I have cm6200 with a remote. I used to be able to start car go to the store press the remote so it would stay running I remove the key I cannot do this again anyone know the remote input to do this
Its a 4 button remote
  • yadayada
    yadayada Dec 27, 2016
    This is a very unsafe practice.
Benimur
  • 6966 Answers
SOURCE: Saturn wont start
Intermittent problem such as what appears that your car has is at best be describe as a test of patience.
Initially would appear to be electrically related. Based on your post/description, pls try and check the ignition wiring (going to the ignition switch behind the tilt lever) along the steering column.
Of course the normal checks should also be considered, battery, battery cables, fuse and fuse box (both in the engine bay and driver side of the center console), relay bank, harness and connectors. Manual cleaning and a spray of electrical contact cleaners should also be performed when in doubt.
Though the technically correct procedure would be to have your car's computer checked/scanned and the readings interpreted.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 13, 2008
  • 8 Answers
SOURCE: 1999 SL2 wont start
you most probably have a flat spot on your starter, changer the starter
Posted on Jul 24, 2008
Duncan
  • 218 Answers
SOURCE: JVC KD-G351 question
It sounds like your stereo is working properly. I've never seen a car stereo that was wired properly that you could turn on and listen to while the car was off with the key removed from the ignition switch. You would have to move the ignition switch to the accessory position in order to get the stereo to work. Hope this helps. Good luck. Mike D.
Posted on Aug 21, 2008
  • 5370 Answers
SOURCE: 2005escalade remote starter
Either the remote keyfob is faulty or it needs reprogramming.
Keyfob remote not working ?
http://technoanswers.blogspot.in/2012/01/keyfob-remote-not-working-on-2003-ford.html
KeyFob will open the doors but not start the car?
http://technoanswers.blogspot.in/2012/02/key-will-open-doors-but-not-start-on.html
Key Fob will not lock and unlock doors? http://technoanswers.blogspot.in/2012/02/key-fob-will-not-lock-and-unlock-doors.html
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks
Posted on Feb 18, 2012
ercupa190
  • 12223 Answers
SOURCE: Pro-form 370e crosswalk treadmill when the start button is pushed it starts up then stops immediately.
1)Lube the deck belt, this a problem by lack of maintenance, this produce enough friction and shut down the machine, by protecting the electronic system.
2) Test the input voltage motor, if there are voltage, the motor need repair.
3) Test the output voltage board, for input voltage motor, if there are NOT voltage the board is faulty.
God bless you
Posted on May 16, 2012
My Cadillac cts 04 won't start... Every time I turn the key it won't even turn over... But the light that shows a car with a lock on it blinks what do I do
Sounds like the anti theft system is active m try this process. Turn the key on. Do not attempt to start. Wait 10 minutes. Turn key off. Turn key on. Wit for theft light to go off. Now attempt to start.
Oct 25, 2016 | Cadillac Cars & Trucks
Immobilizer fault on a Picasso hdi 2001 car starts
Take to dealer to reset the key code on the ignition key.
Oct 08, 2013 | Magnum Remusshield Finger Touch...
On my bmw2006 330i it seems that the ignition is not really off after stopping the car. After stopping the engine with the start/stop button and removing the remote key from the slot, the button remains...
In your car the engine starts this way: a code stored in the remote key is sent wirelessly to the receiver in the receptacle (thru its coil antenna) which sends it to the ECM to activate it; then the starter button sends the command for the actual starting.
In your case the receiver appears to keep the code in memory when it shouldn't. Have it replaced. BTW this has absolutely nothing to do with the ignition coil.
Sep 12, 2011 | 2006 BMW 3 Series
Need codes for philips universal remote to program to a deawoo tv
Hello
There is no set up code described in the manual of your remote control. But you can find out the code that stored in your device with this remote control handset. For that do the following.
The Code Identification Feature allows you to identify
the 4 digit library code stored under your device key. For
example, if you want to find out what 4 digit code is
stored under your TV device key, follow the six steps
below:
1. Press and hold the SETUP button until the red
indicator stays on. Release the SETUP button.
2. Press and release the desired mode button (TV,
VCR, etc.). The red indicator blinks, then stays lit.
3. Press and release the SETUP button. The red
indicator blinks off.
4. To find the first digit for the code stored under the
mode key pressed in step 2, press each numeric key
from 0-9 in turn. When the red indicator blinks off
the number you pressed is the first digit for the code
you are searching for.
