Question about Miscellaneous
Upper arm pain
Continuous pain in r upper arm
Have pain oper arm even had a jag but pain still wnt go away even pain kilers ae not workinhi
Might be onset of frozen shoulder syndrome. Often only cortizone shot may help. But this is guess work plus having had the syndrome on my part. For all I know, your pain could come from a vaccine shot. Even gall bladder problems or heart disease can cause chronic shoulder pain. A doctor might sort this out, given time.
Remember, I'm not a medical professional. Any suggestions here actually can potentially make things worse, given I have no way of knowing the underlying condition. Any suggestion I have might work but might waste your time when it would be better being used to sort things out with a medical professional. Just because the shot or pain reliever proved ineffective is not a reason to suppose the next form of treatment on the doctor's check list also will not work. But serious chronic pain is nothing to ignore as it will wear you down in short order.
Till then, there are specific stretches which might help if it is related to muscle injury or frozen shoulder. The sort of pain you are talking about tends to finally make it very difficult to sleep.
Upper Arm Pain Exercises Medi Dyne
You might also google for exercises on the Mayo Clinic site. That site has a symptom checker too and might help you rule out some things.
Aug 24, 2017 | Cars & Trucks
What is #1 cause of pain underneath left shoulder blade?
Here you go Edna
Self diagnosis is a bad thing though and you should consult a physician.
  • Left Shoulder Blade Pain. - Find Info on Health & More - reference.com‎
    Adwww.reference.com/Health‎ This ad is based on your current search terms. Visit Google's Why This Ad page to learn more or opt out. Reference.com delivers the best articles from across the web and real people. Q&A Articles · Quick & Easy Answers · Search Relevant Content · Popular Topics
  • Fibromyalgia symptoms - arthritis.ca‎
    Adwww.arthritis.ca/Fibromyalgia‎ This ad is based on your current search terms. Visit Google's Why This Ad page to learn more or opt out. Learn about fibromyalgia symptoms, self-management & treatment. Highlights: Lack Of Concentration And Memory, Heightened Sensitivity To Touch And Pressure...
  • .spell{font-size:18px}.spell_orig{font-size:15px}#mss p{margin:0;padding-top:5px}
    Search Results
    Pain under Left Shoulder Blade ' MD-Health.com
    www.md-health.com/Pain-Under-Left-Shoulder-Blade.html
    Cached
    Similar
    Pain under left shoulder blade can seriously affect your quality of life and overall ... is actually one of the top reasons why people complain from shoulder pains.
    Chronic pain under left shoulder blade near spine - Upper Back ...
    www.spine-health.com > Home > Upper Back Pain, Thoracic
      1. Cached
    1. Nov 12, 2015 - 17 posts - ‎14 authors
    Chronic pain under left shoulder blade near spine. ... (still seeing one), physical therapy, electronic massagers, pain killers, the Theracane. .... this morning I woke up and could barely get dressed because the pain was so bad. Shoulder blade and arm pain with arm numbness. 27 posts 20 Feb 2013 Neck and shoulder blade pain, any ideas? - Neck Pain ... 18 posts 25 Dec 2012 More results from www.spine-health.com
    When to Be Concerned About Shoulder Blade Pain - Verywell
    https://www.verywell.com > ... > An Overview of Lung Cancer > Lung Cancer Basics
    Cached
    Some possible causes include: Muscle strain - Short-term overuse of your arms and upper torso may be experienced in your scapula, and is the most common cause of shoulder blade pain. ... Muscle conditions such as rotator cuff tears may also cause pain in this region.
    Shoulder Blade Pain: Left, Right, Under, Between Scapula ' eHealthStar
    www.ehealthstar.com/shoulder-blade-pain.php
    Cached
    Similar
    Nov 25, 2014 - Fracture of one or more ribs can cause sudden, severe, sharp pain near the shoulder blade; the pain is usually aggravated by breathing, ...
    Nov 27, 2016 | Cars & Trucks
    I had sudden pains in my chest the other day and a tenderness came on in my upper left arm.could this be a clot
    I am not a trained medical professional so seek professional help.
    Look at it as a warning and visit your local doctor and get it tested and checked.
    It is better being aware of a problem or knowing it is not a clot or heart problem for peace of mind !
    Aug 11, 2015 | Health & Beauty
    How to remove upper ball joint on driver side of an 1994 GMC Sonoma
    The OEM ball joint is riveted into the upper control arm. There are two possible ways to replace the joint. You can purchase the entire upper control arm/ball joint assembly, which comes complete with the upper control arm bushings. This part costs about $150.00. You will also have to deal with the coil spring when replacing it this way. You can also buy just the ball joint for about $30.00. This will require that you drill out the rivets of the original ball joint and then bolt in the replacement with the bolts that are provided with it. The 2WD and 4WD versions are the same. See this link.
    http://www.autozone.com/suspension-steering-tire-and-wheel/ball-joint-upper/gmc/sonoma-4wd/1994/6-cylinders-z-4-3l-tbi
    Mar 18, 2015 | 1994 GMC Sonoma
    Google com
    A.D.A.M. Medical Encyclopedia.
