Question about Tools & Hardware - Others
Is there a loose mertal shim that goes eith long nose air staple gun
  • 2712 Answers
SOURCE: staple gun support
Know the types of staple guns available. They can be manual, electric, battery operated or run by compressed air with an air compressor. Some staple guns have guide wires because they’re used by electricians that can’t pierce wires. Others have long noses to work well in corners and tight spaces. There’s also a reverse built ergonomic staple gun called a "forward action" because the handle and the staple’s exit point are on the same end of the staple gun. Some staple guns can shoot brads instead of staples. Know how each type of staple gun works. This one is so simple because it works just like a stapler. You press and hold the silver latch on the back of the stapler to open the body. Take the tray out and fill it with staples. Then it’s ready to use. Just put the staple ejecting end on your piece to be stapled and squeeze it. There is also the forward action manual gun which is used by pushing the handle down, too. The handle is just located near the staple ejection site. Use an electric staple gun for effortless stapling. There’s no need to squeeze or apply any pressure on these guns. They come with a very short cord so you will always need to have an extension cord with your staple gun. You can also go with a rechargeable battery operated cordless staple gun. They are great but they do run out of steam so for long use one with a cord is better. They’re also pretty easy on the wallet these days, so there’s no reason to go without this in your home tool kit as it’s something that does a lot of jobs. Know the versatility of the staple gun. Whether you have a manual or an electric model, these are some of the most versatile tools out there. You can use them to recover furniture, to build a birdhouse, to staple lattice to a patio, to build lightweight projects like a small knick knack shelf and to do wiring work.
Posted on Aug 27, 2008
SOURCE: staple gun
Open the chamber and drop the staples upright in to the chamber do not try to load the staples by placing them on the strip that pulls out as you do with most staple guns.
Posted on Nov 25, 2008
danny_murray
  • 55 Answers
SOURCE: Need help on how to put staples in Ace staple gun 22084
At the very botton of the stapeler in the back there should be a square mechanism press in and down then just slide the staples in and eplace the mechanism the way you took it out
Posted on Dec 05, 2008
efs_perpends
  • 1996 Answers
SOURCE: I have a staple stuck in my Arrow model #ETN-50
Unplug it. If you can see the driver jammed against the staple, take a screwdriver end and try to push the driver back in and the staple should be released. If you can't get the driver to go in and release the staple, you'll have to disassemble it to clear the jam, If you need help with that, see the instructions for the current model here, page three, diagram 3, cleaning the magazine.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Aug 18, 2009
Testimonial: "Thanks for your help! Much appreciated!"
  • 1383 Answers
SOURCE: duofast ms 7664c staple gun still blowing air out
This series of nailers are the most difficult to repair. Your nailer has twice as many orings as the norm. Many have said that this nailer is over-engineered. There are three areas that could cause trigger area leak. To make it simple, lets do one area at a time. Use soapy water around the trigger area to find actual leak. If air is leaking from actual trigger valve (ms719-2) and its counterpart, the cartridge (ms719-1) then these two parts need to be removed. Check for scratches in the metal of the valve. If scratched try to remove with fine paper or replace as necessary. Most leaks are due to faulty trigger valve. If air is not leaking from actual trigger valve then remove the dump valve (mn120-5) at the back of the head of gun. There should be two small allen screws then metal lid, then spring and oring. Pull out dump valve and make sure all the orings are in order. This valve should be able to move, not too tight. Use silicone paste lube on all orings (available at Lowes in plumbing department, Danco brand used for faucet orings). Reinstall dump valve and related parts and check for leaks. If air seems to be leaking from bottom of gun neer trigger, most likely problem is cycle valve (mm419-1) and related vinyl seat. These two parts are in the valve housing under the trigger. This valve also moves within its housing and seats on a vinyl oring. This part could be clear vinyl or black rubber. New seats are clear. Inspect these parts for scratches/cuts and lube with silicone paste. Hopefully you would have solved the problem with trigger valve. Good luck with your repair and do not dispare, this is one of the most difficult guns.
