Question about Refrigerators
Freezer Lffh21f7hwb keeps saying door ajar, not freezing. I unplug it, the plug back in and unit starts running again, later the same pattern again. Door seal is intact, no damage.
Also noticed compressor and light going on/off as I swing the door.
fixincars
  • 335 Answers
SOURCE: Door ajar light
The sensor for the lights is in the door latch spray some GOOD penetrant in the door latch (WD 40 IS NOT A PENETRATING OIL!!!!!!!!!!!!!!!!!!) open and shut the door several times after you let the penetrant soak a bit Liquid wrench, PB Blaster, BG Penetrant, are good
I owned Ace Automotive for 14 years and came across this problem on ford windstars and aerostars all the time I posted the fix on my website Please visit
http://www.aceautomotive1.com It is in the BLOG or FAQ
Please email me with the results of this. fixincars@yahoo.com
Please rate this a fixya if you feel its helpful Thanks, Randy
Posted on Sep 12, 2008
SOURCE: door ajar light won't go off
I had the same problem. Spray WD-40 (with the sprayer extender) into the latch of the doors very liberally. Open and close doors a few times. Should resolve issue.
Posted on Jun 01, 2009
  • 11 Answers
SOURCE: door ajar light and beep keeps going off
take the small black cover off from the pillar side of the switch and use the straw with the wd-40 can and lubricate the switch well.. old ford tech trick
Posted on Jun 06, 2009
  • 10 Answers
SOURCE: "Door Ajar" light won't go off. Interior lights staying on.
I sprayed WD40 in the handle opening and moved it up and down a few times and sprayed some in the latch and it went away.
Posted on Mar 16, 2010
walleyracing
  • 76 Answers
SOURCE: 2003 Jetta Door ajar light keeps coming on and
You need to replace the door jamb switch. Little button on the door jamb that is pressed in when doors are shut.
Posted on May 03, 2010
Freezer stops freezing I unplug it then plug it back in and it starts to run
When you unplug it do you leave it unplugged for a period of time or just real quick? If you leave it unplugged for a long enough period of time it will defrost and then begin to run again for some time before it freezes up again and stop. Not really sure of what your saying when you say stops freezing and then starts to run when you plug it back in.
Jul 29, 2015 | Refrigerators
Accidentally left the freezer door very slightly ajar a few days back. Though it's keeping food cold, it's not freezing them back up.
Ask a friend/neighbour/family member if you can store the meat in their freeser for a day or two. keep an odd item ir two in the freezer see if it freezes. If it does then replace your dood in it which should be frozen by then.I give freezers a chance or two when things start to go wrong. As your issue was caused by leaving the door open there is probably not a fault, If it is resolved fine. If it is not then think about the repairman. As I am a little overcautious I tend to buy a new machine when white goods go wrong.
GOOD LUCK
Jun 14, 2015 | Refrigerators
Amana bottom freezer unit warms, then resets after being left unplugged
If the door does not shut correctly, humidity enters the unit and condenses inside. The defrost function is not designed to work properly under such a condition.
Ice (frost) builds up around the cooling coils, and actually insulates them, so you don't get good cooling. When you unplug the unit, the frost melts, runs into the bottom tray beneath the unit (can't see it).
When you turn it back on it cools like it should until the frost builds up again. You need a good gasket and a door that is adjusted properly. You also need the unit level at least side to side, but front to back also is preferable.
The unit has front leveling feet, and the back usually adjusts itself with self-leveling feet. The adjustments for the door are metal bars inside it, behind the inside storage panel.
The hinges are also adjustable. Sometimes the door sags from heavy things stored inside it. You must loosen the hinges a bit, lift the door and hold it while you tighten the hinges.
Sometimes the unit can be unsalvagable, because it's been situated incorrectly for so long that it's permanently bent out of square.
OR, the defroster clock might be bad.
Jan 20, 2014 | Refrigerators
My frigidaire freezer upright has an error message door ajar
Sounds like the main control board to the unit needed to be reset and with the resetting it has caused a communication error with the door sensor. Contact a service tech to move forward with a repair.
Sep 04, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer side is working fine. the fridge side appears not to be as cold as it use to be. a few days ago my kid left the door ajar all night. how ever it should be cold by now. there is power I can hearthe...
When a refrigerator door is left open the freezer will continue to run to keep it cold and since it can't cool an open area it will freeze up on the inside, to resolve this you will need to unplug the fridge and open the freezer door and allow the freezer to thaw completely, once it is thawed you can plug it back in and everything should go back to normal after a 24 hour period
Jun 28, 2011 | Kenmore Side by Side Refrigerator
Whirlpool refrigerator side by side freezer won't freeze
your over-load/contactor is defective, un plug it from compressor and shake it if it rattles its bad
Oct 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer not freezing and blowing luke cold air. Fan running full time.
rotate the defrost heater timer until it clicks and see if the defrost heater is working
Jun 02, 2009 | Refrigerators
Freezer left open and now won't work
Try to unplug the unit from the wall and let it sit for a few minutes then plug back in. May reset the door alarm lock out. Also, moisture in the air can be drawn in and freeze up the whole thing. That means turning it off with doors open for about 36 hours... Moisture is a killer in a freezer, freezes and blocks up every air circulation vent, etc.
Sep 16, 2006 | Samsung RS2534 Side by Side Refrigerator
Refrigerators Logo
21 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