5. To find the second digit, repeat step 4, this time
when the red indicator blinks off this is the second
digit.
6. Repeat step 4 to find the third and fourth digits.
Write these digits in order and you will get the code of your device.
Direct code entry mehod.
indicator stays on, then release the SETUP button.
3. Enter the 4 digit code from the code tables (on
separate sheet). Note: after a valid code entry, the
red indicator turns off. For an invalid code, the red
indicator flashes.
4. With your device on, press CHANNEL UP. If the
device responds, no further programming is required.
Note: If some buttons do not operate your equipment,
try one of the other codes for your brand.
OK.
Feb 19, 2011 | Philips SRU3003 Remote Control
I have a viper remote start that came with the used i car i bought, the remote start worked great for the first few months of winter, now when i start it up, it runs for 2 seconds then dies, takes up to 6...
Your alarm may have lost the tach signal, that was learned to it, when it was originally installed. That would cause the remote start to try starting the vehicle over and over again, until it finally stays running, because it can't read the engine speed to know it's running.
If you can find the valet push button switch in your vehicle, try this; Start your car with the key and immediately after it starts, press and hold that valet push button switch until the alarm led on the dash stays lit up or the park lights flash. Then, release the valet switch, shut the car off and try remote starting it. That is the procedure to re-learn the tach signal. Hope it works for you.
Feb 10, 2011 | Remote Start System
Starter will not engage anti theft light is on it is a 2005 cobalt
I found this on a website try this
1. Put the newly cut Master key into the keyway and turn it to the ON (RUN) position. A "security" indicator
light on the dashboard will stay on for 10 minutes.
2. Within 1 minute after the indicator light goes off, turn the ignition to "OFF", then return to the ON (RUN)
position. The indicator light again will stay on for 10 minutes (Do not remove the key.)
3. Again, within 1 minute after the indicator light goes off, turn the ignition to "OFF", then return to the ON
(RUN) position. The indicator light again will stay on for 10 minutes. (Do not remove the key.)
4. When the light goes off the third time, the new key is programmed into the computer and will start
the car. Remove the key and then re-insert it into the ignition lock and start the car.
All previously stored codes will be erased. To stop the process at any time, simply remove the key and use
an existing key to start the car.
Mar 25, 2009 | 2007 Chevrolet Cobalt Coupe
I cant start my car with the remote starter
You normally have to while the car is running transmition in neutral push the brake pedal, put the emergancy brake on, release the foot brake, press the remote start button on the remote, take keys out of ignition switch, car should stay running, get out, press the lock button on remote starter remote, car should shut off, and now is set
Feb 05, 2009 | 2002 Hyundai Accent
We have a 2007 Entourage and you cannot lock it with the car running. We installed a remote starter and it will not lock the doors when it is remotely started. Can this feature be disabled?
i think that this is to prevent you from locking your keys in the car with the engine running.
Some remote starters have a feature that when the car is running (and in park) you can hit the remote start button twice for one second each - then you can take the key out of the ignition and still have the car running.
At this point....if you would hit the 'lock' button on your door the doors would immediately unlock. However, if you get out of the car and close the door leaving it unlocked and then you hit the 'lock' on your original car remote the doors will lock and stay locked. So now the car is running the doors are locked and you have the keys in your hands. Then you can run into the store or house real quick with your car locked.
Once you come back, you hit 'unlock' on the original car remote. the doors will unlock - you can get it - and then before hitting the brake put the key in the ignition and turn it (dont crank it) as if you had when originally using the remote starter.
Maybe this will work for you.....
Oct 14, 2008 | 2007 Hyundai Entourage Limited Minivan
Central locking system
I have recently had this problem I believe this to has been caused by a fault in the drivers door lock assembly It seems this contains the remote receiver. In my case I think there had been some radio interference being the main cause. The remote system seems to be working OK, The door lock will still not operate with the key.
Remove and replace the fuse 25 resetting the ignition module. Starting the engine, switch off remove the key from the ignition, stay in the car lock the doors using the door button, press and hold the remote unlock button for approx 5 seconds, listen to see if you can hear the clicking of the door receiver when you press the remote buttons. Press and hold lock/unlock button. You may be lucky.
Jun 05, 2008 | 1999 Volvo S80
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
