Question about Vacuums
On a13H8-K when we vacuum the dirt blows into the 2 filters and out into the room so l have to dust everything when done. What is wrong? Mary
4 Suggested Answers
chrispurs1
  • 372 Answers
SOURCE: Suction not working
Ok first thing to do is remove & clean the 2 piece premotor filter or purchase new.
Now remove soleplate from bottom of machine to do this rotate the 3 plastic screws to unlock position. Lift sole plate off now remove any blockagers or fluff that may be built up over the brush roller.
Remove hair from brush roll using scissors.
Check short clear hose for blockages & any damage rips or tares if it is damaged purchase new hose.
Now look at belts & rotate brush roller it should turn relatively easy if it is difficult to turn by hand remove the brush roller & pull off the end caps the axle will come out with one of the caps.
Check the roller bearings clean away dust build up replace end caps & axle spin roller holding on to end cap if freely to spin refit back on to machine.
If its stiff to rotate you will need new roller.
Now pull off the 2 inspection ports check them for bits of paper etc especialy the (U) shaped port at bottom rear of machine this can contain pens pencills stones all sorts of items that hinder the suction.
Now check the long flexi hose & metal wand for any obstructions.
If after all this machine is still not working correctly go to this site http://dysonmanuals.llc.nu/
On this site you will find Dyson service manuals covering poor suction, clutch,motor, etc.
Chris...
Posted on Sep 26, 2008
advacak
  • 125 Answers
SOURCE: my hoover vacuum spits out dirt particles as I vacuum!
the vacuum is clogged somewhere the brush roller is just kicking stuff around, as it cant get into the suction port
Posted on Dec 02, 2008
galati2k
  • 281 Answers
SOURCE: suction problem
check the intake hose at the bottom it may be clogged.try blowing into the long hose if you can't blow through it then you have a clog somewhere between the long hose and your intake hose at the bottom.the intake hose is the somewhat clear hose that comes up from behind the base at the bottom.you will see it on the backside
Posted on Apr 04, 2009
My new Hoover Wet & Dry Vacuum Cleaner-1800w sucks dust from the carpet but it also blow abt 50% of the dust out into the room. Everything is covered in a layer of white dust. The hose is fitted 100%
It seems it must be blowing out from somewhere. Try to figure out where by feeling for air blowing to try to determine where it's coming from and why.
Mar 16, 2018 | Hoover Vacuums
Top filter keeps clogging up??
Just make sure the rubber gasket is secure at the bottom of the dirt cup if it rides up the dirt will go straight up to the filters
here is the hepa that should be change when it is dirty
Hepa Filter Hoover U5780 WindTunnel Bagless 93002360
Dec 07, 2015 | Hoover U5780900 Bagless Upright Cyclonic...
Why My Rroomba 560 collects the dirt and after 2 or 3 circles gives it back on the floor. What is wrong?
Sounds like it's picking up the dirt, running it around the brushes and dumping it back out after one full circuit. I would check to see if anything big is caught in the brushes and preventing dirt from going into the filter compartment. Do you need to empty out the filter compartment and shake out or change the dust filter? If the filter is too clogged, dust won't get pulled into this compartment because there's no air passing through the filter to draw air.
Jun 16, 2014 | iRobot Roomba 560 Robotic Vacuum
Is blowing dust out as I vacuum
In your manual:
Visible dirt escaping from cleaner
Possible Causes: Remedies:
1) Dirt Container full 1) Empty Dirt Container
2) Filters missing or installed incorrectly 2) Check Upper Tank, Pre-Motor and Post-Motor
Filters for correct installation
3) Dirt Container installed incorrectly 3) Pull out and re-insert Dirt Container correctly
Feb 01, 2011 | Bissell 6591 Power Trak Revolution Bagless...
Dust will blow out of the front vent of my Dirt Devil Featherlite Bagless Vacuum. It seems to be shooting out dust that I just vacuum up, but I can't be certain.
Dust blows out of the filter vent is usually caused by a plugged filter drop the filter door on the back, replace or for a temporary fix blow out the filter
Jan 17, 2011 | Dirt Devil Featherlite Bagless Vacuum...
Dirt blowing out of front of vacuum
Replace filter in the front as it gets loaded with dust and needs replacement. Also clean filter under canister.
Apr 29, 2010 | Bissell 6594 PowerForce Bagless Upright...
I just bought a foldaway hoover with wide path. I plugged it in and started to vacuum and dust flew everywhere. Walmart would not give me my money back so they gave me another hoover foldaway with the wide...
Take to Walmart, plug it in and start to vacuum THEIR floors!
Try removing the dust container and look for anything blocking airflow including the HEPA filter. Make sure the dust cup has a seal where it joins the vacuum. The fix is probably simple, but it shouldn't be up to you to do so!
Nov 16, 2009 | Hoover U5172900 Fold Away Widepath Bagless...
Bissell easyvac filters
Replace Filter
As you vacuum, dirt and debris are deposited in the Dirt Cup
while air passes through the filter before being returned to
the room. This process enhances the vacuum path while
dramatically reducing dust, dirt, and potential allergens from
the air you breathe. Replacing the filter periodically enhances
vacuum power and air quality. To replace the filter:
1. Remove the Dirt Cup.
2. Grasp the filter frame and pull it straight from the Cup.
Empty the Cup.
3. Replace the filter. Push new filter into place at the top of the
Cup, place the small tab at the bottom of the Cup into the
slot at the bottom of the Canister cavity, then press the upper
portion of the Cup into place until the lock button snaps
into place. Use only BISSELL Style 6, #32047 Filters
[package of 2] in your BISSELL EASY VAC™ Model 3101-0.
4. EASY VAC™PLUS Model #3102-0 features a high efficiency
3M Filtrete™ Filter. To keep your cleaner operating at peak
efficiency and to remove irritating allergens from your
home, you should change the FILTRETE™ filter every six
months. Use only BISSELL Style 6, #32046 Filters [package
of 2]. The cup-shaped filter lifts out from the top of the
Dirt Cup, and the new one fits into place.
You may purchase these filters
by calling
BISSELL Consumer Services
1-800-237-7691
Monday - Friday 8 a.m. — 7 p.m. EST
Saturday 9 a.m. — 2 p.m. EST
or from the BISSELL website —
http://www.bissell.com
Jun 29, 2009 | Bissell 3102-0 EasyVac Upright Vacuum
Blows dust
i had this trouble and it turned out someone in my household had tossed out the filter with the rest of the dirt. you may have lost yours along the way since it's relatively easy to throw out.
Mar 01, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Dust blowing out of the side of vacuum
make sure that the filter in the dirt cup is in place.
Dec 30, 2008 | Eureka Whirlwind Litespeed 5740 Bagless...
Vacuums Logo
27 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
