Question about Vizio Televison & Video
Where is the t-con board in vizio m420nv tv - Vizio Televison & Video
SD Tech
  • 14553 Answers
SOURCE: vizio m420nv without a remote
Contact Vizio for part number by model number or Google the model to locate an original (universals are a waste of time and money and often are missing key features needed).
Posted on Apr 01, 2012
SOURCE: where is the t-con board located in a vizio 55in tv
The T-con is usually at the top center on the rear of the LCD panel. It usually has a metal cover over it.
Posted on Jul 25, 2012
bugoy31
  • 1238 Answers
SOURCE: vizio m420nv has sound but no picture
Hello there
Actually that problem is very common on all LCD TV,, that problem is cause of either inverter board or t-con..
In this case you don't need to check the voltage that is too complicated for you,,only visual check is enough..
I share you my tricks and hope it helps..
Power on your TV turn off your lights..if you will see the light comes from the screen the problem is t-con..if no light the problem is inverter board (backlight) board
Hope it helps..
Don't forget to rate..
Posted on Aug 25, 2012
Slinteriors
  • 8617 Answers
SOURCE: bad T-con board on my vizio tv
You can easially do it yourself only takes a couple of minutes to replace the TCON you can get replacement TCONs from www.tvrepairworld.com
Posted on Oct 23, 2012
gopakumarg43
  • 74251 Answers
SOURCE: Vizio tv model:E502AR
In fact; you have to replace the display panel too to make the TV a new one. Contact any service technician. It will be best.
Posted on Jun 16, 2015
My Vizio m420nv tv the left half of the screen has a yellow tint throught the whole screen. the right hand side is fine. Ive changed the T Con Board and didn't change anything. any ideas?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Dec 01, 2015 | Vizio m420nv 42 in. LCD HDTV
M420NV
Check and replace back-light inverter board. Check the input supply voltage to back-light inverter board. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact any experienced service technician, or the nearest service center.
Apr 23, 2013 | Vizio Televison & Video
Vizio M420nv LCD TV Black Screen
lightning can do extensive damage to electronics equipment especially flat panel TV's. I would really recommend a professional diagnosis instead of board swapping. You could have several boards that are damaged!
Feb 13, 2013 | Vizio m420nv 42 in. LCD HDTV
Vizio M420NV Wont turn on
I have a suggestion if you have and are using a box of some kind with this set, remove set and box from power for awhile and then power both back, sometimes a box can trigger this type of event, hope it helps and it cannot hurt to try.
Dec 11, 2012 | Vizio m420nv 42 in. LCD HDTV
Vizio m420nv has no sound or picture
High there!
I want to try this, change the video card ( video audio section ) of the TV
peace .
Apr 21, 2017 | Televison & Video
Vizio m420nv has sound but no picture
Hello there
Hope it helps..
Aug 25, 2012 | Vizio m420nv 42 in. LCD HDTV
Vizio m420nv without a remote
Mar 31, 2012 | Vizio m420nv 42 in. LCD HDTV
I just purchased a brand new M420nv 42 HDTV LCD LED and turned it on for the first time & the screen was white with blue vertical lines (very similar to a UPC bar code) on the left side of the screen. ...
For sure a defect. You are looking at a T-con board that is faulty. Return immediately and get a different one. If it's within 30 days just swap out and avoid having to wait for a warranty repair!
Please rate if this helped :)
Mar 09, 2011 | Vizio m420nv 42 in. LCD HDTV
Televison & Video Logo
26 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
