Question about Candy Refrigerators
Removal of panel to access thermostat on Candy cp2913f/9 fridge freezer
huuum
  • 750 Answers
SOURCE: Candy CPCA250 GB Freezer feezing but fridge not cold
Hello jonnyclewlow
Welcome,
You said, you recently had a problem with my Candy fridge freezer (it defrosted overnight and wasnt cooling at all) and a repair shop diagnosed a thermostat problem. I have replaced the thermostat, Now the freezer freezes without any problems but the fridge does not go cold at all.
Also the compressor is running constantly
This is my first thought
Fresh Food temperature is
too warm. Freezer
temperature is satisfactory.
1. Fresh Food control is set too
warm.
2. Set fresh food control to a colder setting. Allow 24
hours for temperature to stabilize.
3.Then see if you do not have your freezer articles packed full up to the top, or covering the cold air vents usually found in the rear of the freezer compartment.
The fridge and the freezer share the cold air so the air must not be restricted from travel form the freezer to the fridge and back!
This would also cause the compressor to run none stop trying to cool the fridge!
So check your air vents in the freezer.
I'll bet you did not know they were there !
Most of us never notice!
Hope this works for you.
Please let me know that one of these solutions worked for you!
or if you have any questions.
Thank You, huuum
Please remember to leave a rating!
Posted on Oct 14, 2008
  • 5 Answers
SOURCE: Fridge has become freezer and freezer become fridge
sounds like the control board i had same problem along with no light i had to have control board replaced working fine now
dmb
Posted on Feb 09, 2009
bobicehouse
  • 1524 Answers
SOURCE: Fridge not cold enough, Freezer ok
The refrigerator gets its cold air from the freezer section through ducts and damper control. Check for blockage.
Posted on Apr 27, 2009
SOURCE: Candy CPCA270FFK Thermostat replacement
if your refrigerator is in warranty than contact your service authority......or if you had purchased it by your own than ...... my friend! the thermostart does'nt have any warranty
Posted on May 14, 2009
  • 85 Answers
SOURCE: Candy Frostfree Fridge freezer, model CPCA240FFK
1st of all conferm that the compressor is automatically (through Thermostate) going to ON/OFF or not, if it automatically goes OFF, i sugges its OK. and if not its no problum. (Minimum 4 hours rest is Must of a compressor, u can maunally OFF it for daily 4 hours Sleep)
Take Care
Shafky
Posted on Jun 17, 2009
Why is my fridge freezing up in my candy fridge freezer
Hello there,
The reason your fridge is freezing up is simply because there is a problem with the defrost unit of the refrigerator. The defrost thermostat simply could have gone bad and therefore is not getting the defrost heater to start work.
Have the defrost thermostat tested and replaced once found faulty.
Hope this was of help to you. All the best Elect_Comp
Sep 26, 2011 | Candy CPCA240FFK Bottom Freezer...
Candy futura cfmf 266a fridge freezer problem
Either the thermostat is set to high or you need to replace the thermostat.adjust it to 1/2 way position position and if temp is to cold and it doesnt want to switch off, it means the thermostat is faulty.
May 21, 2010 | Candy CPCA240FFK Bottom Freezer...
Take Care
Shafky
Jun 17, 2009 | Candy CPCA240FFK Bottom Freezer...
May 14, 2009 | Candy CPCA270FFK Bottom Freezer...
Candy frost free fridge freezer .freezer working ok
The thermostat might be turned up too high or is faulty. It should click when turned up and down from the setpoint.
May 12, 2009 | Freezers
Hello jonnyclewlow
Welcome,
too warm. Freezer
warm.
Thank You, huuum
Oct 14, 2008 | Candy CPCA270FFK Bottom Freezer...
you can decrease the setting of your thermostat for a start.
tnx 4 using fixya,
drcool
Sep 07, 2008 | Candy CPCA240FFK Bottom Freezer...
Fridge Feezes
My Candy fridge freezer done the same. After a bit of investigation, I found that the little plastic shaft from the front temperature dial that connects to the thermostat has snapped. I merely glued it back together and it worked fine.
In essence, the thermostat was turned on to super all the time, and turning the dial anti-clockwise did nothing as it wasn't connected to the thermostat.
Very flimsy I say.
Apr 08, 2008 | Candy CPCA240FFK Bottom Freezer...
i have candy fridge freezer which the thermostat is on high setting but not cold as it should be. There is build up of ice around thermostat at the back of fridge inside. What is needed to repair?. Any ideas? Cheers!
Nov 02, 2007 | Candy CPCA240FFK Bottom Freezer...
Refrigerators Logo
Top Candy Refrigerators Experts
Charles T Nevin
Charles T Nevin
Cesar Quant
Cesar Quant
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
