Air handler fan doesn't turn on .. Replaced thermostat
ACTECH
  • 80 Answers
SOURCE: Replaced thermostat on FA4ANF030 with Honeywell model rth3100c does not work
if you have a newer t-stat your heat pump reversing valve is either o or b depending on the type of system you have
Posted on Dec 19, 2007
  • 306 Answers
SOURCE: the air handler won't shut off
As long as the t-stat fan switch is in the auto position the problem sounds like fan relay is stuck. It looks like a little black box about 2 inches square. Has 5 positions on it two of them are for 24 volts.
Be sure you turn off power before pulling it out. Make note of the arrangement of the wires maybe label as you remove them. ken
Posted on Dec 27, 2008
cactus bob
  • 267 Answers
SOURCE: fuse blowing on tappan air handler
most of the time its out by the ac unit . you have a shorting thermostat wire .. the outside unit has a large wire thats 240v and a small one that 24v thats the one you want to look at . look for bare wires , look where it goes into the wall , thats the common place . "critters" love to chew thermostat wire . so take a look . .....please rate this answer , i need votes . thanks
Posted on Jan 24, 2009
  • 24 Answers
SOURCE: where is the fuse box in the inside air handler?
There should be a small 3 or 5 amp fuse on the circuit board inside the air handler.
Posted on Apr 20, 2009
farfield
  • 462 Answers
SOURCE: The fan in the airhandler wont shut off.
The fan is controlled by a blower timer board located inside the air handler, or on older units it has a relay called (of all things) a blower relay. If these items were at fault I doubt removing the thermostat would cause the blower to go off. if bad causing this problem the blower would continue to run even with thermostat removed.
But it is also controlled by the thermostat.
You mentioned that if you remove the thermostat it cuts off. There are 2 switches on most thermostats.
1 has Cool, Off, Heat, and Emergency Heat (on a heat pump stat)
2 The other switch has On and auto (it is for the fan motor only)
I believe because it stops when you remove the thermostat that the switch on the fan is set to on possibly. It should be on auto-matic. This way the fan motor only come on with cooling or heating. If in the on it stays on all the time. If this is the case just switch to AUTO.
Or the thermostat may be wired wrong. The G terminal is where the fan motor gets instructions from the thermostat. Make sure its on G at the stat and the correct wire at the blower coil is being used for the corresponding wire going from the stat to the blower for G. Don't confues G for green it could be any color. The terminals are not for color but it makes more sence to make them color - letter identified. On the other end soemtimes the wires are not colored the same so look carefully.
Also a whisker of a thermostat wire could be touching inside the thermostat and causeing the motor to run 100%. Look carefully at this and see if it has too long of thermostat wires stickinhg on out under the screws to where they may tough other things.
If neither things stop or show the problem and it deffinately stops when thermostat is removed the thermostat is most likely bad.
If this helps you 1 way to make the repairs your\self or helps you realize you need a technician please rate mne as high as you can.
Posted on May 14, 2009
How do I fix my Trane air handler to keep it from turning off about 20 seconds after being commanded to turn on?
Some units require both a start and a run capacitor. It's possible the wrong capacitor was replaced. It's also possible to add a run capacitor to a system to keep the fan running. There is an outside chance the bearings in the fan motor are worn to the point it's time to replace the motor.
Mar 29, 2015 | Heating & Cooling
Carrier air handler/furnace won't turn on
from what your saying the motor is hot to touch if that is the case the motor is bad need to be replaced.
Nov 08, 2014 | Heating & Cooling
My air handler fan does not come on, the outside unit turns on fine. Is their a way to reset the fan?
Check for fan operation by turning the fan control at the thermostat to "on". If the fan blows, it works. If not, check a circuit breaker or fuse.
If the fan blows when forcing it on with the thermostat but not in automatic, check the fan control circuit in the air handler. Danger: high voltage, beware! There should be a system wiring diagram inside the air handler somewhere.
Mar 30, 2014 | Rheem 4 Ton Air Handler - RHLLHM4821JA
JUST REPLACED NEW COMPRESSOR AND NOW MY AIR HANDLER WONT SHUT OFF WHEN TSTAT SHOWA OFF
it is either miswired or the fan control switch on the thermostat is in the on position instead of auto position. hopefully its that simple
Sep 07, 2012 | Heating & Cooling
WIRING THE THERMOSTAT TO AC UNIT THEN FROM THE UNIT TO HANDLER
Generally, you would go from the thermostat to the air handler, and then, from the air handler to the outdoor unit. I don't know if you have a heat pump or not, so I will give you a simple diagram and you can contact me if you need more.
Thermostat : Y G R W and sometimes C
Air handler: Y G R W and C
Outdoor unit: two wires connecting to the contactor ( not heat pump)
Thermostat; Y--------------Y(air handler cooling)------------------one side of contactor, outdoor unit
G-------------G (air handler, fan)
R--------------R (air handler ,hot)
W-------------W (air handler, heat)
C--------------C (air handler, common)------------other side of contactor, outdoor unit
This is a typical wiring diagram. Just contact me if you have something different. Hope this helps. Stay cool. mark
Jul 10, 2011 | Heating & Cooling
My Rheem Air Handler runs all the time,a/c works fine and cools the house but I want the air handler to kick off when not in use. It's model RBHA-14J00NFRA Volts 208/240VAC PH/HZ 1/60
IS your thermostat set to automatic on the fan switch? If so then you may have a stuck fan relay in the air handler. If it has an electronic control board the relay is on the board and the whole board would need replaced. If it is not a stuck relay then you could have a crossed wire from the thermostat to the air handle, usually the green wire from the t-stat, it could be crossed with the red wire that supplies 24 volts to the t-stat.
Jun 17, 2011 | Heating & Cooling
What supply house sells haier air handlers in Atlanta ga
any 4 tonnes air handler will fit if you respect de gas for the unit if r22 than than r 22 air handler if r410 than r410 air handler you can put r410 air handler if r 22 not avalable but be sure that expension valve is compatible.
Dec 13, 2010 | Haier HC48C1VAR Central Air Conditioner
My air handler fan will not come on during heating but will operate during cooling - Anerican Standard unit TWEO65E13FBO
Please check the thermostta first. Take the thermostat to the air handler and hook up on a short thermostat leash. The unit should work properly, then its for sure that the problem is going to be in your thermostat wiring. If problem persists then we are troubleshooting a thermostat.
Let us know if you need further assistance.
Thanks for contacting Fixya.com
Jan 12, 2010 | Heating & Cooling
Changed batterys in the tstat now air handle will not run
Turn the Fan switch to On, if the fan does not run,
either the thermostat is not telling it to run or you have blown a mini fuse in the air handler, assuming
you have no readout at thermostat.
disconnect thermostat wires and try to Jumper between R and W or W1. Remember to shut power
off before you start. If the air handler starts the
problem is either ther thermostat or thermostat wire.
Jan 11, 2010 | Heating & Cooling
Lennox CB26UH Air Handler stopped running
Do you mean the air handler fan doesn't run but the outside part runs? If that is the problem, try turning the fan blade with a stick. If it turns freely, you have an electrical problem. It could be a relay, a bad motor winding, a bad capacitor, or a bad thermostat, among other things. If the fan won't turn, the motor needs to be replaced.
Jul 23, 2008 | Heating & Cooling
Heating & Cooling Logo
20 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
