Question about Janome Sewing Machines
Janome 8900 first attempt zig zag - using two different colored threads to see the stitch- the back of fabric, stitch color is more top thread than bottom, even though the stitch itself looks okay.
Tension setting is auto but bottom zig-zig is half bobbin color half top thread
  • Janome Master
  • 12,241 Answers
The upper tension is too loose. The two threads should meet in the middle of the fabric for the tension to be correct.
Posted on Dec 27, 2016
What stitch should I use to sew stretch cotton fabric
Hard to tell because your machine is unidentified.
Jul 14, 2017 | Sewing Machines
When zig-zagging on raw edge stitches bunch
Use a different stitch, use the triple zig zag or serpentine stitch so he needle is going through the fabric three or four times as it swings left to right.ma plain zigzag, because thread is tensioned, will pull lightweight fabric up. Try another raw edge finish, such as french seams, pinking shears or overcasting stitch. Of course for professional looking seams an overlocker (serger) is the answer as it has blades that trim the fabric edge and neaten with 2, 3 or 4 thread seam, encasing the raw edge.
Sep 26, 2014 | Elna 3210 Mechanical Sewing Machine
Raw edge zig zag stitch bunching underneath
When zig zagging over a raw edge, the tension on the thread will pull in the fabric, especially in lightweight cottons or even lighter organza. Its not the best edging method for very light weight fabrics. You can try using a smaller zig zag, loosening off the top tension a little bit. Or if your machine has it, use the triple zig zag or serpentine stitch, where the needle goes through the fabric three times to make up each zig stitch, this stitch is better for edging most fabrics and is my preferred stitch.
The machine is not stitching correctly,especially on zig zag # 3 stitch selection. I put two different thread colors and the zig zag on the front and back of fabric are both the bobbin thread. Now the...
If the bobbin thread is coming up to the top, then the thread is not under tension correctly. I think that this is a top loading bobbin so the bobbin will go into the bobbin holder, then you pull the thread back and press it into a tension device - should hear it click into tension. Now pull the thread back towards you and it should not come out of the tension. The bobbin should turn anticlockwise as the thread is pulled from it.
These bobbin holders usually will have a small adjustment dial on them and it should have the standard setting marked in red. It is very unusual that you would need to change this but check that it hasn't been messed with perhaps. If you have the machine manual check where they say the dial should be set. More likely that the thread is just not into tension fully or at all.
The manual may give you other troubleshooting tips too.
A good resouce is www.sewing.about.com for general machine tips, cleaning and threading issues.
Hope this helps.
Apr 11, 2011 | Bernina BERNETTE 65 Mechanical Sewing...
Pulls bottom colored thread to top...how do I ajust New Home 8000 trying to zig zag and bottom thread pulls color to top....
The bottom thread is the bobbin thread and it is suppose the pull the top thread slightly to the bottom/center of the layers of fabric.
Try a lower tension setting and a tear-away stabilizer or sheet of printer paper under the fabric to see if this will help hold the top thread down into the fabric.
Mar 27, 2010 | Sewing Machines
I have been using the zig zag stitch for appliques and all of a sudden the bottom thread which is a different color is showing on the top. I have rethreaded top and bottom threads, changed needles, cleaned...
it sounds like no bobbin thread tension. there should be some resistance when you pull on the bobbin thread. if there is none or too little you may have some lint or thread caught behind the bobbin case tension spring.
very carefully try and push the tip of a thin pin into the bobbin case tension spring and pick any accumulated thread or lint out.
if the bobbin case spring is clean, try tightening the bobbin tension a little at a time until your zig zag looks ok.
of-course all this is done after checking needle threading and needle for damage.
scott.
Jul 29, 2009 | Janome Sewing Machines
No zig and cotton keeps breaking
Make sure you have a new sharp needle installed for both problems and sometimes you need a particular kind of needle for the fabric. Also some machines don't deal well with 100% cotton thread. For some reason it gets caught up in the machine somewhere and breaks. Gutterman and Metrosene make excellent although slightly more expensive threads. Coats and Clark thread is good too. They make an all cotton thread but it doesn't come in as many colors. If you have the old spools of cotton thread from Walmart, just use them for topstitching if you need the color. Other wise, use them for hand stitching or throw them away. One more thing that I can think of off hand, one of my machines does not like lining fabric. For some reason the thread breaks if I stitch really fast. If you have to use that thread, you may try sewing slowly. One more thing, when was the last time your machine was serviced? This can make a huge difference if it's been awhile and you use the machine a lot. Good luck. Hope any of this helps.
Apr 01, 2009 | Janome Sewing Machines
Zig zag stitches are not holding
When ever a machine is jamming up the bobbin thread, it is a result of your top tension. It is either set to low (under 4), or the thread has come out of the take-up lever. Check your threading, fromt he spool pin, down to 2 and up to 3. Three is the take up lever. From the take-up lever down to 4. Set the thread behind the thread guide and thread the needle form front to back. Low quailtu thread 9dual duty or all purpose) can also create this problem.
thanks,
Bonnie
Aug 24, 2008 | Kenmore 15516 Mechanical Sewing Machine
Suddenly zig zag stitch not working?
Because it is almost a straight stitch but the needle continues to move in a zig zag fashion is reason to believe it is in a long stitch. By changing the number of stitches per inch there will be a very noticeable looking zig zag stitch.
Mar 25, 2017 | Brother XL-2610
Sewing Machines Logo
35 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
