Question about Canon PowerShot SX40 HS Black 12.1 MP 24mm Wide Angle Digital Camera
Canon powershot sx40 hs
Power button won't work
Camera won't turn on
Assuming you have charged the battery to full. If you did not use the camera for a long time and left the battery inside then the battery terminals may have corroded.
Check user manual for possible problems with battery when left for long periods without charging.
https://www.lclark.edu/live/files/14568-canon-powershot-sx40-hs-manual
Aug 12, 2014 | Canon PowerShot SX40 HS Black 12.1 MP 24mm...
How do I reset my camera?
Look in your camera settings menu and you should find the "reset to factory settings" option.
Jun 03, 2014 | Canon PowerShot SX40 HS Digital Camera 2GB...
Windows 8 doesn't recognize canon sx40hs
Try installing the software that came with the camera on your computer first, then connect the camera to the computer.
Mar 11, 2014 | Canon PowerShot SX40 HS Digital Camera 2GB...
Why is my viewfinder black when the camera is on and able to take pictures using the LCD screen?
some camera will inactive the electronic view finder if you shot through the lcd monitor, try to find out in the manual book about shooting trough view finder.
May 04, 2013 | Canon PowerShot SX40 HS--Black
I Need a user manual for my canon powershot sx40 hs
You may download the manual and more from here.
Nov 05, 2012 | Cameras
Canon SX40 HS wont reset to factory settings
I own a same model camera but the problem you mention is new to me. I would try re-setting individual menus to their defaults first, then switch off the camera for sometime then re-start. This time, try the factory re-set option. This is no definite solution to your problem, but it;s worth trying because I had a smaller (pocket-size) Canon camera sometime back that worked that way.
Aug 18, 2012 | Canon PowerShot SX40 HS Black 12.1 MP 24mm...
Canon PowerShot SX40 HS Black 12.1 MP 24mm Wide Angle Digital Camera Logo
150 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
