Question about Ryobi Air Tools & Compressors
Ryobi air strike nailer sticking when firing - Ryobi Air Tools & Compressors
4 Suggested Answers
wiringlunati
  • 576 Answers
SOURCE: central pneumatic air nailer leaks air around
Probably needs the trigger valve rebuilt/replaced. Contact Harbor Freight for replacement parts.
Posted on Nov 25, 2009
  • 6 Answers
SOURCE: I have a central pneumatic palm nailer leaks air
sounds like a bad o ring inside the housing .
Posted on Feb 01, 2010
  • 1388 Answers
SOURCE: porter cable FR350 round head nailer type 2 fires when it is connected to air hose and won't fire afterward
Various nailers will fire on their own when connected to air if the orings have become hard or worn and internal trigger valve parts worn-out (mostly Dewalt and P/C). You could buy an oring kit or purchase trigger valve seperately. Replacing trigger valve and lubing the headvalve with white grease will most likely solve the problem. After repairing the gun, be sure to remove the nails from the mag after each use to prevent possible discharge of nail. Good luck
Posted on Oct 23, 2012
What gage staples do I need for a p300 ryobi air stapler?
Good morning Victoria,
The staple series that you'll need is probably need is a 90 series. These are again an 18gauge wire in several different lengths.
Regards
collatedfasteners
Jul 05, 2014 | Ryobi P300 One+ Stapler Brad Nailer
Grip rite roofing nailer
make sure there is not any tar or black cement makeing the driver stick to the inside of nose
Apr 15, 2012 | Grip Rite Grip - Rite Coil Roofing Nailer...
Brand new unit. Used last weekend, no problem. Today, won't shoot nail. Air is released when trigger pulled, but no nail plunged.
Orings /other parts tend to stick when nailer is new. Dewalt uses some vinyl orings that have been causing premature failure. Be sure to add a few drops of oil when used. Too much oil is not good. Wrong oil will cause orings to swell and cause problems such as yours. Your nailer's firing valve can be reset by rapping the nailer against rubber surface such as a thick rugger mat or coiled rubber air hose. Remove airline and nails, being carefull not to damage the head, rap had against rubber mat and retest gun. If it did not reset rap against nose of gun and test. If no joy, you will most likely need to remove head and manually move cylinder up/down and /or check vinyl orings for failure. Before you try to reset the gun, make sure that the safety is pushing the firing pin all the way in. Air removed, look under the trigger as you push down on safey, if it does go all the way in try bump-firing the gun (for test have nails removed). Hold in trigger and quicky /firmly strike gun against rubber pad. Good luck
Nov 14, 2010 | Dewalt D51850 Heavy Duty 20 Degree Full...
Striking pin does not return to firing position
Bad 0-ring or bent firing pin...
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Oct 20, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Driver does not retract after striking a nail
if its new warranty it,
otherwise all it should need is a rebuild kit . its just a bunch of orings and gaskets. pretty easy to do. take some pictures as you take it apart to help with reassembly.
Dewalt should have scematics online or ereplacements.com
Apr 08, 2010 | Dewalt D51844 Framing Nailer
Paslode framing nailer will onley fire one time and wont return to fireing pos. fires first nail great . started this problem after cleaning
Did you remember to lube the upper cylinder, lg 0-ring and silicone the striking pin----sticking may prevent returning to firing position
Mar 05, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Porter cable brad nailer only fires brad on second trigger pull
The dent in the wood is not caused by the air. It's caused by the set that drives the brad. Are you oiling it consistenly? Are the brads the right manufacturer for your porter cable brad nailer? From the information you give it appears that the brads are not advancing correctly or that the air pressure is not sufficient to dislodge the brad from the brad strip on the first strike - it takes an additional strike to break it free. The standard for adding oil is to add ten drops of air tool oil for every hour of operation. That seems like a lot, but the correct amount of oil is a sure way to prevent most air tool problems.
Aug 29, 2009 | Makita AF503 2'' 18 - Gauge Brad Nailer
Air Tools & Compressors Logo
74 people viewed this question
Top Ryobi Air Tools & Compressors Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
ray gallant
Are you a Ryobi Air Tool and Compressor Expert? Answer questions, earn points and help others
