Question about Cameras
Transfer frames from internal memory to memory card
  • kakima Dec 28, 2016
    Hi Sally bennett, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model?
Hi KarenB,
Not sure if anyone ever got back to you on this but i just had the same problem then googled it and found this
Yes, the [BACKUP] feature will transfer files from the camera's internal memory to an xD-Picture Card™ flash memory card. It does not delete those files from the internal memory. To perform a backup, insert an xD-Picture Card flash memory card into the camera and then turn the camera on. Press the [MENU] button. Press the Right arrow button to select the Setup icon, and then press the [OK] button to enter the Setup menu. Use the Up or Down arrow to select [BACKUP], and then press [OK].
Posted on Jun 06, 2008
  • 248 Answers
SOURCE: Philips digital photo frame 7FFI series
Here`s a tip i found for you...
1. Connect the frame to your PC using the supplied USB connector. Navigate to the \DCIM\100Frame directory and delete all the Phillips advertising pictures there.
2. Create a directory on your PC and put copies of all the pictures you want to display there.
3. Download the free picture resizer utility from Microsoft at:
(Look for Image Resizer in the right column). After installing it, "Select All" pictures in the directory you created, then right click and select "Resize Pictures" from the context menu. Choose the 640x400 radio button. Sort by size and copy all the small ones into the "\DCIM\100Frame" directory on the frame drive (Called Removable Disk on my PC).
Posted on Jun 20, 2008
SOURCE: internal memory photos download to sd card
1. Ensure memory card is inside camera.
1. Turn on camera.
2. Press Review button on back of camera
3. Then Press Menu Button on back of camera
4. Select "Image Storage" option (by depressing the joystick on RHS of back of camera).
5. Select "Internal Memory" option (by depressing the joystick on RHS).
6. Select "Continue"
7. Press Menu button.
8. Press "Review" button
9. Press "Review" button again.
10. Press "Menu" button.
11. Scroll down to "Copy" and select this option by depressing the joystick.
12. Scroll down to "All", then select by depressing the joystick.
13. Contents should now copy over from internal memory to SD card.
14. Don't forget to reselect Auto detection of SD card afterward. This is done by turning camera off then back on again. Press "Review". Press "Menu". Select "Image Storage". Select "Auto". Select "Continue".
Posted on Dec 24, 2008
  • 34 Answers
SOURCE: Trying to transfer pics on internal memory to my SD card.
Set the image storage setting of the camera to Internal.
Once it is set to internal, put the card in the camera and press review.
Copy the pictures from the internal memory to the card.
Posted on Jun 22, 2009
SOURCE: Internal Memory to Memory Card
This was a pain for me to figure out. I too had the same problem. This may not be the RIGHT way, but it is how I did it.
First, copy everything you want off the memory card and then insert it into the camera. Format the card.
Then, take a single picture.
Now, with the camera on, hit the playback button to view the picture you just took.
Press the MENU button, and scroll through the menu to the very last entry, which should be COPY.
Press OK, and then you can select to copy from INternal to memory card, or memory card to INternal (note, IN means internal in the menu). You, of course, want internal to memory card, so select it if not already done so, and press okay.
That's all there is too it! I recommend erasing all images from the internal memory once you're done so you don't get confused later if you see images on there again.
Good luck! Ray -
Posted on Jul 26, 2009
How do I save to my internal memory of my digital photo frame ?
Usually, the camera saves to internal memory when no card is present. Internal memory is not large. More for holding a photo or two until you realize there is no card there. When you do save to internal memory you then need to transfer the images to a card, or plug your camera into the computer and transfer the images that way. Hope that helps.
Oct 18, 2014 | Cameras
I have a Fuji FinePix F480 which is brilliant but it isn't downloading all my shots onto my computer. It is showing a message that I have internal pictures. My question is how do I get these pictures to...
I've attempted in the past to download from the internal memory to the computer before with no success. What you can do is put the memory card back into the camera and transfer the internal pictures to your memory card (your camera refers to these as "frames"). I'm not sure if you have a manual or not but what needs to be done is selecting copy using the multi-control button on the back of the camera select "IN" for internal and arrow from internal to card. the only sticky thing about this is you need to do one "frame" at a time. Make sure you have the room on your memory card before doing this. You might want to format the memory card first before you do the transfer from internal memory to your memory card. Then once the Internal "frames" are all on the memory card you can down load them to the computer as "normal"
Dec 18, 2010 | Fuji FinePix F480 Digital Camera
Hi, I purchased 3 Coby digital frames DP 700 with the intention of putting vacation pictures on for three friends. The included directions are useless. Hope you can help. Can I transfer and SAVE...
Good day,
I read up on the specs of the frame and it does not have an internal memory, thus you will have to have the sd card inserted at all times to display photos.
Hope this helps!
Dec 01, 2010 | Coby Cameras
How can we copy from our memmory card to the wide screen picture frame without leaving the card in the unit.
I'm going to guess that you can't. A guess because you don't say the make and model of the frame. If the frame has internal memory, you might be able to transfer picture files into it from a USB memory stick, or a memory card reader that imitates a USB memory stick, so you could put your memory card into one of those to transfer the pics. I guess.
Nov 28, 2010 | Cameras
How do i get pictures off internal memory onto a computer or sd card
Hi, I have the similar s8000fd and I transfer pics from internal memory by taking out the sd card then connect to a spare usb socket on computer, then switch camera on. To transfer pics from internal memory to sd card - leave sd card in, switch on camera (playback mode), press menu, select copy, select 'internal memory to sd card', 'select frame' or 'all frames'. It should say 'copy ok?' Press OK.
Jul 10, 2010 | Fuji FinePix S8100fd Digital Camera
How do i transfer photos from internal memory to a memory card? finepix z 3x
Press > to enter Playback mode, then press Menu/OK to open the Playback menu. Use up/down to highlight Copy, then press right. Use up/down to select Internal Memory -> Card and press Menu/OK. You can copy one picture (frame) at a time or all pictures (frames).
Apr 29, 2010 | Fuji Z10 Digital Camera
How do you access pictures on the internal memory of the Fine Pix F470? I'm not sure if the camera came with a USB that what is needed to connect the camera and my PC?
It is possible to transfer saved images on the internal memory to xD-Picture Card Page 67 on the manual - see limk below
The user manual is here
It is possible to transfer saved images between the internal memory and an xD-Picture Card. 1Press the “w” button to turn the camera on in Playback mode. 2Press the “MENU/OK” button to display the menu on the LCD monitor. 2 a)Press “a” or “b” to select “û” COPY. b)Press “c”. 4 a)Press “a” or “b” to select “FRAME” or “ALL FRAMES”. b)Press the “MENU/OK” button. ALL FRAMES Copies all the frames (files). FRAME Copies only the selected frame (file). COPY 3 a)Press “a” or “b” to select INTERNAL MEMORY \ CARD or CARD \ INTERNAL MEMORY and confirm the copy source and copy destination. b)Press “c”.
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Apr 05, 2010 | Fuji FinePix F470 Digital Camera
Westinghouse 7" lcd picture frame internal memory not recognized
You can copy files from internal memory to sd card only. Its one way data transfer.
Sep 05, 2008 | Westinghouse 7" LCD Digital Photo Frame
Transfer from internal memory to new memory card
Go to Playback Mode (with memory card inserted)
Press Menu/Ok (center botton)
Internal Memory to Card
Then choose "All Frames" or select which ones
Sep 21, 2007 | Fuji FinePix S5700 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
