Question about Saws
I need to replace a KOBALT 15 inch aggressive tooth handsaw blade. I was told to throw the entire saw away and just buy a new saw ... REALLY? Do you sell just the saw blade?
    Top Expert:
  • Saws Master
  • 49,198 Answers
Fixya site sells nothing
you can get new blades from a good tool shop or take the old band to a saw sharpener shop and have a new one made
the band length and width and will be on a decal under the lid that covers the band or on the machine somewhere
failing that , use a tape measure and measure the distance around the wheels ( as it if is a band) and that will be the length and then measure the width of the wheels and that will be the width of the band
make the measurement with the band tension adjustment all the way in so that if the band is a touch longer you can adjust the tension up
Posted on Dec 27, 2016
Testimonial: "thank you very much for your help"
    Top Expert:
  • 78,267 Answers
This site does not sell anything.
I need a replacement left-handed bolt to hold the blade on a Kobalt rorary saw
You'll need to order one from Kobalt for around $23 plus $10 fer delivery. Happened to me once and when l found out how much it was gunna cost l told the salesperson to stuff it up their a$$ and threw it out and bought a new machine off ebay.
Nov 16, 2017 | Blade Saws
Need a blade guard for kobalt miter saw 0358938
Fixya does not sell blade guards for Kobalt miter saws.
Oct 11, 2017 | Blade Saws
I need a arbor nut and washer for a kobalt 10 inch table saw model kt 1015
First try Lowe's, the only Kobalt tool retailer. If they can't help you, the Kobalt customer service number is (888) 356-2258. I looked for Kobalt power tool parts onlline without success. That may suggest that their one-and-only retailer is the only source, or it may mean you should look for a replacement saw, basing your choice on likely future parts availability.
Oct 04, 2017 | Saws
Buying a Kobalt reciprocating saw quick lock replacement
Fixya does not sell replacement parts.
Sep 02, 2017 | Blade Saws
How do you adjust the laser from side to side on a Kobalt 10-in 15 Amp Slide Compound Laser Miter Saw
goto https://www.lowes.com/pd/Kobalt-10-in-15-Amp-Single-Bevel-Sliding-Laser-Compound-Miter-Saw/3512785 and scroll down to guides and documents download PDF
Dec 22, 2017 | Measuring Tools & Sensors
FB14593DB Flex Back Band Blade 1/4" X 93 1/2" 6TPI Skip Tooth
I buy my band saw blades on www.sawblade.com. I have a great experience with them. They custom made band saw blades -German Engineered but USA made. They have centers in CO, TX and KY . You can get their Flex Back Carbon 7 ft 6 inch 1/2" 6TPI blade for as low as $11.69 . Call them.
Oct 25, 2013 | Olson FB14593DB Flex Back Band Blade 1/4"...
How to put the blade into the black and decker 3.4 amp powered handsaw
#1) You have to locate the blade release button on the saw (see your manual). The opposite side of the release button is a screw-like OVAL shaped PIN. To insert the blade, the direction( or position) of this OVAL shaped PIN has to match the OVAL shaped hole in the blade. You could use a screw driver to change the direction/position of this OVAL shaped pin. You have to push down the release button when you use the screw driver to turn.
#2) Hold the blade in Vertical position in your right hand. The "Oval" hole is on top. The teeth is facing your left hand. You will see that the "oval" hole on the top of the blade is a "horizontal" oval.
#3) Hold the saw (handle) in your left hand as if you were going to saw using your left hand.
Now peek through the hole of the saw and find the direction of the OVAL PIN. It has to be a "horizontal" (or lied down) OVAL. If it is not, use the screw driver to adjust it.
#4) Hold the blade using your right hand. Oval hole on top, teeth facing your left hand. Insert
the blade from the bottom of the saw. What you needed to do is to insert the PIN into the hole
of the blade. When you inserted the pin into the hole of the blade, slowly turned the blade upward, the blade will lock by itself.
Oct 15, 2013 | Black & Decker PHS550B Powered Handsaw...
New blades, new belt.. burning the wood when I try to maky any type of cut
Is the blade the correct one for the type of wood you are cutting?? There will be recommendations on the saw blade. Finer toothed blades are for plywood, etc. Aggressive or large tooth blades are for thicker wood.
May 15, 2012 | Craftsman 10" Table Saw
I have an old Sears Craftsman 7" Electric Handsaw model #315.27782. The blade I use for fine sawing has begun to wobble. I've taken it off, put it back on and tightened it several times. Same wobble. ...
It could be that the bearings that support the shaft that holds the blade are worn, allowing the shaft to move slightly and make the blade wobble. As the machine is an older model, I would try replacing the bearings.
Sep 16, 2010 | Craftsman Saws
I just purchased the ryobi 9 inch bandsaw, used it once or twice and have noticed that the teeth on the blade are crooked. is that a typical problem, is it a problem at all?
If you mean that the teeth alternate sides in which they point, this is normal. This aids in the blade clearing cut material from the path of the blade making sure it does not clog. Almost all saws for wood have this tooth pattern. If you have doubts look at a new replacement blade for the saw.
Jan 19, 2010 | Ryobi 9 in. Benchtop Band Saw
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
