My 40" flatscreen tv picture wont illuminate but the power light blinks while pluggi
  • 4234 Answers
SOURCE: STANDBY MODE FOR PANASONIC FLATSCREEN TV TH-42HD6
Your TV is in protect mode. A problem was detected and the set shutdown. Is there a pattern to the blinking?
Dan
Posted on Mar 21, 2009
  • 105 Answers
SOURCE: Newer Jvc tv wont turn on
1. hold the [vol-] and [menu] button.
2. while holding those, press the [power] button and let go of the [power]button only
3. wait 5 seconds then let go of [vol-] and [menu]
4. wait for a while(approx 30secs).....do you get a picture
This works for the JVC models that end in "9" and end in "0"
Posted on May 27, 2009
  • 7 Answers
SOURCE: 26" Samsung flatscreen LCD doesn't power up
Just to be a little more detailed, since I just fixed this problem. It is the capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Posted on Sep 25, 2009
SOURCE: Model #LNS4051DX/X 40 inch LCD HDTV
Just fixed one of those.
Filter caps on power board 4 x 1000 uF / 10V.
http://www.coppelltvrepair.com
Posted on Dec 11, 2009
  • 27 Answers
SOURCE: tv wont turn on power
power supply unit problem you have bad caps (capacitors) change all the caps or atleast the onces they leaking how do you see if they bad usually they are bold on the top instead of flat. change it with a higher voltage but the same UF. if it shows 10V-1000uf you change to 16V-1000uf or if it fits a 25V-1000uf.
Posted on Feb 09, 2011
LG 60PN6500 plasma tv power surged. has no picture and i think no sound. tv wont turn on but stand by light illuminates but then shuts off. in a cycle fashion. cant find my multi-meter to check fuses
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 20, 2017 | LG Televison & Video
My 40" Coby flatscreen is getting power but wont turn on....any solutions?
Replace the defective power supply that is inside the TV set.
May 23, 2014 | Coby 40 TFTV4028 LCD TV
Sanyo 50" plasma flatscreen, hdtv
Picture frozen on one picture for some channels and blank on others. Sound is on. What could this be? We have a 50" Sanyo. HELP!
Apr 13, 2011 | Sanyo DP32746 32 in. LCD Television
Samsung LA40A550 no picture and sound
Power supply board is dead.That the board,the power a/c cord go into it.Replaced the power supply board will solved ur tv power lite LED light indicator blinking and ur tv power will be stable and work again.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 04, 2010 | Samsung LA40A550 40 in. HD-Ready LCD TV
Flatscreen tv no picture instead of green light for power it blinks red
The led blinking is an error code from the internal processor - defining the nature/area of the TV's internal problem.
A service manual (if available) will de-cipher the code.
The tv will probably need to be repaired by a service technician.
Oct 07, 2009 | Philips Televison & Video
Phillips 32" HDTV power light blinks green but wont turn on
the problem in the main power supply it depends of the kind of faillure but normaly to repair it not very expensive
good luck
Aug 23, 2009 | RCA F32650 32" TV
May 25, 2009 | JVC LT-40X776 40 in. LCD HDTV
I have a LG 32 in flatscreen. It wont turn on. The green light blinks and I see the monitor light up some but no picture or sound. I can not see the menus or anything else. What can I do to fix this? I...
hi..the reason due to this problem may be
due to the circuit board.If the soldering is not
done in any part of the main board this type of
problem occurs.check the board completely.
check this out..
thank u..
rate me..
Feb 10, 2009 | Philips Televison & Video
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