    Tennis elbow
    Epitrochlear bursitis; Lateral epicondylitis; Epicondylitis - lateral
    Last reviewed: August 11, 2012.
    Tennis elbow is soreness or pain on the outside (lateral) side of the upper arm near the elbow.
    Causes, incidence, and risk factors
    The part of the muscle that attaches to a bone is called a tendon. Some of the muscles in your forearm attach to the bone on the outside of your elbow.
    When you use these muscles over and over again, small tears develop in the tendon. Over time, this leads to irritation and pain where the tendon is attached to the bone.
    This injury is common in people who play a lot of tennis or other racquet sports, hence the name "tennis elbow." Backhand is the most common stroke to cause symptoms.
    However, any activity that involves repetitive twisting of the wrist (like using a screwdriver) can lead to this condition. Therefore, painters, plumbers, construction workers, cooks, and butchers are all more likely to develop tennis elbow.
    This condition may also be due to constant computer keyboard and mouse use.
    Symptoms
    • Elbow pain that gradually worsens
    • Pain radiating from the outside of the elbow to the forearm and back of the hand when grasping or twisting
    • Weak grasp
    Signs and tests
    Your doctor or nurse will examine you. The exam may show:
    • Pain or tenderness when the tendon is gently pressed near where it attaches to the upper arm bone, over the outside of the elbow.
    • Pain near the elbow when the wrist is bent backwards.
    X-rays may be done.
    Treatment
    The first step is to rest your arm and avoid the activity that causes your symptoms for at least 2 - 3 weeks. You may also want to:
    • Put ice on the outside of your elbow 2 - 3 times a day.
    • Take nonsteroidal anti-inflammatory medications (such as ibuprofen, naproxen, or aspirin).
    If your tennis elbow is due to sports activity, you may want to:
    • Ask about any changes you can make in your technique.
    • Check any sports equipment you are using to see if any changes may help. If you play tennis, changing your grip size of the racket may help.
    • Think about how often you have been playing and whether you should cut back.
    If your symptoms are related to working on a computer, ask your manager about making changes to your work station or have someone look at how you chair, desk, and computer are set up.
    An occupational therapist can show you exercises to stretch and strengthen the muscles of your forearm.
    You can buy a special brace for tennis elbow at most drug stores. It wraps around the upper part of your forearm and takes some of the pressure off the muscles.
    Your doctor may also inject cortisone and a numbing medicine around the area where the tendon attaches to the bone. This may help decrease the swelling and pain.
    If the pain continues after 6 - 12 months of rest and treatment, surgery may be recommended. Talk with your orthopedic surgeon about the risks, and whether surgery might help.
    Expectations (prognosis)
    Elbow pain may get better without surgery. However, most people who have surgery have full use of their elbow forearm afterwards.
    Aug 30, 2014 | Health & Beauty
    Upper arm does not spin
    If the sprayer arms continues to get caught, see if your racks can be adjusted in height. Some can be moved up or down by the side brackets. Otherwise freely spin it with the unit off and see if it is just getting caught on a pot/pan in the unit. Otherwise, it may not be getting enough water pressure to turn it completely around.
    Aug 22, 2012 | Electrolux EWDW6505GS Fully Integrated...
    Upper and lower spray arms are not spinning
    Check that the arms spin freely when spun by hand, then check the outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it with the result is that the upper dishes do not get enough water and chemicals. It may also cause water to continue dripping onto dried dishes after the the drying cycle has stopped.
    May 06, 2011 | Microwave Ovens
    Upper and lower ball joints
    It's definitely easier to replace the control arms with the ball joints. I think you may have to buy new upper control arms anyway if they are oe i don't think the upper ones can be pressed out. If you are going to press the ball joints out you do not need to remove the springs or struts. Brake caliper/rotor/hub and knuckle are removed leaving the upper and lower control arms. i would disconnect the abs connector too if it has abs. recommend supporting the vehicle on the frame somewhere. You can buy a ball joint press kit for about 80$ online or use a really big hammer to smack them out. Putting them back in may be a pain without a press.
    May 23, 2009 | 1997 Ford Ranger SuperCab
    Miscellaneous Logo
    Top Miscellaneous Experts
    Andy Fraser
    Andy Fraser
    Dan Grod
    Level 1 Expert
    dennis lewis
    Level 1 Expert
    Are you a Miscellaneous Expert? Answer questions, earn points and help others
