Question about D-Link Vonage-enabled Wireless Router (VWR-VR)
Router does not save settings
All the routers produced in this line must be faulty then, mine doesn't save settings either.
    President:
  • 1,566 Answers
Try to reset it into factory defaults.
Posted on Jul 21, 2009
Need to reset my password for wifi as I've forgotten mine
Connect pc to router using lan cable.
Open browser.
Type the router's lan ip address. (most manufacturer use 192.168.1.1 but it could be different in your case. Check your router's instruction manual.
It will ask for a username and password. (by default both is set to admin. But it can be different in your case. Check the manual)
Now in the router interface page,go to wlan settings or something like that. There you can change your wifi Password.
Now save your settings.
Done.
Apr 27, 2016 | Computers & Internet
Tip
Save/Backup Settings does not work on F5d7234 V1 router
On the F5D7234 version 1 in the firmware 1.00.01 with which the router was released the feature to save the settings does not work correctly. When you try to use the feature it will produce a Page Cannot be Found error on Internet Explorer or a blank page on Firefox.
Workaround: click the Save button to produce the error or the blank page, now the address bar of the browser will show: http://192.168.2.1/userconf. Change this to http://192.168.2.1/user.conf, i.e. put a dot between user and conf and press Enter. The settings will now be saved as usual.
on May 05, 2010 | Computers & Internet
What is the default password for cisco
There are two main methods to return a Cisco router to its original factory defaults. These two methods are described below.
Method 1
1. uses the config-register 0x2102 command in global configuration mode.
2. Check the configuration register on the router by issuing the show version command.
3. The configuration register setting is displayed in the last line of the show version command output and should be set to 0x2102. If this is not the case, enter the config-register 0x2102 command once in global configuration mode.
router#configure terminal
router(config)#config-register 0x2102
router(config)#end
router#
4. If the show version command is issued again, the same line in the command output will have '(will be 0x2102 at next reload)' appended to the current register setting.
5. Erase the current start-up configuration on the router with the write erase command.
Reload the router with the reload command. When prompted to save the configuration, DO NOT save.
router#reload
System configuration has been modified. Save? [yes/no]: n
Proceed with reload? [confirm]
Once the router reloads, the System Configuration Dialog appears.
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
The router is now reset to the original factory defaults.
Method 2
1. uses the config-register 0x2142 command in global configuration mode.
2. Enter the config-register 0x2142 command in global configuration mode.
router(config)#config-register 0x2142
This causes the router to ignore the start-up configuration on the next reload. If a show version is issued, the last line in the command output will have '(will be 0x2142 at next reload)' appended to the current configuration register setting.
3. Reload the router using the reload command in enable mode. It is not necessary to save when prompted to save the system configuration.
router#reload
After the router has reloaded, the System Configuration Dialog appears.
4. Enter no to the question "Would you like to enter initial configuration dialog?"
5. Change the configuration register setting to 0x2102 by entering the config-register 0x2102 command once in global configuration mode.
6. Issue the write memory command in enable mode to overwrite the existing start-up configuration with the current running configuration.
7. Reload the router with the reload command in enable mode.
Once the router reloads, the System configuration Dialog appears.
Note: The configurations below are stored in ROMMON, and cannot be reset to Factory Default Settings by the write erase or config-register 0x2142 commands.
warm-reboot
memory-size iomem <not default>
Jun 18, 2013 | Computers & Internet
Changining my wifi passphrase
connect your pc to the router with ethernet cable.
open web browser and in the address bar type 192.168.1.1 (if this doesn't work try 192.168.1.2)
you should get your router's home page.
when asked for user and password type admin for both.
if that doesn't work try admin and password
go through settings to where the password is and change it.
save the changes and you're done.
Oct 31, 2012 | Cisco Computers & Internet
My Dlink router doesn't work.. I click on save settings on the site but it doesn't save. I want to add a password and change the name but its not saving to can anyone tell me what's going
  • Open command prompt->type ipconfig and enter.check default gateway.
  • Put the default gateway in the address bar in Internet Explorer and enter...then you will get the router login page.
  • Enter the default username and password for login.
  • select the "Wireless Settings" link on the left-hand side.
You can follow this blog for more information to set name and password-http://wireless-support-squad.blogspot.in/2012/07/how-to-configure-d-link-di-524-wireless.html
Sep 04, 2012 | D-Link Computers & Internet
Need the security key password for wireless linksys WRT54G router.mine don't work
The default username and password are as follows:
username: (leave blank)
password: admin
If that doesn't work, you can factory restore the router by doing the following:
1. Unplug the router
2. Hold in the reset button for 30 seconds
3. Plug the router back in and continue holding in the reset button for another 30 seconds
Note that this will reset all of your router's settings to default and you will lose any of the stored settings you have, but it will reset the password to the default I listed above. Hope this helps!
Aug 26, 2011 | Linksys WRT54G2 Wireless Router
To change password
Open new internet explorer tab and type
http://192.168.1.1/ (If it doesn' ask for username and password try below address)
http://www.routerlogin.net
Ckeck if it asks for username and password
If ask give
username : admin
password : password
Now will be navigated to router configuration area
Now our next job is to navigate to wireless settings ( left side)
security option click on wpa/wpa2
now on passphrase enter new password
click on save button to save the settings
That'a all
Note: all devices that is connected to router via wireless will loose the connection . Now you have reconnect it using the new password
Thanks
Vote me if you are satisfied with my answer
Mar 22, 2011 | NetGear WGR614 Wireless Router
Hi,i was trying to configure my wii to the router and somewhere along the line i messed up the settings that connected the router to laptop. i tried deleting it from the laptop + then connecting it to the...
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Dec 07, 2009 | Zoom X6 (5590) DSL Modem (55900003)
Cell phone interfers with router takes modum off
You need to change the wireless channel on your router. I believe your router is set to Auto channel. Open the router's setup page by going to http://192.168.2.1 and look for wireless tab. Change the channel to 11 and save the settings. The reboot your router. It should't interfere with your cellphone now.
Oct 22, 2009 | Belkin (F5D5231-4) Router
Not working
Go into your routers settings, usually by typing it's ip address in your web browser and save all the settings to your hard drive or make a note of all the settings. Look to the connections menu and see if your ISP's ip address and dns servers are showing and not showing noughts, if it does show noughts your isp is at fault, if there is dns server numbers showing,look to see if there is an option to restart the router, if restart it and try again. On the router normally at the rear there should be a hard reset button which should be held in for atleast 10 seconds and let the router reboot. If non of this works, then the router is probably faulty
Apr 21, 2007 | Actiontec GT704WG Wireless Router...
D-Link Vonage-enabled Wireless Router (VWR-VR) Logo
471 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
