Question about Tools & Hardware - Others
On a rainco long nose air staple gun is thers a metal shim between the nose and the main body of the air gun
2 Suggested Answers
  • 13 Answers
SOURCE: staple jams by driver blade
The problem is wear on the sides of the driver blade. With the constant up/down movement of the driver against either side of the nose plate, it eventually narrows enough to allow part of the fine wire 71 series staple to find it's way between the driver blade and the inside wall of the nose plate. A new driver blade cures this completely. Rainco tackers have become a bit rare but the good news is, they're actually manufactured by Fasco and the Fasco driver fits into the Rainco piston by the removal of a single pin to allow the old blade out, replace with the new Fasco blade, re-insert the pin into the piston, then re-assemble the gun and you're away.
Posted on Apr 02, 2011
Rainco stapler parts
Needs o'ring kit and lower bumper.
Nov 09, 2013 | Tools & Hardware - Others
Staple jams by driver blade in gun and I have to dismantle nose to get it out. Empire Rainco 7-16.
Mar 06, 2011 | Nailers Empire Rainco R16 Stapler Driver...
Need spring on a rainco staple gun
Rainco are a variant of the Fasco range. There will be a Fasco tool identical to your Rainco so take it to a Fasco stockist and yo'll sort it.
Jan 17, 2011 | PHIL & TEDS SPORT BUGGY Jogger
FixYa RainCo R1b 7C -16
Hello; If the gun is AIR operated, adjust the AIR presure DOWN on the regulator on the air compressor tank? If it is electric operated! there should be a depth DIAL (say 1-8, 1 being the least depth and 8 being the most; depending on the hardnest of the item being stapled) trial & error to be tried on a scrap piece first......! hope this helps, John.
Aug 19, 2009 | Staples Tools & Hardware - Others
Schematics on fasco air stapler #F1B 7C-16
I can e-mail you schematics. I have all Fasco & Rainco parts for this tool and more in stock!
Aug 10, 2009 | Fasco Staple Gun Pneumatic F3c Atw-38 Mod...
Cannot load staples
At the back of the staple gun is a flat shaped metal piece. It's at the bottom. Push in, pull down, then pull the mechanism out. You'll see it's a metal rod with a spring, that is attached to that flat metal piece. The spring pushes against another flat metal piece, that has a hole in it, and travels back, and forth on the rod.
The flat metal piece that the spring pushes down the rod, pushes against the staples.
Remove this spring mechanism, slide the staples down the rails. The staples will be in the position of an upside down U. Replace the spring mechanism, and lock it back into place. (Push in, pull up)
Should, your question be in reference to the fact that you have staples loaded, but upon pressing the trigger nothing comes out:
In the front of the staple gun, is a flat metal piece that pushes down on the staples. One staple at a time. The flat metal piece is shoved down by spring pressure. The spring pressure is applied to the flat metal piece each time you squeeze the trigger. (Flat metal piece = Hammer)
Sometimes, Two staples try to come out. When they do, this flat metal hammer is stuck up in the gun. To free the flat metal hammer, remove the spring mechanism out of the back of the staple gun. (The spring mechanism discussed above) Remove any staples in the gun.
Try to use a flat blade screwdriver, and see if you can shove the flat metal hammer in the front of the gun -> UP.
(DO NOT have the staple gun pointing at your face! DO NOT squeeze the trigger! DO NOT use excessive force)
If this method is of no avail for you, you have to disassemble the gun, and remove the metal hammer, and stuck staple/s.
Jul 29, 2009 | Arrow T50P ARROW STAPLE GUN
Rainco R16L leaking air
go to airnailerparts dot com
Thanks,
Jeff
Apr 10, 2009 | Tools & Hardware - Others
Staple gun support
Know the types of staple guns available. They can be manual, electric, battery operated or run by compressed air with an air compressor. Some staple guns have guide wires because they’re used by electricians that can’t pierce wires. Others have long noses to work well in corners and tight spaces. There’s also a reverse built ergonomic staple gun called a "forward action" because the handle and the staple’s exit point are on the same end of the staple gun. Some staple guns can shoot brads instead of staples. Know how each type of staple gun works. This one is so simple because it works just like a stapler. You press and hold the silver latch on the back of the stapler to open the body. Take the tray out and fill it with staples. Then it’s ready to use. Just put the staple ejecting end on your piece to be stapled and squeeze it. There is also the forward action manual gun which is used by pushing the handle down, too. The handle is just located near the staple ejection site. Use an electric staple gun for effortless stapling. There’s no need to squeeze or apply any pressure on these guns. They come with a very short cord so you will always need to have an extension cord with your staple gun. You can also go with a rechargeable battery operated cordless staple gun. They are great but they do run out of steam so for long use one with a cord is better. They’re also pretty easy on the wallet these days, so there’s no reason to go without this in your home tool kit as it’s something that does a lot of jobs. Know the versatility of the staple gun. Whether you have a manual or an electric model, these are some of the most versatile tools out there. You can use them to recover furniture, to build a birdhouse, to staple lattice to a patio, to build lightweight projects like a small knick knack shelf and to do wiring work.
Aug 27, 2008 | Black & Decker 5700 Powershot Forward...
Tools & Hardware - Others Logo
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