Posted on Jul 09, 2010
WHEN STAPLE GUN IS PLUGGED IN IT WON'T START. PLEASE ADVISE.
Take the entire staple feed assembly on the bottom apart. Sometimes a staple or part of one jams in the back/inside of the mechanism and can only be pried out with needle nose pliers. Good luck.
Sep 14, 2015 | Tools & Hardware - Others
Staples are stuck inside the stapler and will not come out
Typically you do not open these up.
Makes it difficult to remove stuck or wrong staples.
I have had good luck removing the staple ram rod and rapping firmly on the **** of the stapler against a wooden table. The idea is jolting the stuck staples into reverse out the way they went in. Tedious process but usually works. Removing the jammed staples in the nose at the striker plate requires using needle nose pliers and a sharp awl or small screw driver used on very small screws.
My T50 Arrow stapler is over 20 years old.
Still works great. Sometimes I slide in the wrong size staples by mistake. The process above usually works.
May 26, 2010 | Arrow T50P ARROW STAPLE GUN
After filling with staples, could not get gun to "shoot" the staple out. did we lose a spring that pushes staples forward?
It's possible, but they are not usually free to fall out. Check for a staple jam where they come up against the driving tongue. This is a common problem with any stapler. Hope this helps!
Apr 12, 2010 | Powershot Tool Company Cobra 8000 Forward...
Remove a jam staple from a hardwood floor stapler
on that model there should be a few bolts on the tip side of the nose , remove screws and top part of nose and remove the damaged staple,, then replace parts
Nov 30, 2009 | Surebonder Pneumatic Stapler
How to repair jammed arrow electo matic staple gun
You'll have to disassemble it. There is probably a staple lodged in the "hammer" mechanism on the business end of the stapler.
Often, these staple are very difficult to remove -- a very small flat-tip screwdriver and needle-nose pliers usually work best.
After you get all the jammed staples out, lubricate all moving parts with something akin to 3-IN-1 machine oil. This should prevent future jams.
Charlie
Aug 20, 2009 | Heavy Duty 648967 Arrow Electric Staple...
How do you load staples into the gun?
The staplesare NOT loaded on top of the pull out shaft; they are inserted directlyinto the slot that opens when you pull the shaft out. If the nose ofthe tool is not placed firmly against a surface, it will not fire.
CLICK HERE
and click the PDF icon on the right of the model # to start the download.
Here is a step by step:
Unplug the tool.
Squeeze the end of the shaft at the rear bottom of the tool and pullout the shaft.
Flip the tool over on it’s back.
Insert the staples,(points up) and then slide the shaft back in.
Plug it in, press the on button (under the the power cord in the back). Press the nose squarely against the material and press the trigger
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 07, 2009 | Stanley Tools TRE550 Electric Staple/Brad...
How to remove jammed staples in staple gun?
Take out the small bolt that is secured with a nut at the back of the gun (at the end where you feed the staples) -- then drop the inset. Now you have access to the jammed area. Clear out jammed staples and put the stapler back together. Easiest way is to hold the nut and turn the bolt from the other side.
Jun 16, 2009 | Arrow T50P ARROW STAPLE GUN
Piece of staple stuck in the trigger section of arrow t-50p
First, remove the magazine pusher / spring and any staples loaded in the magazine.  Then try firing the gun to clear the staple.  Use a small jeweler's screwdriver and small needle nose pliers to get the staple out.  Reload and test.       These are relatively inexpensive staple guns.  If the problem persists it might be less trouble to replace the gun.     Best of luck and I hope this solution works for you.   Michael Mittelsdorf
Jan 11, 2009 | Arrow T50P ARROW STAPLE GUN
Staple gun support
Aug 27, 2008 | Black & Decker 5700 Powershot Forward...
Tools & Hardware - Others Logo
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
