Question about Garden
Lawn tractor will only run in high gear - Garden
    New Friend:
If it is a geared, belt driven lawn tractor it more than likely may be a worn or stretched belt. When you use it in high gear, does it go the same speed as it did originally or is it slower?
No valve movement on 320 John Deere lawn tractor.
the jd 320 lawn tractor is fitted with a 2 cylinder water cooled vertical shaft Kawasaki engine
parts numbered -j59051 and , I 59051 show it as a gear driven cam shaft
I would be looking for the rocker arm bolts loose /stripped, bent push rods or the key or the key that drives the crank gear has sheared
May 02, 2017 | Cars & Trucks
Tractor starts. When put in gear and let off clutch motor stops. Thanks in advance.
On newer lawn tractors there is a safety switch on the seat. When in gear the seat presence switch must be engaged for the tractor to stay running when the clutch is let out,.
Check wiring connector to the switch. Seat requires minimum weight so child protected.
The following video provides insight to this problem, Read the first comment which describes a similar problem to yours.
How to test lawn mower electrical safety switches
Dec 23, 2015 | Garden
Starter wont engage on 1641 lt cub
sometimes the shaft that the gear rides on gets dusty dirty and the Bendix gear cannot slide up. Is that what you have? You can hear it spin but doesn't engage the engine? A week battery will do that too. Thees CC starters like their voltage high
Nov 10, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Peg Perego lawn tractor only works at 2 speed
Sounds like you either have a bad motor or a bad shifter switch, lift up the rear end of the tractor and then push the pedal and see if both wheels turn in high gear, if not then you have a bad motor
Nov 18, 2011 | Peg Perego John Deere Turf Tractor
I have a craftsman lt 1000 riding lawn mower and it runs, but it won't go into gear it goes into gear, but clutch won' engage the gear.
Look under the mower to see if the drive belt has come off or broke. It is the belt that runs from the bottom of the engine to the rear axle.
Oct 01, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My nelson lawn tractor won't move forward in low or high gear.
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
Aug 13, 2010 | Nelson Sprinkler: Traveling Tractor
42 in. Deck 19.5hp Lawn Tractor: Craftsman Lawn tractor my engine clicks but will n...
battery has a low charge or the starting gear on the starter is bad. just remove cover and see if the starter ingages and cranks the fly wheel. look at the gear itself to make sure the teeth are good ,if not replace the plastic gear. takes 5 min.
May 18, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
On a 1948 Ford 2N tractor, how high should the fluid level be in the transmission? Looking in the fill hole next to the shifter, it seems that the level is fairly low past the gears. How high should it be?
My brother has one of those tractors too so I called him and asked him and he said that he has his oil level up into the gears but he also said that you can go on Google and find out any info that you need on those tractors. Hope this helps you out somewhat.
Aug 31, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
62 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
