Question about Empire Heating & Cooling
Empire wall heater backfiring - Empire Heating & Cooling
  • 69 Answers
SOURCE: wall heater burners wont ignite
you may have a bad gas valve
Posted on Dec 19, 2008
techcrazy
  • 72 Answers
SOURCE: does not put out enought heat
Hi this is tech crazy
the solution and reason to the problem mentioned by you is as follows:
As cold water comes in, it remains at the bottom of the tank because it is denser than hot water. If you use the hot water faster than the heating elements can heat the incoming cold water, and if you consume all of the hot water that the tank holds, you run out of hot water in the middle of your shower. If this seems to happen too often, it could mean that the bottom heating element in an electric water heater has burned out or that your water heater is too small for your house. Or it could mean that you are taking really, really long showers.
Hope this helps u a lot
Please do rate me on the above said solution
Posted on Feb 04, 2009
  • 79 Answers
SOURCE: empire wall heater with wall vent pilot light
It sounds like the gas valve is dropping out. Make sure the system is venting the exhaust(no restrictions). Then make sure all your wiring connections in the unit are tight. In a millivolt system if all wiring connections aren't tight and clean your circuit will drop in millivolts and the gas valve will drop out. The gas valve requires a certain millivolt to stay open. I hope I was of some assistance!! Good luck!!
Posted on Nov 29, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Our new Empire wall heaters are loud. Do they
Rinnai are the quietest I know of. Rinnai.us
Posted on Mar 01, 2010
SOURCE: HOW TO LIGHT PILOT ON EMPIRE CORCHO WALL HEATER
I have tried to light my empire wall furnace by pressing the button and I have the gas on and it won't light
Posted on Oct 09, 2010
Empire heater is lite but wont come on
have you check the switch if it is break ?or maybe it has used for a long time .it was out of work .and couldn't discover .you should change a new one.
wall light
May 03, 2012 | Empire DV-35 Heater
EMPIRE MANUAL DV2353SG
I believe all the Empire manuals are there to download or read at their website: EmpireComfort.com.
Nov 08, 2011 | Empire Direct Vent Wall Furnace;...
Need an electrical diagram for an empire WFA 35s wall heater. It is at least 30 years old. Thanks
Unfortunately, Empire Comfort Systems hasn't made that wall heater in years. Never the less, you may get lucky by calling Empire direct @ 800-851-3153 and ask for Technical Service. Maybe one of the old timers can help you out.
Jan 16, 2011 | Empire Heating & Cooling
I nee an owners/installation manual for an Empire BF-30
Try this link for the owner manual:
http://files.totalhomesupply.com/data/Empire/Heaters/blueflameseries/BF-102030user.pdf
Oct 13, 2010 | Empire ECS BF-30 Infra-Red Wall Mounted...
Empire Wall heater; model 0630500; lot 403F272
lowes and home depot sell universal thermocouples.
Mar 13, 2010 | Heating & Cooling
Empire wall heater with wall vent pilot light
Nov 29, 2009 | Empire Direct Vent Wall Furnace Millivolt...
HOW TO LIGHT PILOT ON EMPIRE CORCHO WALL HEATER MODEL R 15
Oct 17, 2009 | Reddy Heater RLP100 Portable Forced Air...
Wall gas furnace
look inside the control panel of the heater. look for a 120 volt to 24 volt transformer.  There may be a fuse on the transformer secondary.  The thermostat switches a hot 24 volt wire so you won't find a common at the thermostat.
Nov 13, 2006 | Empire GWT-25 Wall Mounted Panel Heater
Heating & Cooling Logo
27 people viewed this question
Top Empire Heating & Cooling Experts
paulcarew
rudyjoe
Level 1 Expert
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
