Question about Panasonic Televison & Video
How to get up the Service menu on Panasonic tx-p5out50b please
Have screen issues need to find out to get service menu up fixed it now it's volume button held down on actual TV then push 0 three times on remote
techman
  • 3130 Answers
SOURCE: Panasonic PT-47WXD63G
If you have a problem with the convergence, believe me, going into the service menu and trying to correct it will only give you large headaches, DO NOT USE THR SERVICE MENU UNLESS YOU ARE A TRAINED TECH!!!! Doing so can result in a complete and total failure of this TV set. I service menu is not for any major changes in any adjustment. It is not the cure all. If your convergence all of a suddenly shifted, it is not a service menu issue. Your problem is the convergence amp IC's. Good Luck
Posted on Aug 12, 2007
ronpar
  • 27 Answers
SOURCE: Tv not responding to remote and now will not turn back on!
if the remote eye on the tv it will do all kinds of strange stuff once the eye on tv gets dirty the the tv will shut off after 2 seconds try cleaning it and see what happens the eye on tv is hard toget to so get a can of air to blow it out i took my pocket knife to clean mine i know that was ruff on eye but thats all i had if this dont work try unpluging your control board on front of set board may be bad or buttons are stuck email me at rjp5765@msn.com if this helps
Posted on Dec 06, 2007
robotek
  • 1512 Answers
SOURCE: Apex 32 inch tv Model #PF3230
G'day mate
Sounds like the power supply regulation has gone high volts, and the screen is blooming because of it. I suggest getting a tech to look at it, will probably have the usual issues of capacitors failing in the power supply. Cheers
regards
robotek
Posted on Sep 14, 2008
dsacco86
  • 1077 Answers
SOURCE: Unable to reset Lamp Hour Meter on Panasonic PT-50LC14
Try this, using the Panasonic remote, wait until the notice about your lamp goes AWAY (it wont work with the message still up).
Hold the volume down on your tv while holding the split/play button on the remote.
You will get a notice about 4-5 seconds later that it was reset.
Posted on May 29, 2009
  • 3 Answers
SOURCE: 42" LG 42LC7D LCD TV stuck in demo mode?
Did you have any luck? My LG is stuck in demo mode too. Menu button doesn't work, and keylock was on as default so I can't use the buttons on the TV itself.
Posted on Nov 30, 2009
How do l get into the panasonic Tx39in a300b hidden service menu
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Feb 11, 2015 | Panasonic Televison & Video
I want to know the service menu code of Panasonic TX-32LX70C
Oct 08, 2014 | Panasonic Viera TX-32LX70 32 in. LCD TV
Access service menu 26lxd52
Press & Hold Volume Dn & Ch Up buttons simultaneously for more than 5 seconds. If it do not help you, try an other method. The methods to access service menu to Panasonic TVs are given in detail by this site, Visit it.
Jan 23, 2013 | Panasonic TX-26LXD1 26 in. LCD Television
Panasonic tv ct-32g7df trouble shooting
Visit this site to get more details about this fault. You might have to enter its service mode window to make it right. The procedure to enter service mode an to adjust the data values to CT Series TVs , are described in detail there. The site name is "Electro-help". search for it. It is an electronic entertainemnt equipments' service help site, in English language.
Jun 20, 2012 | Panasonic Televison & Video
I have noise issue with my panasonic tx-22lx2
Reset the TV. Refer its user manual for details. If it do not help you, you have to enter the service mode and make some adjustments there. To get details about how to enter service mode to Pansonic, visit this site "Electro-Help". Google for it, and get details. Never attempt to change any data value to service mode adjustments, if you are not aware about what do you do with it.
May 02, 2012 | Panasonic TX-22LX2 22 in. EDTV-Ready LCD...
Need to find user guide and owners manual
Hello;
I have lost the user manual to a Panasonic TX-32LXD700 32" TV. Does any one know of a link to download a copy?
Many thanks to any one who can help?
Feb 10, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
How can i access the service menu of panasonic tv tx-42lz80m?
Pansonic Limits access to prevent you from making any irreversible changes to the settings or firmware.
What are you trying to do?
Panasonic TV Repair Denver Service
Jan 27, 2011 | Panasonic TCP50S2 50 in. TV
Panasonic tx-51gf85h contrast
The tubes are aging and the grey scale has to be reset, enter service mode and readjust all guns until you get a black and white image. ones done memorize settings and that should fix the problem
also it has come to attention that the seals are failing that hold the coolant. please also check that no coolant has dropped onto the signal board. it is highly conductive and corrosive, it can eat a track on the board and create the same issue as you are having.
May 24, 2008 | Televison & Video
Panasonic Viera TX-37LZD70F - Red 'CHK' message on screen
Your set is in the service mode. TO EXIT THE SERVICE MODE PRESS VOLUME DOWN ON THE SET AND THE OK BUTTON ON THE REMOTE F0R 3 SECONDS.WHEN SELF CHECK SCREEN APPEARS UNPLUG THE UNIT.
Nov 19, 2007 | Televison & Video
Televison & Video Logo
22 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
