Question about Fusion Televison & Video
My sukam fusion series 3,5kva 48vdc does not power the display continues blinking when switched on i need solution pls
2 Suggested Answers
  • 11 Answers
SOURCE: My Sukam Inverter is not working, even if the power is on, and its continuously beeping! so how can I direct the power, and so that the switches connected with inverter also works fine?
The first thing I would check is to make sure that the polarity is correct... IE: That you have red connected to positive and black to negative, assuming you're connecting it to a battery that is.
Many inverters will actually self-destruct if the polarity is backwards... But some of the better ones will beep instead.
Posted on May 25, 2016
I have a 06 Lincoln Zephyr and the left front turn signal stays on constantly at it runs my battery down and my right front turn signal when you turn it on comes on for 1 blinks 1 time and don't blink no...
Without test we would only be gussing . Could be the SJB - smart junction box , electronic module problem ,wiring problem ,switch etc... Looking at wiring diagrams an testing the circuit's with a DMM - digital multi-meter , would be the way a professional technician would diagnose this . Hooking up a factory or professional type scan tool an checking for DTC'S - diagnostic trouble code's also .
The smart junction box (SJB) monitors the multifunction switch position by sending multiple voltage reference signals to the multifunction switch. When the multifunction switch is in the LH or RH TURN positions, or the hazard lamp switch is engaged, that input signal is routed to ground.
When the SJB receives a request for a turn signal or hazard lamps, the SJB supplies voltage to the appropriate turn lamps.
Smart Junction Box (SJB) Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1342 ECU is Faulted SJB CLEAR the DTCs. RETRIEVE the DTCs. If DTC B1342 is retrieved again, INSTALL a new SJB. REFER to Section 419-10 . B1799 Lamp Turn Signal Front Output Circuit Open SJB Go To Pinpoint Test N . B1801 Lamp Turn Signal Front Output Circuit Short to Ground SJB Go To Pinpoint Test N . B1875 Turn Signal/Hazard Switch Signal Circuit Failure SJB Go To Pinpoint Test P . B2044 Left Rear Stop Lamp Circuit Short to Ground SJB For Milan or Zephyr, Go To Pinpoint Test N .
For Fusion, REFER to Stoplamps in this section to continue diagnosis of the turn lamp. B2045 Left Rear Stop Lamp Circuit Open SJB For Milan or Zephyr, Go To Pinpoint Test N .
For Fusion, REFER to Stoplamps in this section to continue diagnosis of the turn lamp. B2046 Right Rear Stop Lamp Circuit Short to Ground SJB For Milan or Zephyr, Go To Pinpoint Test N .
For Fusion, REFER to Stoplamps in this section to continue diagnosis of the turn lamp. B2047 Right Rear Stop Lamp Circuit Open SJB For Milan or Zephyr, Go To Pinpoint Test N .
For Fusion, REFER to Stoplamps in this section to continue diagnosis of the turn lamp. B2281 Right Turn Switch Short to Ground SJB Go To Pinpoint Test M . B2282 Left Turn Switch Short to Ground SJB Go To Pinpoint Test M .
Your best bet mite be to take it to a qualifed repair shop.
Nov 14, 2017 | Lincoln Cars & Trucks
I have a Sharp SB57 series tv. The tv turns on. Stays on fine for a few minutes, then powers off by itself. When it turns off, there are two green lights flashing on and off.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mar 10, 2017 | Sharp Televison & Video
Hi.I have a1050 va sukam inverter no power on the ac output
Check your fuse. If it's a clear fuse and you can easily see it burnt or good this will tell you if it needs replacing. If it's a ceramic fuse you can use a multi meter to check for continuity.
Dec 29, 2016 | Inverter Electronics - Others
May 25, 2016 | Inverter Electronics - Others
Sukam 800VA inverter continuously beeping with 3 lights blinking. What could be wrong?
check batry voltage or 2nd problem in realay and capicitors or
3rd ic before that disconnect output line
May 05, 2014 | Computers & Internet
I have a digi portserver 2 16 port. When i connect the power, its not getting switch onn. Any idea how to fix my problem.
I am ASSUMING you mean power on, right. Is this an AC powered unit or DC? If it's DC make sure when you connect your volt meter from the - to + terminals that you are getting a +48vdc. If you are installing this in a telecom facility chances are the power plant is -48vdc which would mean you will need to connect the ground side to the positive terminal and the source side to the negative terminal.
If you are using AC verify again with a volt meter that you have 110/120vac and that the plug is properly grounded. This is easily done from the female end of the power cord. If that is fine there should be a fuse on the unit check that.
Let me know how it goes.
Nov 26, 2012 | Digi Portserver Ts 8 Mei Terminal Server -...
Powered on and geting off. No display front led is blinking 4 times.
I HV A PROBLEM WITH SONY-KV-HA21M80 TV. WHEN THE SWITCH ON POWER ON AND GETTING OFF. FRONT LED IS BLINKING 4 TIMES. WHAT COULD BE THE PROBLEM. PLS HELP ME ON THIS.
Apr 29, 2009 | Televison & Video
Televison & Video Logo
19 people viewed this question
Top Fusion Televison & Video Experts
Lawrence Oravetz
ray gallant
Are you a Fusion Televison and Video Expert? Answer questions, earn points and help others
