stove this wood eliminate this . .
You won't be able to eliminate all smoke odors with any woodburning system that I am aware of. On a new installation it's possible that part of the smell is coming from light oil coatimg on stove from manufacturer burning off. I would also check setting on damper,and make sure chimney is clean. On manual damper I set them at full open at start. Then when I have a good hot fire going I shut mine down to 3/4. I would do some trial and error to find what works the best for you. I hope this helps. Thanks
Nov 24, 2010 | Heating & Cooling
Gravity fed toilet cistern-no water feed.
First I would disconnect the supply line and see if I have water to that point. If so, than take apart or replace the ballcock or float valve. If not continue to trace problem backward untill found. Hope this helps.
May 11, 2010 | Plumbing
My 106821A 10" Remington electric chain saw leaks oil heavily when stored. Suggestions?
According to the manufacturer... Saw has a gravity-fed oiling system and it is normal for oil to “slowly” seep when saw is not in use. Empty tank after each use to prevent seepage. If you empty before you store it that should do the trick. I hope this helps!
Jun 08, 2009 | Remington Electric Chain Saw
The auger motor is fed through a high temp limit thermostat. It has to be manually reset if it activates but it could be causing your problem with a bad connection or intermittently bad. It deserves a look...
Jan 16, 2009 | Napoleon Auburn Pellet Stove Heater
Bad Smell only when window is down...Smells like propane
no the ring and pinion seems ok from what you are wouldn't smell it up front while moving do to wind and what not,
oil can smell at low temps.
you may have an exhaust leak at an O2 sensor seal. or something relative to that.
Aug 17, 2008 | 1999 GMC Suburban
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
