Question about Garden
How to replace broken trigger on a huskie 162 sg chain saw
  • yadayada
    yadayada Dec 27, 2016
    Is this a Husqvarna and Huskie is short for that? If so you can find the info on youtube.
  • 22 Answers
Most Husky saws have a small pin to drive out to remove trigger. Often safety lever on top needs to be removed also. Sometimes tank/handle assembly needs to be removed to replace trigger.
Posted on Dec 28, 2016
  • 211 Answers
SOURCE: chain saw repair this a valid product stupid
Hi
If the piston has the same carracteristiqs,size and shape it is ok.
best regards savumihai71
Posted on Feb 12, 2009
SOURCE: My chain saw starts but won't move the chain, and shuts off when
Make sure the chain brake is not engaged.Pull it toward the handle until it latches.Also check for sawdust under the chain sprocket cover.Adjust the chain to remove slack but make sure you can still move it by hand.
Posted on Apr 09, 2009
dontbother10
  • 2220 Answers
SOURCE: Husqvarna 65 fuel line
This is Husqvarna.com manuals. You wlll need to find the IPL that applies to you. The exploded diagrams should help you trace the fue lines.
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Lou
Posted on Sep 05, 2009
dontbother10
  • 2220 Answers
SOURCE: chain saw trigger
You don't tell me the make or model, your answer can be found here:
Homelite/Ryobi.com
http://www.gardnerinc.com/recons/disclaimer-lg.php
HusqvarnaUSA.com
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
Lou
B-Roosky
  • 59 Answers
SOURCE: Oil is leaking out the bottom of the saw after
check the hose that goes to the oilway if everything checks clear you may have a crack in your oil tank due to excessive vibration and weak molding.
Posted on Jan 12, 2010
Testimonial: "Your answer seems about right. I'll look into it further and report back"
File size
For a .325 chain you need to use a 3/16 fille
Jun 28, 2013 | Garden
Throttle linkage
It seems that Mac engineers could have come up with something better than the M.M. kluge that they did. The problem is hooking the wire link to the plastic hook on the trigger plastic casting while juggling the front case and engine body. It appears that it should just snap together, but knowing how plastics get with age, it would appear that the trigger should be replaced every time the case comes off. I had trouble with mine and wound up straightening out the wire link end somewhat to force the parts together--it continues to work though. Hope this helps!
May 05, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Husqvarna chain saw oiler problem
I fear you are correct about the oiler problem. I see a lot of oiler problems on these saws. Sooner or later Husky will have to address it. Ask the dealer about modifying your oiler; the 350 has an adjustable and might fit 1 or both of these saws. I think Husky needs to admit the nonadjustable is a mistake, and come up with a fix.
If you want to do some research start with the IPLs here:
HusqvarnaUSA.com
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Please post back (below) with what happens at the dealer. Take your buddy and his saw with you! Good Luck. HTH
Lou
If Husky starts modifying all these with 350 oilers I want compensation...LOL
Feb 17, 2010 | Husqvarna 450 e-series 18" Chain Saw
Chain sprocket won't turn on my 450e series chainsaw
The most common causes are the chain is to tight or the chain brake is triggered.
Page 15 discusses how to check oiler operation and page 17 discusses both chain tension and the chain brake. You cannot check the oiler if the chain cannot rotate. (you provided no serial number, this may not be your saw Feb-2008)
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2008/HOUS2008_1151081-96.pdf
If this is not the problem or you have additional questions please reply below. I will get back to you.
If I chose the incrorrect manual you can download the right one here:
HusqvarnaUSA.com
06 1500198
HTH
Lou
Feb 13, 2010 | Husqvarna 450 e-series 18" Chain Saw
When I top up the chain oil it runs out of the opposite side really rapidly, I don't see how to fill it in the instruction booklet
Are you using bar oil? Is it less than 2 years old (warranted)? Did the chain come off and hit the tank?
I think your saw may have been impacted and the oil tank is broken. I didn't see an oil vent on the IPL but if the filler is on the bottom of the saw and you must lay it on its side to fill there must be one. Take it and your bar oil with you and stop by your friendly neighborhood Husky dealer. Ask what they think the problem might be. You might be pleasantly surprised. Purchase some 2 cycle oil, a new chain, some bar oil, something. When time for a new saw remember how they treated you.
HusqvarnaUSA.com
Serial number decode – for use with IPL
06 1500198
Oct 15, 2009 | Husqvarna Forest & Garden No.967012396 345...
It starts up, but when trigger is pulled, the
Most saws have a safety or anti kickback brake. Yours might have tripped. There is a guard in front of where your left hand holds the saw. With the saw NOT running, pull the guard HARD towards the back of the saw. It should move a bit ant you may hear a click. The chain should now move. If the chain moves easily when the saw is not running, but doesn't move when you rev the saw up, the clutch is broken.
Sep 10, 2009 | Garden
My Husky 36 did this. The oil pump drive gear was stripped and had to be replace. It's located under the flywheel/sprocket so you have to pull that. I couldn't find info on how to do that so had a local shop repair it for $70! Parts are cheap, labor is not.
Oct 22, 2008 | Husqvarna Chain Saw 20" Bar
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
