SOURCE: screeching snow blower
On one side of your machine you will find a cover that you can remove, the belt for the auger is in there. From what I can see there is no adjustment. Check to see how the belt looks.If it's chewed up it will need to be replaced.If you remove the belt try to turn the impeler to see if it turns freely, if it doesn't then check to see if there is something wedged. if nothing is wedged and the belt is off and it still don't turn by hand it could posibly be a bad bearing.if it does turn by hand. Also check the belt pulleies to see if they are ok, the only pulley that will sshould spin freely is the idler pulley, the one on the engine shaft should spin the moter so make sure you pull the spark plug wire off to check that one, and the auger pulley should spin with the auger.
SOURCE: 2OO2 TROOPER HAS NO FORWARD GEARS, BUT HAS REVERSE.
First check you fluid level,if good have it flushed out with new fluid,if this does now work,time for rebuild,unless you know how to adjust the bands.
SOURCE: no forward gears just reverse
I had the same problem with my grandsons gator and I replaced the shifter switch. I called the peg perego department at 1.801.655.0800 and they sent me a couple of switches.
Hope this helps
SOURCE: My snapper mower only has two forward gears and no
Typically if your clutch is worn, you would experience some slippage in all gears. If your forward gears work, but reverse does not, you should be looking at a potentially more serious problem.
