Question about ASUS Cell Phones
How do I prevent an Asus Zenphone 2E Go Phone from switching to Sign-in to network?
My phone constantly switches to this screen. I only purchase minutes for phone calls and text messaging. The switch to this screen is very rapid. At times I am switched to this screen before I have time to hang up after a phone call.
SOURCE: problem with my samsung SGH-j600 phone
try giving "master reset" option (restore factory settings)
due to some sudden removal of the battery when the cell is on or due to the sudden poweroff of the cell due to low battery it has cause some firmware files to be missing which are needed for the operation .... so just give the master reset option your cell will get reseted & your problem will be solved ...
while giving reset option you must enter the password (security code) ... the default one may be "full of zeros" or 1234 something like that ...
if you have changed that you will be knowing just give that ...
any doubts reply me
i am always here to assist you .
thank you
bye
Posted on Jun 17, 2008
My touch sensative buttons have stopped working is their any way of fixing this problem??
Posted on Aug 14, 2008
SOURCE: Forgeting Settings, Switching Off and On, Freezing Button Usage
I have taken my phone to a Mobile Phone shop and was advised that the problem i was experiencing was common for the 6500 slide and as such i needed to get the phone FLUSHED and it is currently with the phone shop to repair.
Thank you for your assistance.
Pavlos
Posted on Nov 21, 2008
firesnake09
  • 2923 Answers
SOURCE: i cant switch on my p990i phone.
Try power cycling the phone:
1. Remove the battery and leave it out for 5 to 10 minutes.
2. Put the battery back and turn the phone ON.
If you get the same problem, contact the manufacturer for possible firmware upgrade or repair.
Have a great day!
Posted on Jul 26, 2009
  • 75 Answers
SOURCE: I have nokia 5220 xpressmusic
Take the backup of your phone using pc suit and then just simply reset it to the default factory settings. you can do this by going through the settings of your mobile phone handset. Your problem might be solved for free..!!!
PLEASE RATE THIS ANSWER, IF YOU GET ANY HELP FROM THIS ANSWER OR LIKE THE ANSWER
Posted on Apr 04, 2011
I have an at&t asus zenfone and i need the screen unlock code.
Posts Tagged "AT&T Asus ZenFone 2E Unlock Code For Free"
unlockattfree.us/tag/att-asus-zenfone-2e-unlock-code-for-free/
Sep 10, 2015 - Want to Unlock Asus ZenFone 2E AT&T for free but can't find the FreeAT&T Asus ZenFone 2E Unlock Code for ... We have a good news for you. ... Turn on the AT&T Asus ZenFone 2E phone. it will show Unlock Code screen.
AT&T Asus ZenFone 2E Network Unlocking Code to work with T-Mobile ...
www.howardforums.com/.../1867755-Asus-ZenFone-2E-Network-Unloc...
Jul 27, 2015 - 1 post
Unlock AT&T Asus ZenFone 2E to use any where in the world with ... To reset your device, from the home screen, swipe down from the Notification bar. ... Congratulations you have managed to safely root your Asus Zenfone 2. How to Unlock At&t ASUS ZENFONE 2E ? ' At&t ...
1 post
Nov 20, 2015
AT&T Unlock AT&T ASUS Zenfone 2E
1 post
Oct 26, 2015
AT&T How to unlock by code AT&T ASUS ...
1 post
Aug 27, 2015
New ASUS Zenfone 2E available at Walmart
Jul 16, 2015
More results from www.howardforums.com
Dec 29, 2015 | ASUS Cell Phones
I have an at&T Asus zenfone and I need the screen unlock codes
1 post
Nov 20, 2015
1 post
Oct 26, 2015
1 post
Aug 27, 2015
Jul 16, 2015
Dec 29, 2015 | AT&T Cell Phones
Cannot start Asus P527
Hi Friend,
You have not mentioned your problem in details hence assuming that your phone is powering on but After the initial Asus screen it is not Booting then might be your Phone's Firmware is corrupt and if that is the case then you will lose your you Phone's data.
If data is not important then you can try following steps and try to restore to factory default setting
1. make sure Battery is charged
2. Remove Sim/ Memory Card
3. Switch Off The phone
4. Insert stylus tip in reset Hole which is on right Side of the phone and press it
5. with stylus tip inserted in Reset hole press power on switch
6. A warning message will appear on screen, remove the stylus and press Call receive key on your phone's Keypad and phone will set to factory default setting.
Then Follow instructions
if still Problem is not solved call Asus customer Care, you will have to visit service centre.
May 23, 2010 | ASUS P527 Smartphone
Suddenly switch off
Friend, G is for GPRS and is displayed only when you are using GPRS. It means that when you poweron the phone is either sending/receiving emails thru GPRS. Switching off could be more serious than sending/receiving emails.
Sep 20, 2009 | Nokia 6300 Cellular Phone
I recently purchased an HTC viva phone. it switches on and then shows a white screen with a cross like icon that moves around the screen and cant show the network, time and network service provider. please...
if it is like a cross that moves from center to corners when pressed it's the aligment screen just touch all the crosses and it should load up the phone
hope this helps
Sep 05, 2009 | HTC Touch P3450 Smartphone
Keys not functional though you can only switch the phone on
May be the phone is 'locked'. Check for a locked sign (probably a padlock sign) in the top edge of the screen.
Jul 13, 2009 | Nokia 6500 Slide Cellular Phone
Message problem
That sign is GPRS go to network seting and stop GPRS
Feb 05, 2009 | Nokia 7373 Cellular Phone
Bluetooth is failing and my GPRS network not available
You just switch off your phone for a while then switch it on again it must work.
May 05, 2008 | Motorola Mobility V360 Cellular Phone
Cell Phones Logo
24 people viewed this question
Top ASUS Cell Phones Experts
Computer Repairing
Computer Repairing
Kolbrun...
Are you an ASUS Cell Phone Expert? Answer questions, earn points and help others
