Question about Electrical Supplies
I have an sdmo generating set with John Deere j88 engine1500 rpm but goes up and down on load. If set rpm at no load to 1500 if a load is applied rpm drops,if set on load and off load it overspeeds.
CarlGehrke
  • 169 Answers
SOURCE: I have an SDMO generating
Set the no load revs such that you get 51 Hz out of the generator, at 80% load this ought to give you something like 48.5 Hz with less than a 3% drop in output voltage. If not, you might have governor problems but I'd try servicing and adjusting it before replacing anything other than filters.
Cheers,
Carl
Posted on Dec 07, 2008
CarlGehrke
  • 169 Answers
SOURCE: 10kw Generac shut down overspeed
Make sure that the throttle linkage is all there and not damaged/misadjusted, then get a manometer and check your inlet gas pressure. Gas pressure should be 8 inches of water column and stay there running or not.
Carl
Posted on Apr 06, 2009
  • 26 Answers
SOURCE: Attempted to start Generac Guardian 15 kw air
I work on these every day. Its either gonna be the rotor or stater, the voltage regulator, but most likely its a bad stepper motor which is the throttle motor, or control board. Thats all that could be causing that so its one of those. If its the rotor or stater thats bad it causes the generator to RPM up because it thinks its not producing enough power due to that. I had the same problem with the same one we just fixed and it was the slip rings on the end of the rotor so bad rotor.
Posted on Jul 09, 2009
harlan301
  • 205 Answers
SOURCE: Coleman Powermate Generator (PM0525202.03) throttle adjustment
set at 3600 rpms at 60hz
Posted on Oct 13, 2009
SOURCE: my sdmo generator keeps shutting down temperature
http://www.aa1car.com/library/overheat.htm
Troubleshooting advice above link.
Sometimes it is the head gasket, check, it can be, incorrect fuel mixture, far too lean, exhaust should be a light grey color. Check enough oil in sump. ensure free flow of air all around machine.
Posted on Mar 28, 2010
I have a John Deer DP 6000 portable generator. The rpm is producing 62 cycles at no load 1/2 voltage rotor has no brushes replaced both capacitors have flashed them both with 12vdc while running
62 Cycles is just going to make a clock run a little fast ,but its ok.
There might be a load sensor on the gen set. That will only allow the to run at full throttle with a load applied on it .
Just a guess.
Feb 14, 2017 | Electrical Supplies
Engine loses rpm
What is the year make and model?
Feb 19, 2014 | John Deere Kawasaki K Series Air Cooled...
I need the maitenance manual for your sdmo 500kva generators
Regular maintenance for generator is necessary that can help prolong the service life of the generator.
Generator Maintenance Tips
Generators
Generator Set Maintenance Tips
Useful Maintenance Tips for Diesel Generator Set
Maybe You Are Interested VOLVO generator Volvo Generator Volvo Generator Set Supplier Manufacturer Factory in China
Aug 30, 2011 | Computers & Internet
GET ME PART NUMBER FOR SDMO J40U GENSET RADIATOR UPPER HOSE
This genset was made for John Deere. Take off the old hose.. walk into any busy automotive parts source and they will match yours up to a NEW hose. Hoses do not care about what brands they are installed on. I could refer you to a SDMO dealer to get the PN but... the part in hand routine at an automotive parts source should get your going again ASAP.
Thanks for choosing FixYa,
Kelly
Apr 28, 2011 | Sewing Machines
My sdmo generator keeps shutting down temperature
Mar 28, 2010 | NEC Mitsubishi MGE 1800 Generator-Voltage...
The coleman voltage generator for 250 kva gen set
Well I assume that this generator is NOT three Phase, and delivering 440 Volts? in that case, that reading is what is called and "Open Circuit" reading, with a full load, that reading will/should come down to the nominal voltage of 250 V (+/- 10%) This generator is a 250 V AC unit? If this is so then it is operating correctly? It is 5kw UNIT. using a digital multimeter due to it's large input impedance it will often give erroneous readings if NOT loaded down with the correct.any. load.?
Mar 02, 2010 | Coleman Powermate Powermate 5000W...
I have an SDMO generating set with a Mitsubishi S3 L2SD engine it is supposed to run at 1500 rpm but goes up and down depending on load, if I set the rpm at no load to 1500 as soon as a load is applied the...
Cheers,
Carl
Sep 28, 2008 | Karcher 2500 PSI Pressure Washer
Electrical Supplies Logo
24 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
