Question about Air Tools & Compressors
Nail stuck in a Bostitch lpf28ww - Air Tools & Compressors
  • 3 Answers
SOURCE: Stanley bostitch coil nailer gun
check the safty shaft and see if something could be under trigger safty causeing it to fire.
Posted on Feb 20, 2009
comax
  • 154 Answers
SOURCE: Leak inside Bostitch N80 Nailer, won't drive nails
If the unit is leaking it most likley need a rebuild kit. Go to a Bostitch service center and ask for an ORK-11 kit. That is all the o-rings needed to do an over haul. Or just have them do it.
Posted on May 28, 2009
  • 497 Answers
SOURCE: contact head won't retract...seems to be stuck
Two things come to mind, both require disassembly.
First i would clean the area, and then relube the contact head. While cleaning that area and relubing, check the o-ring and the surrounding seals, they may be not properly alligned or sitting perfect.
Posted on Aug 10, 2009
  • 4 Answers
SOURCE: bostitch n80 does not feed nails
make sure that the feeder spring is not broken this stops nails or can jam them or cause them to skip. Some nail gun types work bette if you buy their brand of nails, but it could possibly just be dirty or maybe check the nail size. You should also have a way to adjust how far your nails are in the bucket where you put your nails, it should go up or down by spining it.
Posted on Aug 13, 2009
SOURCE: Bostitch Nail Gun wont release and shoot nail
I had purchased a bostitch bt200 and am just now trying to use and after loading the nails 18ga 2" brads made by bostitch connecting to a small compresor that had 20 psi I pushed the nailer flush with the board and pulled the trigger and had no nails ejected. Is there something else I needed to do, manual was read.
Posted on Sep 07, 2010
I have a new Bostitch F21PL framing nail gun. I used it for the first time on Saturday and it worked flawlessly through the first half-dozen nail sticks. Then, it jammed. The culprit nail was easy to...
when you removed the jammed nail did the piston driver move back into the rear position? if not there may still be a piece of the nail holding the piston.... If the piston is stuck in the forward position with the air disconnected use a hinge punch and tap it back, reconnect air and give it a try
Sep 23, 2013 | Stanley Bostitch F21PL Nailer
What degree nails are used in stanley bostitch n60fn nail gun
I've repaired many nail guns and I can tell you the Stanley Bostitch N60FN uses 15 guage nails from 1 1/4" to 2 1/2" long in the FN1500 series of Bostitch nails. Nowhere does SB or any of their aftermarket dealers list what the angle of the nails is. I do know most of the SB nail guns that come through for repairs are because of damage to them from using other than SB series nails.
Oct 01, 2012 | Stanley Bostitch Nail Gun
How do i get stuck nails out of a bostich nailer gun
This would depend upon where the nail is stuck. Click on the link below to get to a site that has the complete diagrams of the unit. Enter the model number and you will get the diagrams with part numbers and costs should you need parts.
Dan
Link: http://www.ereplacementparts.com/bostitch-parts-c-29443.html?gclid=CPalnuStwKMCFUWC5Qod0XDcZw
Aug 14, 2010 | Stanley Bostitch F21PL Nailer
Bostitch electric nailer shoots two nails at time, how do I fix?
Generally this is because the feeder gets stuck. Usually when this happens to me, I oil the area and fire the guna few times without nails in it. All that is usually needed is either more lubrication or a good cleaning. See the following link for a diagram of the unit to guide you in dis-assembly and re-assembly. Enter the model number at the main page.
Dan
Link: http://www.ereplacementparts.com/bostitch-parts-c-29443.html?gclid=CK232OvOu6MCFZZM5Qod4gz2bg
Aug 13, 2010 | Stanley Bostitch Coil Framing Nailer
My bostitch 1664fn finish nail gun blows lots of air out exaust
Open the front and clear any jammed nails that are there. Oil the gun, push the drive pin back in if it didn't go back in when the front was off and try again. If there are repeated nail jam issues, try genuine Bostich nails.
Dec 03, 2009 | Tools & Hardware - Others
Contact head won't retract...seems to be stuck
Aug 08, 2009 | Stanley Bostitch F21PL Nailer
I have a bostitch SB 16 finish nailer that has a rack of nails stuck in th loading barrel. I need to take the barrel apart to get them out, How do I do this?
The solution provided is harder then it needs to be. Where the nail gun handle attachs to the nail magazine there are 2 bolts. Remove these bolts and the nail magazine slides right out and you can get to the jammed nail. It still took some effort on my part to get the nail out but this was a lot easier then removing the 4 bolts previously suggested.
Jun 30, 2009 | Stanley Bostitch F21PL Nailer
How do you safely remove jammed nail gun?
Not sure exactly what Bostitch framer model you have, but if it is powered by compressed air, as long as you remove the air hose from the nail gun, there should be no risk of the nail gun firing while you remove the jammed nail. There should be a way to access the driver area from the top of the nail gun, even via a latch or a couple screws. Remove the top part of the driver area and that should give you access to the jammed nail, which you can remove. Use long nose pliers or something similar if the nails are really stuck.
May 31, 2009 | Stanley Bostitch F21PL Nailer
Air Tools & Compressors Logo
97 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
