Question about Pioneer Cell Phones
I have a Pioneer FHX731BT, issues with the Bluetooth. once synced the music plays fine but when I answer a call my iPhone i have to turn the sound all the way to 60 to barely hear the person talking?
SOURCE: Ambient sound is louder than the music
I have a Mac (OS X 10.5.7) and had the same problem with the Ion TTUSB system picking up room noise. This seemed to fix it:
In System Preference, under Hardware, choose "Sound".
Choose "Input".
Under "Choose a device for sound input" choose USB Audio CODEC  type: USB
I hope this helps,
Cheers!
Posted on Jul 06, 2009
isaacwoodard
  • 54 Answers
SOURCE: H170 bluetooth headset - I can hear caller but
Because of the design of these headsets, over time the wire leading to the mic can wiggle and break loose, which allows you to hear fine, but prevents the listener from hearing you. My bet is that it's the red wire, as it tends to have more pressure placed on it. The dismantle process isn't easy (i'm working on the very same problem at the moment!) but if you'd like to try it and are able to do very fine resoldering I can share my notes with you. Otherwise, you're out of luck and will need to purchase a new headset. Sorry I can't give you better news!
Posted on Jan 28, 2010
vanherringto
  • 1738 Answers
SOURCE: motorola bluetooth instructions n136 pair with IPhone
Your headset may also be called a HS850 (may look different) but the instructions would be the same. Instruction manual is here:
http://www.motorola.com/mdirect/manuals/HS850_%209489A97O.pdf
Posted on Feb 04, 2010
SOURCE: Iphone 3G speakerphone and headset volume is too low
Whilst on a call in bluetooth mode change the volume. It needs to be for each different "speaker" you use
Posted on Mar 22, 2010
supernova278
  • 1932 Answers
SOURCE: i barely hear the person i am talking to is there
Yes you can turn up the volume,While on call press right navigation key to increase the volume and left navigation key to reduce volume.
Thank you
Posted on Nov 12, 2010
Sync my iPhone 5 music to the Motorola tk30 - there is no volume on the Motorola?!
Julia
First make sure the software is up to date. Motorola Support Find Answers Motorola Mobility Inc .
Then check the manual on page 22 about music play on iPhone. https://motorola-global-portal.custhelp.com/app/answers/prod_answer_detail/a_id/78862
How are you using it? Via Bluetooth?
Also make sure your phone volume is up and your stereo. If you just had it installed. Contact the professional installer to ensure it was installed properly.
Mark
Motorola Support
Feb 20, 2015 | Motorola Mobility Genuine Tk30 Music &...
USB port for iphone sync
The iPhone will sync to iTunes on a computer. If the display has a USB port, there must be another USB cord to the computer. The iPhone will go through it to get to the computer.
Apr 15, 2014 | Atlona ATNO-AT13033-2 - AT13033-2 6FT Mini...
Bluetooth connected to x5 but can't play music
You'll have to confirm this with BMW as we have a 650, 135, and X3 not an X5, but your car won't play iphone based music via bluetooth. It will sync contacts, make calls and some other things (particularly with the newer apps) but it won't play your music.
To play your music you have to have the package that allows you to connect your iphone via an iphone cable (usb at one end, iphone connector at the other - what you use to charge it). With this connected you can then see all your music and control your iphone through the screen on the dashoard.
Feb 07, 2013 | 2005 BMW X5
Paring iphone via bluetooth
If your phone is paired, you should be able to listen to music using the BT audio source.
Aug 19, 2012 | Pioneer AVIC-F900BT Car GPS Receiver
I have the Motorola H620 bluetooth and it is paired fine, phone answer and dial and voice activation works fine, but, music will not play through the headset. When I play my ipod app in my iphone, music...
1)this feature not availeble
2)go to this link 100% sure solve your problem http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones%20Accessories/H620/US-EN/_Documents/Static%20Files/H620_QSG_US_9518A57A.pdf
Nov 13, 2010 | Motorola Mobility H620 Bluetooth Headset
Sync iphone with plantronics bluetooth
Bluetooth on iPhone:
On iPhone:
1) Go to Settings
2) Go to Reset
3) Select "Reset All Setting" (Make sure you save passwords. Data is safe.
On Plantronics BT:
Clear all previous pairings.
Once iPhone reboots, turn on Bluetooth. Type in BT passcode.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 11, 2009 | Apple iPhone Smartphone
Same exact problem- music player works fine with headphones
If you had a bluetooth device connected and it did not disconnect properly then the phone may be trying to play the sounds to the bluetooth and not the speaker, Turn the phone's bluetooth off and then on and it should work. Also, if you look at a sound file or video file it will show the bluetooth symbol next to it, which means that it is playing to bluetooth and not the phones other outputs.
Jun 09, 2009 | Samsung Eternity Cell Phone
Help, i cannot put music on my iphone
I have the same issue. The best workaround is to create a playlist in iTunes specifically for the iPhone, and just have the phone sync that list.
Sep 20, 2007 | Apple iPhone Smartphone
Cell Phones Logo
73 people viewed this question
Top Pioneer Cell Phones Experts
William Alequin
Are you a Pioneer Cell Phone Expert? Answer questions, earn points and help others
